  3. Arduino with ESP8266-01 and MQTT
1 Posts 1 Posters 1.2k Views 1 Watching
  • 79kiko7
    79kiko7
    79kiko
    Works MQTT Gateway library with ESP8266-01?
    I uploaded MQTT Gateway library to my ESP8266-01 and I dont know what I have upload to my Arduino. Im testing SerialGateway sketch with RelayActuator sketch like this.
    RX and TX from ESP8266 to pin 8,9.
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 2
    // Set RS485 baud rate to use
    #define MY_RS485_BAUD_RATE 9600
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
    #define RELAY_1  11  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before() {
        pinMode(pin, OUTPUT);
        present(sensor, S_LIGHT);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    My serial monitor output:
    0;255;3;0;9;TSP:SANCHK:OK
    0;255;3;0;9;Starting gateway (RSNGA-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;11;Relay
    0;255;3;0;12;1.0
    0;1;0;0;3;
    0;2;0;0;3;
