  3. Vera
  4. Q: neopixel color change based on relays (lights) in vera
4 Posts 2 Posters 2.3k Views 3 Watching
  • rchampR
    rchampR
    rchamp
    Hi there, i created a very crude sensor that connected to a strip of neopixels. i have it simply fade to white when the light is pressed on and fade to black (off) when pressed off in vera.
    However, i've tried to now create some more "relays" as switches to allow me to trigger different light effects/modes, but i don't know how to create a switch, or case to check "when relay 1 on, color mode 1, relay2 on color 2, etc" It always reads a general 1 or 0, regardless of which light send the command from vera.
    Any ideas on how i can change the code in the receive function to listen to each switch(relay) and then trigger a different condition from there?
    below is my code
     * Version 1.0 - Henrik Ekblad
    #define MY_NODE_ID 12
    #define MY_REPEATER_FEATURE
    #include <Adafruit_NeoPixel.h>
    #define LED_PIN 5
    #define RELAY_1  1  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 4 // Total number of attached relays
    #define NUM_LEDS 60 //60 for full cabinet set
    #define ledFadeTime 5
    #define BRIGHTNESS 100
    Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
    int gamma[] = {
        0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
        0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  1,  1,  1,
        1,  1,  1,  1,  1,  1,  1,  1,  1,  2,  2,  2,  2,  2,  2,  2,
        2,  3,  3,  3,  3,  3,  3,  3,  4,  4,  4,  4,  4,  5,  5,  5,
        5,  6,  6,  6,  6,  7,  7,  7,  7,  8,  8,  8,  9,  9,  9, 10,
       10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
       17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
       25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
       37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
       51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
       69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
       90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
      115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
      144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
      177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
      215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
    void before() {
      strip.setBrightness(BRIGHTNESS);
      strip.begin();
      strip.show(); // Initialize all pixels to 'off'
      sendSketchInfo("Kitchen Island Lights", "1.0");
        present(sensor, S_LIGHT);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
         int showState = message.getBool();
         Serial.print("Newstate variable data:");
         Serial.println(showState);
         if (showState==1) {
            //rgbFadeIn(255, 255, 255, ledFadeTime); // White
            rgbFadeIn(255, 255, 255, ledFadeTime); // orange
          //colorWipe(strip.Color(255, 255, 255), 50);    // White
         }else{
          rgbFadeOut(255,255,255,ledFadeTime);
          //colorWipe(strip.Color(0, 0, 0), 50);    // Black/off
    // Fill the dots one after the other with a color
    void colorWipe(uint32_t c, uint8_t wait) {
      for(uint16_t i=0; i<strip.numPixels(); i++) {
        strip.setPixelColor(i, c);
        strip.show();
        delay(wait);
    void rgbFadeIn(uint8_t red, uint8_t green, uint8_t blue, uint8_t wait) {
      for(uint8_t b = 0; b <255; b++) {
         for(uint8_t i=0; i < strip.numPixels(); i++) {
            strip.setPixelColor(i, red * b/255, green * b/255, blue * b/255);
         strip.show();
         //delay(wait);
    void rgbFadeOut(uint8_t red, uint8_t green, uint8_t blue, uint8_t wait) {
      for(uint8_t b=255; b > 0; b--) {
         for(uint8_t i = 0; i < strip.numPixels(); i++) {
         strip.show();
         //delay(wait);
    • korttomaK
      korttomaK
      korttoma
      I have a RGBW node that also have mode selection and I send the mode from Vera to the node using V_VAR1.
      This is maybe not what you are looking for but maybe it can give you some idea or be helpful someway.
       * Version 1.5 - Modes added
       * Example sketch showing how to control RGBW LED Strip.
       * IMPORTANTE NOTE!!! one of the "radio" pins has been moved from pin 9 to pin 4 because the White is connected to pin 9 because only 3,5,6 and 9 are PWM outputs on Arduino Pro Mini!!!!
