  3. [Closed][Unresolved]gateway DHCP Fail
5 Posts 2 Posters 2.5k Views 1 Watching
  • markjgabbM
    markjgabbM
    markjgabb
    wrote on last edited by markjgabb
    gateway DHCP
    i have a feeling im probably missing something really strait forward
    i get the following message
    DHCP FAILURE...0;255;3;0;9;Transport driver init fail
    now i think debug is already turned on and this is what the above message is.
    im using the rmf chip....but im unable to tell which ethernet shield im using, im assuming its the w5100, and im using that sketch at this point....
    unsure of what steps to take after this
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    //#define MY_IP_ADDRESS 10,0,0,200   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 10, 0, 0, 1
    #define MY_MAC_ADDRESS 0x00, 0x00, 0xDE, 0xAD, 0xBE, 0x01
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
    #include <Ethernet.h>
    • greglG
      greglG
      gregl
      Take a photo of your board and we can help identify.
      I would recommend ONLY using static ip's for "servers/gateways" etc on your network. Only use DHCP for 'clients" ( pc's and mobile devices )Did you try assigning a static address?
      Also, do you have any other arduino based network devices already running? If so check the MAC address its already using.. DEADBEEFEED is typically used, and MAC address's must be unique on a subnet (as it says in the sketch) - So change the MY_MAC_ADDRESS to something else.. looks like you may have already - but is 0000DEADBE01 valid?
      • markjgabbM
        markjgabbM
        markjgabb
        hey guys board pic is below....im guessing now looking at it that the mar address for the board dshould be the HR number printed on it?
        im aware of the static desirability, i will also have a reservation for it later on...only using DHCP now to try and figure out why its not hitting the network properly...
        once this part is done ill be ready to go....
        im unable to tell if my made up mac is valid...havent dealt in MAC's before
        board pic
        • markjgabbM
          markjgabbM
          markjgabb
          ok i can safely ignore my own comment about the mac address....a) no there are no other devices
          b.) the model number printed is not the mac address...
          there is no mac printed anywhere on he board so im not sure how to create one...
          but unless im horribly mistaken that shouldnt affect the DHCP assign of IP address at this stage...
          i have attached a better coipy of the picture where you can see my pin locations
          • markjgabbM
            markjgabbM
            markjgabb
            worked around the issue but making it a serial gateway instead as long as my nas is happy i dont mind how it plugs in....
