  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.3k Views 40 Watching
  • maghacM maghac
    Thanks - I use NRF24 radios.
    I found MY_RF24_CE_PIN which I redefined to pin 8 which worked absolutely fine.
    The problem I have now is that now cannot use the Newbie PCB anymore :cold_sweat: :wink:
    @maghac cut the trace with a small knife and re-attach it with a wire.
      @maghac doh!
      How about using a software pwm library instead? I have not tried any, but I have seen this before: https://github.com/Palatis/arduino-softpwm
      maghacM
      maghacM
      maghac
      @mfalkvidd Maybe I'll give that a try.
      I think FOTA will fail as the bootloader will try to initialise the radio with the default pin, right? Then I'll need software pwm or recompile my own bootloader.
      gohanG 1 Reply Last reply
      • maghacM maghac
        @maghac or go for dual optiboot
        maghacM 1 Reply Last reply
          maghacM
          maghacM
          maghac
          @gohan But then I would need additional hardware to use DualOptiBoot?
          Anyone have any quick instructions on how to build a new custom version of MySensorsBootLoader using MY_RF24_CE_PIN = 8 :wink:
          I have access to ArduinoIDE on Windows or a Ubuntu 16.04 box.
          • maghacM maghac
            @maghac yes, an spi flash chip. It is not a bad solution since the firmware is transferred during normal node operation and if it fails nothing bad happens.
              @maghac - EasyPCB rev 10 will probably include spi flash ;)
              • alowhumA
                alowhumA
                alowhum
                It might be an idea for the "connecting the radio" page on MySensors to point to these handy boards:
                https://www.aliexpress.com/item/Free-shipping-Nano-328P-IO-wireless-sensor-expansion-board-for-XBEE-and-NRF24L01-Socket-for-arduino/32298692903.html
                Then people have to just plug in the NRF24 boards. And it also makes it much easier to connect lots of sensors. I wish I had known about these boards earlier, it would have saved me a lot of time.
                  It depends if you want to go with the nano or the pro mini like many nodes use
                  • KimmoHopK
                    KimmoHopK
                    KimmoHop
                    wrote on last edited by KimmoHop
                    #129
                    Just noticed, that MySensors 2.2 changed default RF24 CS pin on Mega2560 from pin 10 to pin 53 (SS) :/ I could not find any reference to the change from 2.2 change log nor from pull request (722)... No wonder RF24 worked with 2.1.1 but not with 2.2 on M2560.
                    Contrary to instruction above, I wanted to continue with old pins (same as on Uno) and set the pins explicitly to MY_RF24_CE_PIN=9 & MY_RF24_CS_PIN=10. Now transport seems quite good (with combined HW and SW ack, static GW address, no routers) :)
                    • KimmoHopK KimmoHop
                      @kimmohop thanks for reporting. Looks like the change was introduced in commit b132a8a81e2ba6c81bcc6e2afce7513cdddbe193. I have added a message to the release notes.
                      • alowhumA
                        alowhumA
                        alowhum
                        @gohan perhaps it can be added to the buying advice page? There the Nano is advised.
                        • alowhumA alowhum
                          @alowhum which of the buing pages are you referring to? https://www.mysensors.org/store/buying_guide has the pro mini.
                          • alowhumA
                            alowhumA
                            alowhum
                            @mfalkvidd: Yes that's the page I'm referring to.
                            • alowhumA alowhum
                              #134
                              @alowhum I'm confused. Could you clarify what you want us to change on that page?
                              • alowhumA
                                alowhumA
                                alowhum
                                Add a link to: https://www.aliexpress.com/item/Free-shipping-Nano-328P-IO-wireless-sensor-expansion-board-for-XBEE-and-NRF24L01-Socket-for-arduino/32298692903.html
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  While you're at it: maybe tell people about the NRF52 option?
                                  • alowhumA alowhum
                                    #137
                                    @alowhum thanks. That does indeed look lika nifty solution. I'll add it.
                                    For the nrf5x, I don't know which boards are user-friendly, and I haven't understood if MySensors nrf5x support is "production ready" yet or if it requires people to tweak or otherwise do special stuff to get a node working. I don't think I have seen anyone building nrf5x MySensors nodes yet.
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      Lots of people have I think, check the NRF5 thread. I built my own first one this week (BME280 sensor). It rocks.
                                      • Arduino with built in NRF24 for $3.
                                      • The size of a postage stamp.
                                      • Powerful enough to use the simple encryption functionality.
                                      • Antenna socket: just plug in antenna for more range.
                                      • skywatchS
                                        skywatchS
                                        skywatch
                                        Maybe it's just me, but in the first image of a pro mini the top row of pins seem to be reversed to what I normally see.....
                                        • 4
                                          42isjustanumber
                                          My first post at mysensors.org. Sounds like a great tool. Tried to set up an MQTT Gateway with Hardware as described above, ESP8266 and RFM69W with 868 MHz, to connect some Technoline TX29DTH-IT temperature and humidity sensors, without success. ES8266 is working , connects with my wifi network and also connects to my mosquitto server. But I do not get any connection from RFM to technoline. Is there anyone out there who was able to get this running?
                                          YveauxY 1 Reply Last reply
