  3. combine working 4 relay with buttons with HC-SR501 motion sensor
1 Posts 1 Posters 897 Views 2 Watching
  • DickD
    DickD
    Dick
    I still have difficulty with combining sensors but learn a lot, Now I try to combine my working 4 relay sensor with 4 buttons with a HC-SR501 motion sensor . I want to use the pir information in my Domoticz controler. If the pir information is available in Domoticz , I can decide what to do.
    Any help is Welcome.
    Here my working 4 relay and 4 button code
    #include "Bounce2.h"
    #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
    #define RELAY_OFF 1
    #define RADIO_ID 11                    // radio Id, whatever channel you assigned to
    #define noRelays 4
    const int relayPin[] = {A1, A2, A3, A0}; //  switch around pins to your desire
    const int buttonPin[] = {A5, 6, 7, 8}; //  switch around pins to your desire
    class Relay             // relay class, store all relevant data (equivalent to struct)
    public:
      int buttonPin;                    // physical pin number of button
      int relayPin;                     // physical pin number of relay
      byte oldValue;                    // last Values for key (debounce)
      boolean relayState;               // relay status (also stored in EEPROM)
    Relay Relays[noRelays];
    Bounce debouncer[noRelays];
    MyMessage msg[noRelays];
      gw.begin(incomingMessage, RADIO_ID, true);
      delay(250);
      gw.sendSketchInfo("Multy-Relay&Pulsanti", "0.2");
      delay(250);
      // Initialize Relays with corresponding buttons
      for (int i = 0; i < noRelays; i++)
        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
        Relays[i].relayPin = relayPin[i];
        msg[i].sensor = i;                                   // initialize messages
        msg[i].type = V_LIGHT;
        debouncer[i] = Bounce();                        // initialize debouncer
        debouncer[i].attach(buttonPin[i]);
        debouncer[i].interval(5);
        pinMode(Relays[i].buttonPin, INPUT_PULLUP);
        Relays[i].relayState = gw.loadState(i);                               // retrieve last values from EEPROM
        digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
        gw.send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
        gw.present(i, S_LIGHT);                               // present sensor to gateway
        delay(250);
      gw.process();
      for (byte i = 0; i < noRelays; i++)
        debouncer[i].update();
        byte value = debouncer[i].read();
        if (value != Relays[i].oldValue && value == 0)
          gw.saveState( i, Relays[i].relayState );
        }                 // save sensor state in EEPROM (location == sensor number)
        Relays[i].oldValue = value;
    // process incoming message
      if (message.type == V_LIGHT)
        if (message.sensor < noRelays)            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
          digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
