  3. Wakeup on Interrupt not working
5 Posts 3 Posters 2.6k Views 2 Watching
  • HenryWhiteH
    HenryWhiteH
    HenryWhite
    wrote on last edited by HenryWhite
    I have an external system which outputs a signal (~2.5V) on one of its pins under certain circumstances. So I hooked up this output pin to the digital pin 3 on my arduino pro mini (and obviously GND from the external system to GND from the arduino), so that the arduino can tell me whether the external system triggered or not.
    Now, when I don't put gw.sleep() in my code, everything works as aspected.
    But when I put gw.sleep() in my code and tell it to wake on interrupt, it doesn not work (the arduino doesn't wake up when I trigger the external system)
    Does somebody has an idea why this is the case? Here's my code:
    //unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    #define DIGITAL_INPUT_SENSOR 3   // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
    // Initialize motion message
      gw.begin(NULL,35,false,AUTO);   //Henry Node-ID anpassen!
      gw.sendSketchInfo("SmokeRF", "1.0");
      pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the  sensor digital pin as input
      gw.present(CHILD_ID, S_DOOR);
      if (digitalRead(DIGITAL_INPUT_SENSOR)==HIGH) {
        Serial.println("Alarm");
        gw.send(msg.set(1));  // Send value to gw
      // Sleep until interrupt comes in on sensor. Send update every two minute.
      gw.sleep(INTERRUPT,CHANGE,SLEEP_TIME);
    • NickB149N
      NickB149N
      NickB149
      Did you already try applying 5V on the interrupt pin manually?
      Maybe the 2.5V is not enough to trigger the interrupt.
      HenryWhiteH 1 Reply Last reply
      • NickB149N NickB149
        HenryWhiteH
        HenryWhiteH
        HenryWhite
        I'm using a 3.3v arduino pro mini, so the 2.5v should be enough i think?
        • L
          L
          Lemme
          Try this:
          gw.sleep(1, CHANGE, 0);
          • HenryWhiteH
            HenryWhiteH
            HenryWhite
            Problem solved!
            First, I forgot to activate the internal Pullup:
            digitalWrite(DIGITAL_INPUT_SENSOR, HIGH);
            Besides that, every signal greater than 0.5V is recognized as interrupt, BUT digitalRead only recognizes signals greater than 1.5V!
            When my external system triggers, it starts to slowly increase the voltage from 0.5V up to 3.3V. It reaches 1.5V after 5 seconds triggering. I cancelled the test every time after 3-4 seconds, so that's the problem why nothing worked.
