  3. Converting to 2.0 Slim Node as a Mini 2AA Battery PIR Motion Sensor code
10 Posts 3 Posters 3.9k Views 3 Watching
  • J
    J
    jacikaas
    I'm trying to convert @m26872 Slim Node as a Mini 2AA Battery PIR Motion Sensor code, from 1.5 to 2.0 MySensors library, but becose I'm very begginer at programming I facing with some unknow issues for me.
    Converted code from 1.5 to 2.0 MySensors library:
     * EgSlimReed2
     * Sketch for Slim Node and HC-SR505 based motion sensor.
     * Inspired by:
     * - MySensors motion sensor example: http://www.mysensors.org/build/motion
     * - AWI's CR123A based Slim Node motion sensor: http://forum.mysensors.org/topic/2478/slim-cr123a-2aa-battery-node
     * Created by m26872
     * Documentation: http://forum.mysensors.org...
     * Version 1.0 - Test to if node can operate in some way dealing with the Pir extreme sensitivity to noise on Vcc.
     * Version 2.0 - First "production node". "Inactivity day counter" introduced.
     * This sketch will only send trips as "1" to the controller. It's up to the controller to deal with the info.
     * The motion node will not notify controller when resets back to low state and is ready for a new trip. In reality
     * this is ~10s. And EVEN IF motion is detected continuously, there will be no new trip until motion has stopped for ~10s.
     * The HC-SR505 is very noise sensitive and will trigger spuriously for almost any activity
     * on Vcc (test thoroughly). To run the HC-505 at low voltages (tested flawlessly down to 1.6V),
     * the 7133-reg and diode are removed (and possibly increase the sensitivity even further).
     * Solution is to deal with it by interrupt type, check which source, block by sleep time etc.
     * HC-505 output connects to MOTION_INPUT_PIN (here D3) without any supporting component. Input pull-up disabled.
     * Every 24 hrs without trip, increments a counter and after "BATTERY_REPORT_DAY" counts a battery report will be sent as a heartbeat signal.
     * Else a battery report will be sent after every "BATTERY_REPORT_BY_IRT_CYCLE" motion trips.
    #include <Vcc.h>
    //#define DEBUG
    #define MY_BAUD_RATE 9600
    #define MY_NODE_ID 3  // Use static Node_ID  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<  //14 var senaste "slim-PIR"-id
    #define SKETCH_NAME "EgSlimPIR2"
    #define SKETCH_VERSION "2.0 2016-01-01"
    #define CHILD_ID 5
    #define MOTION_INPUT_PIN 3
    #define BATTERY_REPORT_DAY 2   // Desired heartbeat(battery report) interval when inactive.
    #define BATTERY_REPORT_BY_IRT_CYCLE 10  // Make a battery report after this many trips. Maximum report interval will also be equal to this number of days.
    #define ONE_DAY_SLEEP_TIME 86400000
    #define VCC_MIN 1.9
    #define VCC_MAX 3.3
    #ifdef DEBUG
    #define DEBUG_SERIAL(x) Serial.begin(x)
    #define DEBUG_PRINT(x) Serial.print(x)
    #else
    int dayCounter = BATTERY_REPORT_DAY;
    int irtCounter = 0;
    bool interruptReturn = false; // "false" will make the first loop disregard high output from HV-505 (from start-up) and make a battery report instead.
    Vcc vcc;
    MyMessage msg(CHILD_ID, S_MOTION);
      present(CHILD_ID, S_MOTION);
      DEBUG_SERIAL(9600);
      DEBUG_PRINTLN(("Serial started"));
      delay(100); // to settle power for radio
      pinMode(MOTION_INPUT_PIN, INPUT);
      digitalWrite(MOTION_INPUT_PIN, LOW);    // Disable internal pull-ups
      DEBUG_PRINTLN("Warming and blocking PIR trip for 20s.");
      sleep(20000); // Wait until HC-505 warmed-up and output returned low.
      if (interruptReturn) {    // Woke up by rising pin
        send(msg.set("1"));  // Just send trip (set) commands to controller. (Let controller reset and decide what to do with it.)
        irtCounter++;
        if (irtCounter>=BATTERY_REPORT_BY_IRT_CYCLE) {
            irtCounter=0;
            sendBatteryReport();
      else { // Woke up by timer  (or it's the first run)
        dayCounter++;
        if (dayCounter >= BATTERY_REPORT_DAY) {
              dayCounter = 0;
      sleep(3000);  // Make sure everything is stable before start to sleep with interrupts. (don't use "gw.wait()" here). Tests shows false trip ~2s after battery report otherwise.
