  2. Announcements
  3. 💬 Building a wired RS485 sensor network
164 Posts 33 Posters 77.0k Views 35 Watching
  • wimdW wimd
    @MICK HI, please check this topic : https://forum.mysensors.org/topic/5495/rs485-on-nano
    mickM
    mickM
    mick
    @wimd Thanks mate! That topic was just what I was looking for. Works perfectly with defining a node ID!
    Just added this to my sensor node:
    #define MY_NODE_ID <X>
    and everything came together. Thank you for your quick reply.
    • K
      K
      kimot
      Yes. It is very bad for beginners, that examples in MySensors library are wrong.
      Example "MotionSensorRS485" will never work and I think, that author not tested it.
      MY_NODE_ID must be always defined for node in RS485 network, because is used for RS485 network addressing.
      Obtaining NODE_ID from controller with currentRS485 network implementation is impossible and I think it should be clearly mentioned in the examples and documentation.
        Would be better if someone with a RS485 setup could analyse and fix the root cause of why automatic id assignment doesn't work than just change the example to use static ids.
        Did the id request reach your controller or gateway? Did the id response get to your gateway?
        K 1 Reply Last reply
          K
          K
          kimot
          @hek
          I think it is simply. In radio network, each node has its unique "radio ID" , witch is used for delivering messages between nodes in radio network. So node can send message " Give me NODE_ID" and gateway or controller knows to witch radio ID send message with assigned NODE_ID in it.
          But in RS485 network we had not unique network ID by default - we use directly NODE_ID for addressing messages between nodes.
            No, it follow exactly the same flow as in a radio network. The gateway (and nodes) should listen to "channel" 255 which is used for broadcast messages (picked up by anyone interested; I.e. repeaters and nodes waiting for new id).
            When a id request is sent out from a node, the gateway will forward it to the controller.. the controller sends out the new id on 255 (which is forwarded by the gateway) and (hopefully) picked up by the new node.
            So somewhere in stil flow the message is not sent along for some reason. Which controller do you use @kimot?
              K
              K
              kimot
              @hek
              I am using Domoticz, but not using RS485, instead I am working on CAN protocol layer for MySensors or using only MySensors serial gateway protocol in my CAN-to-Domoticz gateway. For that reason I am studying source code of MYSensors a lot of. Its only useful documentation source, unfortunately.
              Imagine, if you "switch on" entire your network with 10 nodes. Each node send request for NODE_ID to the gateway and gateway send broadcast with assigned NODE_ID. How RS485 nodes recognizes, that this NODE_ID is exactly for specific node?
              Why in radio network is something like MY_RF24_NODE_ADDRESS?
              ( five bytes long, 4 are constant, fifth is radio ID )
              I seems, that entire this "MySensors network DHCP" stuff is made in different level then MyTransportXXXXX.cpp level. Maybe radio drivers ?
              If you know, how it works, pleas write here or send link, please.
              I can imagine only mechanism, when only one new node is connected at time, or some random generated number in each node or unique serial number etc. Then gateway can send NODE_ID with this "mark" end receiving node knows, that this is for it.
                wrote on last edited by hek
                #27
                This will not work (and the same applies for a radio network). All nodes will then pick the broadcasted id.
                This is known limitation and has its technical background in how the radios work and that the new have problem generating a good unique random number when it starts blank.
                I know we had some ideas of adding a payload (random number) on the id-request payload identifying the requesting node. The node then also check that this number is the same in the id-response. But would break backward compatibility with the serial protocol so it would only happen in a bigger (3.0?) release.
                Edit: Added issue so we won't forget it.
                https://github.com/mysensors/MySensors/issues/732
                  K
                  K
                  kimot
                  @hek
                  Thanks for your explanation.
                  Last question for you. I cannot find information about internal message strukture.
                  Only this discussion:
                  https://forum.mysensors.org/topic/305/mysensors-protocol-format
                  or
                  "hacking" libraries
                  Witch version is actual?
                  I need myself write translation between my network message format and MySensors message format to use
                  something like MyTransportRS485.cpp. But I have limited number of bytes for payload, so I need modify and test "data" array too.
                  Thanks.
                  • R
                    R
                    Reza
                    is domoticz support this gateway ?
                    wimdW 1 Reply Last reply
                    • R Reza
                      wimdW
                      wimdW
                      wimd
                      @Reza yes, select MySensors Gateway USB for type if you add hardware.
                      R 1 Reply Last reply
                      • wimdW wimd
                        R
                        R
                        Reza
                        wrote on last edited by Reza
                        #31
                        @wimd
                        i have problem with usb port in raspberry. everytime after power off/on , usb port lost for me. so now i use a raspberry gateway . rs485 can run on gpio ? with a virtual usb port
                        • R Reza
                          @wimd
                          wimdW
                          wimdW
                          wimd
                          @Reza sory but I'm not able to help you with this.
                          R 2 Replies Last reply
                          • wimdW wimd
                            R
                            R
                            Reza
                            @wimd
                            thank you :pray:
                            • wimdW wimd
                              R
                              R
                              Reza
                              @wimd
                              i have problem with nrf24. and this is work bad for me in distance 10 or 20 meter. i have problem in wireless connection. this protocol have not this problem ? connection is good ? with out any disconnect ?
                              • R Reza
                                @wimd
                                thank you :pray:
                                wimdW
                                wimdW
                                wimd
                                @Reza Check https://www.mysensors.org/build/raspberry. There is a comment for a serialgateway.
                                • wimdW wimd
                                  R
                                  R
                                  Reza
                                  @wimd
                                  i see this, but this is not for a arduino wiring. this is for a nrf24 . perhaps @marceloaqno can setup a rs485 gateway on raspberry. thank you
                                  • R Reza
                                    @wimd
                                    wimdW
                                    wimdW
                                    wimd
                                    @Reza Struggling also with the radio network if the distance is more then 5m (and I'm using the ones with the antenna) I have troubles
                                    Add #define MY_RF24_PA_LEVEL RF24_PA_HIGH to send on maximum power.
                                    Added the capacitor give a bit extra power on the 3,3V?
                                    I do not have a RS485 network installed yet but trails on a 10m ethernet cable did not give any issues. Still in program phase.
                                    • R Reza
                                      @wimd
                                      wimdW
                                      wimdW
                                      wimd
                                      @Reza scroll down on the page down to the serial gateway chapter on that page.
                                      • wimdW wimd
                                        R
                                        R
                                        Reza
                                        @wimd
                                        i use capacitor 4.7 , 100 , 470 uf.
                                        i use 3 type of radio. (usual + 2chip + 2chip+pa+lna)
                                        i use radio adapter. i use regolator 5 to 3.3 module.
                                        but i have problem yet.
                                        i dont test #define MY_RF24_PA_LEVEL RF24_PA_HIGH !
                                        what is code ? and where i can add this ? for gateway or nodes?
                                        this code can solve my problem ? in other means this code can increase power of radio ?
                                        • R Reza
                                          @wimd
                                          wimdW
                                          wimdW
                                          wimd
                                          @Reza yes adding this code increases the power of the radio.
                                          you add this code at the begin of your sketch (both gateway and nodes)
