  2. Announcements
  3. 💬 Serial Protocol - 2.x
43 Posts 17 Posters 19.0k Views 13 Watching
    You may need to get in touch with openhab binding developer to fix that
    jjkJ Offline
    jjkJ Offline
    jjk
    @gohan yes, have done that. Thanks for your time and support!
    • I Offline
      I Offline
      itbeyond
      I am investigating a problem I have found with I think openHAB but I am not sure if this issue is not related to the Gateway code of 2.3.0.
      When a node performs a requestTime() I am seeing this reported:
      2018-10-09 10:47:13.337 [INFO ] [rs.internal.gateway.MySensorsGateway] - I_TIME request received from 2, answering...
      Looks perfect and the node receives the time however I was curious as to why sometimes the node would receive GMT and at other times my local timezone GMT+8. I decided to run the gateway via MYSContoller so I could monitor and log the traffic and I have found the problem. When the Gateway receives the request it responds twice within a few ms of each other, for what reason I do not know but the first response send the local time zone response (GMT+8) and the second is a GMT response. The logs from MYSController for the above report are as follows:
      318857 9/10/2018 10:47:19 RX 2 - Irrigation Ctrl (2) INTERNAL C_INTERNAL NO I_TIME
      318858 9/10/2018 10:47:19 TX 2 - Irrigation Ctrl (2) INTERNAL C_INTERNAL NO I_TIME 1539082039
      318859 9/10/2018 10:47:19 TX 2 - Irrigation Ctrl (2) INTERNAL C_INTERNAL NO I_TIME "1539053233
      Note the quotes where picked up in the copy and paste (I did this several times) so it looks like the body was changed to a string type but I also caught this in the MYSController Debug:
      9/10/2018 10:47:19 RX 2;255;3;0;1;
      9/10/2018 10:47:19 INFO Reply time request
      9/10/2018 10:47:19 TX 2;255;3;0;1;1539082039
      9/10/2018 10:47:19 FWD 2;255;3;0;1;1539053233
      9/10/2018 10:47:19 TX 2;255;3;0;1;1539053233
      So I am curious as to where the FWD comes from and why the response body has changed between the TX, FWD & TX?
      • T Offline
        T Offline
        tonbor
        Is there a type to present in mysensors for solar radiation w/m2. Got a veml6075 sensor. And domoticz has a solar radiation sensor type.