      // Sleep until interrupt comes in on motion sensor or sleep time passed.
      interruptReturn = sleep(MOTION_INPUT_PIN-2,RISING, ONE_DAY_SLEEP_TIME);
      // DEBUG_PRINT("interruptReturn: ");DEBUG_PRINTLN(interruptReturn);
    void sendBatteryReport() {
              float p = vcc.Read_Perc(VCC_MIN, VCC_MAX, true);
              int batteryPcnt = static_cast<int>(p);
    When I compiling code on arduino I get:
    Warning: Board arduino:avr:apm96 doesn't define a 'build.board' preference. Auto-set to: AVR_APM96
    In file included from C:\Users\Moni\Documents\Arduino\sketch_aug11c\sketch_aug11c.ino:37:0:
    C:\Users\Moni\Documents\Arduino\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    exit status 1
    Error compiling for board APM Optiboot internal 1MHz noBOD 9600baud.
    I was trying to reinstall MySensors library, but it didn't help.
    Maybe someone could advise, where I made a mistake in code when converting it?
    Thank You!
    m26872M 1 Reply Last reply
    • J jacikaas
       * EgSlimReed2
       * Inspired by:
       * Created by m26872
      #include <Vcc.h>
      //#define DEBUG
      #define CHILD_ID 5
      #define VCC_MIN 1.9
      #define VCC_MAX 3.3
      #ifdef DEBUG
      #else
      int irtCounter = 0;
      Vcc vcc;
        DEBUG_SERIAL(9600);
          irtCounter++;
              irtCounter=0;
          dayCounter++;
                dayCounter = 0;
      exit status 1
      Thank You!
      m26872M
      m26872M
      m26872
      @jacikaas I'm not very up-to-date on anything in these days :disappointed: , but it looks like a preference is missing from the "boards.txt" in Arduino IDE. Which IDE version do ou use? Can you post the "boards.txt" please?
      J 1 Reply Last reply
      • m26872M m26872
        J
        J
        jacikaas
        @m26872
        Actually that one error with preference:
        ...was also on 1.5 library and sketches was succsessfully uploaded.
        I'm using 1.6.10 Arduino IDE version.
        Yes, of course. In boards.txt file I paste same configuration description as in this link, at the end of file:
        # Add the new board to boards.txt (normally located at "C:\Program Files\Arduino\hardware\arduino\avr"
        # The *.bootloader.* etries only matters if you want to program bootloader (and fuses) from Arduino IDE.
        # See http://www.engbedded.com/fusecalc (select Atmega328p) for interpretation of fuse values and how
        # extended fuses are written in different applications (07h in Arduino IDE = FFh in Atmel studio).
        apm96.name=APM Optiboot internal 1MHz noBOD 9600baud
        apm96.upload.tool=avrdude
        apm96.upload.protocol=arduino
        apm96.upload.maximum_size=32256
        apm96.upload.speed=9600
        apm96.bootloader.tool=avrdude
        apm96.bootloader.low_fuses=0x62
        apm96.bootloader.high_fuses=0xde
        apm96.bootloader.extended_fuses=0x07
        apm96.bootloader.path=optiboot_v50
        apm96.bootloader.file=atmega328_1a.hex
        apm96.bootloader.unlock_bits=0x3F
        apm96.bootloader.lock_bits=0x2F
        apm96.build.mcu=atmega328p
        apm96.build.f_cpu=1000000L
        apm96.build.core=arduino
        apm96.build.variant=standard
        Do I need to post whole boards.txt file?
        • J jacikaas
          @m26872
          m26872M
          m26872M
          m26872
          @jacikaas Ah! Forget about the warning. You error comes from that you haven't put your MySensors-related defines before the "include MySensors.h". Look here link.
          • m26872M m26872
            J
            J
            jacikaas
            @m26872
            A golden rule - RTFM. Next time I will use it :)))
            Thank You, that was it! Now code is compiling. But I think my HC-SR505 is broken, becose it don't see any movement.
            I need to order new one :)
            A lot of thanks!
            • J jacikaas
              @m26872
              A lot of thanks!
              m26872M
              m26872M
              m26872
              Did you test it with just a simple LED+resistor at the output ? Another option is to just measure the supply current (47uA when idle, 64uA for 10s after trigger).
              • m26872M m26872
                J
                J
                jacikaas
                @m26872
                Yes, now I test it with LED+resistor. It's definately broken, becose if I hide PIR sensor, data output always get high. LED light up for a while, then goes down for 2-3s and goes up again. And it repeating all the time, when it is covered (no movement in background).
                Thanks for Your help @m26872 !
                • Martin TellblomM
                  Martin TellblomM
                  Martin Tellblom
                  Tried this setup and its not working very well for me, can be a busted PIR but I don't know.
                  It seems like it sometimes work, but if I leave the room and then enter it can take long time until the PIR triggers.
                  If i put a LED and a resistor I do that between GND and signal or where do I place it?
                  MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
                  • Martin TellblomM Martin Tellblom
                    J
                    J
                    jacikaas
                    @Martin-Tellblom
                    Hey, try like that:
                    https://goo.gl/images/pQ9nTU
                    • Martin TellblomM
                      Martin TellblomM
                      Martin Tellblom
                      Thanks I'll try that
