  3. Having trouble getting 2.0.1-beta running on Raspberry Pi2 as gateway and controller
2.0raspberryserial gateway
4 Posts 1 Posters 2.4k Views 1 Watching
  • micahM
    micahM
    micah
    I think I've read every topic on this so far and I must have tried every combination.... and I'm stuck, so I'm hoping someone can see my mistake and help me get this sorted
    Here is how I setup MySensors on my Raspberry Pi 2 - I followed the guide to install the NRF24L01+ PA/LNA radio with 4.7µ decoupling (and it previously worked on version 1.4 of mysensors)
    Here is the contents of my mysGateway.cpp
    #include <iostream>
    #include <cstdio>
    #include <unistd.h>
    #define MY_LINUX_CONFIG_FILE "/etc/mysensors.dat"
    #define MY_GATEWAY_MAX_CLIENTS 20
    #define MY_IS_SERIAL_PTY
    #define MY_LINUX_SERIAL_PTY "/dev/ttyMySensorsGateway"
    #define MY_LINUX_SERIAL_GROUPNAME "tty"
    void setup() {}
    void presentation() {}
    void loop() {}
    Here is how I make and then monitor it
    ./configure --my-gateway=serial --my-rf24-pa-level=RF24_PA_LOW
    sudo make all
    sudo make install
    sudo ./examples_linux/mysGateway -d
    Here is my Arduino Node code - It's a simple Uno with a DHT sensor and an NRF24L01+ radio with 4.7µ decoupling
    #define MY_NODE_ID 5
    #define MY_PARENT_NODE_ID 0
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define HUMIDITY_SENSOR_DIGITAL_PIN 5
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    unsigned long pMillis_DHT = 0;
    long sCheck_DHT = 10000;
    bool requestACK = false;
    void setup(){
      metric = getConfig().isMetric;
    void presentation(){
      sendSketchInfo("Just Temperature and Humidity", "0.1");
      present(CHILD_ID_HUM, S_HUM, "DHT22 Humidity", requestACK);
      present(CHILD_ID_TEMP, S_TEMP, "DHT22 Temperature", requestACK);
    void loop(){
      // Check Temp and Humidity
      if (currentMillis - pMillis_DHT >= sCheck_DHT){
        pMillis_DHT = currentMillis;
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          #ifdef MY_DEBUG
          Serial.print("T: ");
          Serial.println(temperature);
        // Fetch humidity from DHT sensor
        if (isnan(humidity)) {
            lastHum = humidity;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
    So far I thought I was doing everything correctly.... but here is my debug output
    On Gateway (Rp2) -The last 6 lines continue to repeat
    mysGateway: Starting gateway...
    mysGateway: Protocol version - 2.0.1-beta
    mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
    mysGateway: TSF:LRT:OK
    mysGateway: TSM:INIT
    mysGateway: TSM:INIT:TSP OK
    mysGateway: TSM:INIT:GW MODE
    mysGateway: TSM:READY
    mysGateway: MCO:REG:NOT NEEDED
    mysGateway: MCO:BGN:STP
    mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
    mysGateway: TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:BC
    mysGateway: TSF:MSG:FPAR REQ,ID=5
    mysGateway: TSF:CKU:OK,FCTRL
    mysGateway: TSF:MSG:GWL OK
    mysGateway: TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysGateway: TSF:MSG:READ,5-5-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    mysGateway: TSF:MSG:PINGED,ID=5,HP=1
    mysGateway: !TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    mysGateway: !TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    On Arduino Node
    0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.0.1-beta
    4 TSM:INIT
    10 TSM:INIT:TSP OK
    12 TSM:INIT:STATID=5
    14 TSF:SID:OK,ID=5
    15 TSM:FPAR
    51 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    504 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    508 TSF:MSG:FPAR PREF
    510 TSF:MSG:FPAR OK,ID=0,D=1
    514 TSM:FPAR:OK
    515 TSM:ID
    516 TSM:ID:OK
    518 TSM:UPL
    553 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    2562 TSM:UPL
    2567 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
    4574 TSM:UPL
    4576 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    6584 TSM:UPL
    6620 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    8628 !TSM:UPL:FAIL
    8629 TSM:FPAR
    8666 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
    10673 !TSM:FPAR:NO REPLY
    10675 TSM:FPAR
    10711 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    12719 !TSM:FPAR:NO REPLY
    12721 TSM:FPAR
    12756 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    14765 !TSM:FPAR:NO REPLY
    14767 TSM:FPAR
    14802 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    So I'm totally confused by these messages... it seems like they are hearing each other but are having trouble communicating properly.
    HELP!!!
    micahM 1 Reply Last reply
    • micahM micah
      #include <iostream>
      #include <cstdio>
      #include <unistd.h>
      void setup() {}
      void loop() {}
      sudo make all
      sudo make install
      #include <DHT.h>
      DHT dht;
      float lastTemp;
      float lastHum;
      void setup(){
      void loop(){
            if (!metric) {
            #ifdef MY_DEBUG
              lastHum = humidity;
              #ifdef MY_DEBUG
      On Arduino Node
      4 TSM:INIT
      10 TSM:INIT:TSP OK
      14 TSF:SID:OK,ID=5
      15 TSM:FPAR
      514 TSM:FPAR:OK
      515 TSM:ID
      516 TSM:ID:OK
      518 TSM:UPL
      2562 TSM:UPL
      4574 TSM:UPL
      6584 TSM:UPL
      8628 !TSM:UPL:FAIL
      8629 TSM:FPAR
      10675 TSM:FPAR
      12721 TSM:FPAR
      14767 TSM:FPAR
      HELP!!!
      micahM
      micahM
      micah
      wrote on last edited by micah
      Other things I've tried....
      1. make sure the connections are good --- CHECK
      2. make sure there is enough distance --- CHECK (about 15 feet)
      3. cleareepron on node and reload code --- CHECK
      4. test with two arduinos -- CHECK (I setup another arduino with a radio as a gateway and it communicated properly with the node described above)
      Also, I'm using a fresh download of the mysensor libraries... from yesterday on both the Rp2 and my arduino
      • micahM micah
        micahM
        micahM
        micah
        Just tried a few more things...
        1. added irq pin 15 to Rp2, then rebuild with the following --- CHECK
        ./configure --my-gateway=serial --my-rf24-pa-level=RF24_PA_LOW --my-rf24-irq-pin=15
        1. soldered decoupling capacitor to both radios (previously they were jammed into the wires) --- CHECK
        2. rechecked all wires --- CHECK
        • micahM micah
          micahM
          micahM
          micah
          UPDATE
          I think it's a problem with the arduino board itself.
          So since my previous posts I've tried multiple radios and I've got a 4 working nodes now:
          1. Mega + NRF24
          2. UNO R3 + NRF24
          3. DCcEle (clone) + NRF24
          4. Nano DCCduino (clone) + NRF24
          Plus the Raspberry Pi 2 as gateway with NRF24L01+ PA/LNA is working.
          So... it seems like it's a problem with that Uno board.... weird.
          I've tried multiple radios (specifically ones that worked on the other boards) and none of them work. Like I said before, the board and the Rp2 seem to be communication but not properly.
          Has anyone ran into a similar problem before?
