  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 110.1k Views 40 Watching
  • sundberg84S sundberg84
    Connection diagram/circuit between RFM module and atmega328p-au TQFP footprint.
    tssk
    I would like to ask about the radio module connection - I am using SX1276 and I connect it the same way as described by @sundberg84 said in 💬 Connecting the Radio except I additionally connect also RST (NRESET) pin according to this https://github.com/sandeepmistry/arduino-LoRa/blob/master/README.md#semtech-sx1276777879-wiring
    Is it necessary?
    • J
      J
      jenspr
      I was wondering about the lengths for the antennas mentioned on this page.
      For 868Mhz is mentioned a length of 82.2 mm on this page. The length most often mentioned over the internet - as first result of the 1/4 wave calculation - is 86,5mm.
      Searching a little deeper through the internet, i found that the antenna should be "a little shorter". Then they end up with around -1cm shorter or something around or more.
      One page mentioned the physically effect that the wave is moving in chopper around 5% slower as the theoratical speed. If i substract 5% of 86,5mm i end up with the here mentioned 82,2mm.
      I was very suprised about the different "approaches" for such a basic thing as antenna length every single . As most of the application over the internet seem to work somehow with all that different lengths, it seems to be just a fine-tuning thing.
      Anyway, i think it would be nice to mention this details here because most people will wonder about the 82,2mm in the first view...
      best regards
      Jens
