  3. [Solved] MySensors node not working, Trouble finding parent node
9 Posts 4 Posters 5.8k Views 3 Watching
  • ayoA Offline
    ayoA Offline
    ayo
    wrote on last edited by tekka
    Have been having problem trying to get atleast 2 nodes to work properly and I can't seems to figure out the problem/solution.
    I have the Ardunio Uno as my serial gateway connected to the NRF24L01+ radio with a 10uf cap using the 2.0 GatewaySerial example (unchanged and even changed :)).
    Have checked the pins for continuity and voltage drop where everything seems okay.
    On the sensor node side, I have an Arduino Mega 2560 connected to the same NRF24L01+ 2.4GHz radio powered by an external 3.3V regulator.
    On the sensor node am running the default dust sensors code adding just a modification of static node id of 6 and arduino mega CS and CE radio pins
    What I've tried: Swapping the codes between the 2 arduino boards, trying out another type of the nrf24l01+ radio, moving the node further away from the gateway, moving the node and gateway closer, trying other example similar codes for the sensor node.
    I don't have a controller, so I've hard-coded the node ID and parent id with #define MY_NODE_ID 6 and #define MY_PARENT_NODE_ID 0 for the sensor node not sure if that's necessary for the gateway device.
    At the end am hoping to build my own limited controller powered by the Arduino mega or Due incorporating the Nextion touch Display for User Interface.
    So, when I start the two monitors up within a few seconds of each other (gateway first), here's the output of the gateway:
    Gateway log messages
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:MSG:READ 6-6-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=6)
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;!TSP:MSG:SEND 0-0-6-6 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
    0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
    0;255;3;0;9;TSP:SANCHK:OK
    Output from the Arduino Mega 2560 Sensor node
    NOde Log Message
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=6)
    TSM:FPAR
    TSP:MSG:SEND 6-6-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    This is the code preview of the dust sensor running on the Arduino Mega 2560
    // Optional for Arduino Mega only
    #define MY_RF24_CS_PIN 53
    #define MY_RF24_CE_PIN 40
    //#define MY_PARENT_NODE_IS_STATIC
    #define CHILD_ID_DUST 0
    #define DUST_SENSOR_ANALOG_PIN 1
    unsigned long SLEEP_TIME = 3*1000; // Sleep time between reads (in milliseconds)
    //VARIABLES
    int val = 0;           // variable to store the value coming from the sensor
    float valDUST =0.0;
    float lastDUST =0.0;
    int samplingTime = 280;
    int deltaTime = 40;
    int sleepTime = 9680;
    float voMeasured = 0;
    float calcVoltage = 0;
    float dustDensity = 0;
    MyMessage dustMsg(CHILD_ID_DUST, V_LEVEL);
    void presentation() {
      sendSketchInfo("Dust Sensor", "1.1");
      present(CHILD_ID_DUST, S_DUST);
      uint16_t voMeasured = analogRead(DUST_SENSOR_ANALOG_PIN);// Get DUST value
      // 0 - 5V mapped to 0 - 1023 integer values
      // recover voltage
      calcVoltage = voMeasured * (5.0 / 1024.0);
      // linear eqaution taken from http://www.howmuchsnow.com/arduino/airquality/
      // Chris Nafis (c) 2012
      dustDensity = (0.17 * calcVoltage - 0.1)*1000;
      Serial.print("Raw Signal Value (0-1023): ");
      Serial.print(voMeasured);
      Serial.print(" - Voltage: ");
      Serial.print(calcVoltage);
      Serial.print(" - Dust Density: ");
      Serial.println(dustDensity); // unit: ug/m3
      if (ceil(dustDensity) != lastDUST) {
          send(dustMsg.set((int)ceil(dustDensity)));
          lastDUST = ceil(dustDensity);
      sleep(SLEEP_TIME);
    This is the gateway code
    //#define MY_NODE_ID 1
    //#define MY_PARENT_NODE_ID 0
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    From what I believe is happening is that the sensor node is trying to request for the Parent address I think and the Gateway sees that sensor node request but somehow failed to respond to request. Also am still worried why the sensor node is actually trying to request for the parent id when it has already been hardcoded into the senor code as
    I believe their must be something I am dong wrong here?? or something I am not seeing well.
    Any help to make these all work will be appreciated.
    • ayoA Offline
      ayoA Offline
      ayo
      Okay....So after some trial I finally got the whole system to work now. The problem was from the node device, I re-soldered everything on the node part and it works flawlessly. I have even try adding more nodes to it which works without problem too. Now I will proceed to building my own Arduino based controller.
      Thanks I guess :)
      CurlyWurlyC 1 Reply Last reply
      • ayoA ayo
        Thanks I guess :)
        CurlyWurlyC Offline
        CurlyWurlyC Offline
        CurlyWurly
        wrote on last edited by CurlyWurly
        Hope the following helps someone.
