  3. OpenHAB
  4. My final setup to get MySensors and OpenHab communicating via MQTT
mqttopenhab
24 Posts 7 Posters 20.1k Views 13 Watching
  • Meshx86M
    Meshx86M
    Meshx86
    My delimma here is Address distribution, i can't get openhab to distribute Address to the nodes when connecting, the MQTT Gateway sketch of my sensors doesn't do that right ?
    Any tips that would be great
    • Martin TellblomM
      Martin TellblomM
      Martin Tellblom
      Set a static node id using
      #define  MY_NODE_ID 20
      20 in this case is the node id.
      MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
      Meshx86M 1 Reply Last reply
      • Martin TellblomM Martin Tellblom
        Meshx86M
        Meshx86M
        Meshx86
        @Martin-Tellblom cheers
        • Eric BuhringE Eric Buhring
          I wanted a solid platform to connect MySensors to OpenHab. I struggled getting messages to come back from OpenHab to MySensor with both the serial gateway and the MQTTGateway on 1.5.4. Finally I abandoned that approach and went to MySensors 2.0 MQTTClientGateway > Mosquito > OpenHab and it all works beautifully. I am posting my final setup so that maybe it will help others trying to accomplish the same thing. If I have omitted anything critical please reply and I will try to update this.
          Controller
          • Raspberry Pi (Jessie)
          • Openhab 1.8
          • make sure you org.openhab.binding.mqtt-1.8.1.jar in your addons directory
          • 192.168.1.101
          MQTT Broker
          • Mosquito on same Raspberry Pi as OpenHab
          • followed steps to install here https://mosquitto.org/2013/01/mosquitto-debian-repository/
          • 192.168.1.101 running on port 1883 this needs to be set in both OpenHab.cfg and in GatewayW5100MQTTClient sketch (see below)
          MQTT Client Gateway
          • Genuine Arduino
          • Gikfun Ethernet Shield W5100
          • Addicore nRF24L01
          • MySensors 2.0 https://github.com/mysensors/Arduino/archive/master.zip
          • GatewayW5100MQTTClient from examples folder in zip
          MySensors RelayActuator
          • Arduino Nano clone
          • Addicore nRF24L01
          MQTT Client on my iPhone
          • This is so useful for getting the messaging correct (both from OpenHab and Sensor)
          • MQTT Inspector 1.0 is the one i used
          GatewayW5100MQTTClient sketch I didn't change these lines but you need to note them. They form an important part of the message structure that your openhab items will need to subscribe to
          // Set this nodes subscripe and publish topic prefix
          It is important to change the lines below so that the MySensors MQTT Client device is on your network and can communicate correctly. Use the same subnet as your other devices. You can get gateway information using ipconfig on windows..
          #define MY_IP_ADDRESS 192,168,1,87
          #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
          Change these lines to point to your Mosquito MQTT Broker
          #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 101
          #define MY_PORT 1883
          openhab.cfg I probably should have called the broker mosquitto instead of mysensor but just note that this is the alias openhab will use to talk to the broker and can be anything you choose
          # URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
          mqtt:mysensor.url=tcp://192.168.1.101:1883
          # Optional. Client id (max 23 chars) to use when connecting to the broker.
          # If not provided a default one is generated.
          mqtt:mysensor.clientId=openhab
          1closed0open.map this is in opt/openhab/configurations/transform
          1=closed
          0=open
          mqtt.items
          before each message is a symbol. < means openhab is subscribing to this topic. As such topics need to be prefixed with the values in your gateway. If you left the default use mygateway1-out prefix. I am not including the code I use to publish to the Garage Door item. > means openhab is publishing to this item. The default prefix here is mygateway1-in. Now the good news here is once everything gets connected and starts sending messages, you can use a MQTT client to watch for specifc messages by subscribing to both mygateway1-out/# and mygateway1-in/#. This is how i dialed in the values you see in my mqtt.items file.
          String Garage_Door  "Garage Door [%s]"           (gGarage, Windows)   {mqtt="<[mysensor:mygateway1-out/101/3/1/0/16:state:MAP(1closed0open.map)]"}
          Switch MQTTTestSwitch  "MQTT Test Switch"  (gBasement)  {mqtt=">[mysensor:mygateway1-in/2/2/0/0/2:command:ON:1],>[mysensor:mygateway1-in/2/2/0/0/2:command:OFF:0]"}
          Modified RelayActuator Sketch from MySensors 2.0 examples
           * Version 1.0 - Henrik Ekblad
          // #define MY_REPEATER_FEATURE
          #define LED_PIN 6
          void before() {
              pinMode(LED_PIN, OUTPUT);
              digitalWrite(LED_PIN, LOW);
              present(2, S_LIGHT);
            Serial.print("V_LIGHT=");
            Serial.print(V_LIGHT);
            Serial.print("got message of type ");
            Serial.println(message.type);
            if (message.type==V_LIGHT) {
               // Change relay state
               digitalWrite(LED_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
               // Store state in eeprom
               // Write some debug info
               Serial.print(message.sensor);
          One other thing to note is that the type of item can affect how it reacts to values. For example, originally my Garage Door item was of type contact and i kept getting messages in my openhab.log that said it could not set state because new value was NULL. I switched it to string and it worked.
          sgthree
          @Eric-Buhring I found that changing the line in the my sensors program that sends the message as below allowed me to use a Contact rather than a Switch
          if (value != sentValue2) {
          		// Value has changed from last transmission, send the updated value
          		send(msg2.set(value==HIGH?"OPEN":"CLOSED"));
          		sentValue2 = value;
