  3. Domoticz
  4. Light level sensor add to Domoticz
4 Posts 2 Posters 3.5k Views 1 Watching
  • DickD Offline
    DickD Offline
    Dick
    wrote on last edited by Dick
    I created a light_level sensor and now I want to use it as a sensor in Domoticz (use it to turn the lights on on an certain light level). I have no clue how get it in place. I read about the creation of a dummy hardware, what I did. Now I don't know anymore. The light level sensor is already visible in the device list of domoticz.
    • S Offline
      You dont need a dummy switch - you need a switch that controlls your light. Then you create some rules either in LUA or in blockly.
      Here is my light scripts from LUA (my lightlevel is named utomhusljus and my group with windowlights is called "fonsterlampor"):
      commandArray = {}
      v = tonumber(otherdevices_svalues['Utomhusljus'])
      if  (v <= 30)) then
      commandArray['Group:Fonsterlampor']='On'
      end
      return commandArray
      You need to code it more than this, (for example they should not be turned off after midnight or when you go to sleep) so you might need to add more variables, like current time or something.
      For example this will turn on the group "Fonsterlampor" but not later than 21:50 or earlier than 4:59:
      commandArray = {}
      h = tonumber((os.date('%H')))
      if  (v <= 30 and h < 22 and h >= 5) then
      end
      return commandArray
      You can also use blockly as I said. It should be easier, you find it in the menu but I have no knowledge about that. Google domoticz blockly tutorial or something.
      DickD 1 Reply Last reply
      • S sundberg84
        commandArray = {}
        if  (v <= 30)) then
        end
        return commandArray
        commandArray = {}
        end
        return commandArray
        DickD Offline
        DickD Offline
        Dick
        Thank you to give me a push in the right direction. I gonna use Blocky.
        Have a nice day and I can go on with my build
        • DickD Offline
          DickD Offline
          Dick
          I read about blocky for domoticz. It looks easy but my first steps are not so easy. I opened in "more options" the option "events", in events I select a "Control" (if/Do), also a "Logic" (>-), a "device " (temperature). In this beginning fase I am not able to connect temp device to the Logic. Anybody recognize this?
          12.2k
