  3. Relay skech API 2.0 Port?
2 Posts 2 Posters 1.1k Views 2 Watching
  • ThomasDrT
    ThomasDrT
    ThomasDr
    can any one tell me what to change in this sketch for API 2.0?
    Relay example in the Build section.
    regards
    Thomas
    Boots33B 1 Reply Last reply
    • ThomasDrT ThomasDr
      regards
      Thomas
      Boots33B
      Boots33B
      Boots33
      @ThomasDr
      The updated relay sketch is included as an example with the MySensors V2 install
      I have copied it and pasted it below
       * Version 1.0 - Henrik Ekblad
      #define MY_REPEATER_FEATURE
      void before() {
          pinMode(pin, OUTPUT);
          present(sensor, S_LIGHT);
        if (message.type==V_LIGHT) {
           // Change relay state
           // Store state in eeprom
           // Write some debug info
           Serial.print(message.sensor);
