  2. Announcements
  3. 💬 Building a wired RS485 sensor network
164 Posts 33 Posters 76.9k Views 35 Watching
  • C cabat
    @hypnosiss you may be interested in this https://forum.mysensors.org/topic/11814/rs485-transport-ack-support/6
    H
    H
    hypnosiss
    @cabat thank you. I have losts when number of messages are sent from HA to nodes(throught mqtt ethernet gateway) and in the same time nodes are sending messages to controller as well. I described issue on Home Assistant forum but without any response - https://community.home-assistant.io/t/lost-messages-sent-simultaneously/363904
    • J
      J
      JeeLet
      yes it's not easy, the loss of package is a difficult thing to
      to counter, but not entirely.
      and the multiple layers of a computer system do not help :)
      some philosophy on collision avoidance
      https://arduino.stackexchange.com/questions/24523/rs485-multimaster-communication-with-collision-avoidance
      don't mix the Protocol (data encapsulation)
      and the physical support (voltage frequency impendance / star or serial bus)
      the ModBus protocol on a RS485 support
      https://www.electroniclinic.com/arduino-modbus-rs485-arduino-rs485-master-and-slave/
      a different explanation https://www.codrey.com/learn/rs-485-arduino-quick-primer/
      for information
      https://github.com/sonyarouje/Arduino_HardwareSerial_RS485
      But the best solution (reliability and especially lightness of the sketch) is the CAN bus :)
      I may have said some stupid things ;)
      Translated with www.DeepL.com/Translator (free version)
      • J
        J
        JeeLet
        wrote on last edited by JeeLet
        #163
        a line of the examples given in the sketches for the use of RS485 can be a source of problem
        (it's my case, I use Pin2 or3 for a long time :( )
        // Define this to enables DE-pin management on defined pin
        #define MY_RS485_DE_PIN 2
        (2 or 3 is an interrupt pin for a Uno)
        avoided interrupt pins.
        the pin 10 is a good thing :)
        • H
          H
          hypnosiss
          Thank you @JeeLet !
          I've been struggling with missing msgs for years with my Arduino Mega
          I changed pin and no issues! :D
          In the pjon code I've reached to list of tested pins that communication works properly
          https://github.com/gioblu/PJON/blob/38e36bb1228c1690143cfbf693a0bcb809514d6c/src/strategies/OverSampling/README.md?plain=1#L12