        In my case I wanted to test communication between
        • "GatewaySerial" sketch on one Uno board("Uno1")
        • "Motionsensor" sketch on another Uno board ("Uno2").
        I also wanted to see the "debug" messages without getting confused so I used 2 computers, one for each Uno board.
        In my case, I used a 3.3V rectifier powered by the 5V line on the Uno board and most importantly - YOU MUST SOLDER A CAPACITOR TO EACH RF24L01+ BOARD - if you don't do this, you might have to power the UNO boards separately (to make the radios work OK) - because the power supplied by the USB connection just might not be clean enough - if you put a capacitor on the RF24L01, then you should be OK.
        This is what worked for me:
        1. Prepare both Uno boards ("Uno1" and "Uno2") by loading and running the sketch "ClearEepromConfig"
        2. Connect "Uno1" via USB to computer 1, and before you program it with the sketch "GatewaySerial", make sure you uncomment the DEBUG line (This is so you can use USB serial to see the messages). After programming "Uno1", disconnect it.
        3. Connect "Uno2" via USB to computer 2, and before you program it with sketch "MotionSensor", make sure you:
          • uncomment the DEBUG line (as before)
          • add the line "#define MY_NODE_ID 123" *just before the line "#include <MySensors.h>". *
            N.B. During testing without a "controller" , the presence of MY_NODE_ID in the sensor code solves the CHKID error, but remember to remove this line after testing i.e. before you deploy your sketch for use with a "controller"! In the case above, the sensor will have a node id of 123 and the Gateway will recognise it OK. After programming "Uno2", disconnect it.
        4. Attach Uno1 (GatewaySeriall) to computer 1.
          N.B. IF NO CAP ON YOUR RF24L01+ BOARD, MAKE SURE YOU ALSO POWER "Uno1" SEPARATELY IN ADDITION TO THE USB CONNECTION (this will solves the FPAR error)
          Press "Reset" on Uno1 and look at the serial output output using Putty/Termite/Ide serial bus. You should see about 9 lines (Baud 115200) starting with something like
          "0:255:2:0:9 Starting Gateway" and ending with the "init complete" line
        5. Attach Uno2 ("MotionSensor") to computer 2 and look at the serial output.
          N.B. IF NO CAP ON YOUR RF24L01+ BOARD, MAKE SURE YOU ALSO POWER "Uno2" SEPARATELY IN ADDITION TO THE USB CONNECTION (this solves the FPAR error)
          Press "Reset" on UNO2 and you should see it communicating fine :)
        @EDIT 071016
        Check if your board has a "screen print" error! If it does, you have to move the GPIO4 wire to GPIO5!
        https://twitter.com/bdcatalin/status/663434209265078272
        LOSTL ayoA CurlyWurlyC 3 Replies Last reply
        • CurlyWurlyC CurlyWurly
          @EDIT 071016
          LOSTL Offline
          LOSTL Offline
          LOST
          @CurlyWurly
          How did you power your Uno's separately?
          • LOSTL LOST
            @CurlyWurly
            CurlyWurlyC Offline
            CurlyWurlyC Offline
            CurlyWurly
            @LOST
            In my case I'm using clone Uno boards for testing. you can see there is a separate jack for power (if you don't want to use USB power) .
            "Arduino UNO R3 Compatible DCCduino ATMEGA328 Development Board"
            (use google to find them - £3.30 shipped)
            LOSTL 1 Reply Last reply
              @LOST
              LOSTL Offline
              LOSTL Offline
              LOST
              @CurlyWurly
              OK, thanks!
                @EDIT 071016
                ayoA Offline
                ayoA Offline
                ayo
                Nice one @CurlyWurly
                  @EDIT 071016
                  CurlyWurlyC Offline
                  CurlyWurlyC Offline
                  CurlyWurly
                  @update
                  OK - just following this up with extra info.
                  Previously, I was using radios without the cap.
                  Once a 47 uf cap was added, I didn't need the extra power supplies (the USB power was enough to the Uno clones).
                  Thinking about this now, It wasn't the uno boards, it must have been noise/weak power on my laptop USB.
                  Also, I wasted a lot of time on a bad rf24L01 board ( I think I bust it a while ago by supplying 5v :( ).
                  So, the moral of the story?
                  • If you get a message saying "radio bad" - try another rf24l01
                  • ALWAYS add a capacitor to every rf2401 board
                  • Yuli HertikaY Offline
                    Yuli Hertika
                    I also experienced similar things. And has now been solved thanks to this topic. :smile:
                    http://www.serbacara.com/2015/04/cara-membuat-email-menggunakan-id-luar-negeri.html
                    http://www.serbacara.com/2015/04/cara-membuat-email.html