       * This code should generate 4 Dimmer devices in Vera so you can control the RED, GREEN, BLUE and WHITE individualy
       arduino Pro mini 5V 16MHz
      #define MY_DEBUG    // Enables debug messages in the serial log
      #define MY_NODE_ID 4
      #define SN "RGBW"
      #define SV "2.0"
      #define MY_RF24_CE_PIN 4    //<-- NOTE!!! changed, the default is 9
      #define MY_RF24_CS_PIN 10    // default is 10
      #include <MyConfig.h>
      #include <LEDFader.h> //library for fading effect https://github.com/jgillick/arduino-LEDFader
      #define REDPIN       3 // pin for red LED
      #define GREENPIN     5 // pin for green LED
      #define BLUEPIN      6 // pin for blue LED
      #define WHITEPIN     9 // pin for white LED
      //#define RF24_PA_LEVEL RF24_PA_MAX
      #define LED_NUM 3 //number of LEDs to fade
      #define DIR_UP 1  //
      #define DIR_DOWN -1
      #define FADE_TIME 2000
      int mode;
      int direction = DIR_UP;   //for fading effect
      unsigned long previousMillis = 0;
      unsigned long currentMillis;
      const long interval = 1000;
      int REDLedState = 0;
      int BLUELedState = 0;
      // 4 LED Faders
      LEDFader leds[LED_NUM] =
        LEDFader(REDPIN),
        LEDFader(GREENPIN),
        LEDFader(BLUEPIN)
      LEDFader REDled;
      MyMessage msgVAR1(REDPIN, V_VAR1);
        pinMode(REDPIN, OUTPUT);
        pinMode(GREENPIN, OUTPUT);
        pinMode(BLUEPIN, OUTPUT);
        pinMode(WHITEPIN, OUTPUT);
        mode = 0;
        REDled = LEDFader(REDPIN);
        Serial.print(" Mode is: ");
        Serial.print(mode);
        //Get Dim values from RAM and write to outputs
        analogWrite(REDPIN, 255 * loadState(REDPIN) / 100);
        analogWrite(GREENPIN, 255 * loadState(GREENPIN) / 100);
        analogWrite(BLUEPIN, 255 * loadState(BLUEPIN) / 100);
        analogWrite(WHITEPIN, 255 * loadState(WHITEPIN) / 100);
        // Request/wait for dimmer status
         gw.request(RED, V_DIMMER);
        gw.process();
         gw.request(GREEN, V_DIMMER);
        gw.process();
         gw.request(BLUE, V_DIMMER);
        gw.process();
         gw.request(WHITE, V_DIMMER);
        gw.process();
        sendSketchInfo(SN, SV);
        present(REDPIN, S_DIMMER);
        present(GREENPIN, S_DIMMER);
        present(BLUEPIN, S_DIMMER);
        present(WHITEPIN, S_DIMMER);
        currentMillis = millis();
        if (mode == 1)
          modeone();
        if (mode == 2)
          modetwo();
        if (mode == 3)
          modethree();
        Serial.print(message.type);
        if (message.type == V_DIMMER)
          uint8_t incomingDimmerStatus = message.getByte();
          // Change Dimmer level
          analogWrite(message.sensor, 255 * incomingDimmerStatus / 100);
          saveState(message.sensor, message.getByte()); //Save Dim value to RAM
          Serial.print("Incoming change for dimmer on pin: ");
          Serial.println(message.sensor);
          Serial.print(" New status: ");
          Serial.println(incomingDimmerStatus);
        if (message.type == V_VAR1)
          uint8_t IncomeingModeStatus = message.getByte();
          mode = IncomeingModeStatus;
          Serial.print(" New Mode recieved: ");
          Serial.println(mode);
          if (mode == 0)
            //Get saved dim values from RAM and write to output
      void modeone()
        //Alarm mode RED BLUE blinking
        Serial.println("Runing Mode 1 sequence");
        if (currentMillis - previousMillis >= interval)
          // save the last time you changed to LEDstrip state
          previousMillis = currentMillis;
          analogWrite(GREENPIN, 0);
          analogWrite(WHITEPIN, 0);
          // if the LEDstrip is RED turn it BLUE and vice-versa:
          if (REDLedState == 0)
            REDLedState = 255;
            BLUELedState = 0;
          else
            REDLedState = 0;
            BLUELedState = 255;
          // set the LEDstrip with the ledState of the variable:
          analogWrite(REDPIN, REDLedState);
          analogWrite(BLUEPIN, BLUELedState);
      void modetwo()
        //Random fading of all except white
        Serial.println("Runing Mode 2 sequence");
        // Update all LEDs and start new fades if any are done
        for (byte i = 0; i < LED_NUM; i++)
          LEDFader *led = &leds[i];
          led->update();
          // This LED is not fading, start a new fade
          if (led->is_fading() == false)
            int duration = random(1000, 3000); // between 1 - 3 seconds
            // Fade Up
            if (led->get_value() == 0)
              byte intensity = random(50, 255);
              led->fade(intensity, duration);
            // Fade Down
            else
              led->fade(0, duration);
      void modethree()
        //Fade up fade down of RED
        Serial.println("Runing Mode 3 sequence");
        REDled.update();
        // LED no longer fading, switch direction
        if (!REDled.is_fading())
          //turn off all other LEDs
          analogWrite(BLUEPIN, 0);
          // Fade down
          if (direction == DIR_UP)
            REDled.fade(0, FADE_TIME);
            direction = DIR_DOWN;
          // Fade up
          else
            REDled.fade(255, FADE_TIME);
            direction = DIR_UP;
      • Tomas
      rchampR 1 Reply Last reply
      • korttomaK korttoma
        #define SN "RGBW"
        #define SV "2.0"
        #define DIR_UP 1  //
        #define DIR_DOWN -1
        int mode;
        // 4 LED Faders
          LEDFader(REDPIN),
          LEDFader(GREENPIN),
          LEDFader(BLUEPIN)
        LEDFader REDled;
          mode = 0;
          Serial.print(mode);
          gw.process();
          gw.process();
          gw.process();
          gw.process();
          if (mode == 1)
            modeone();
          if (mode == 2)
            modetwo();
          if (mode == 3)
            modethree();
            if (mode == 0)
        void modeone()
              REDLedState = 255;
              BLUELedState = 0;
            else
              REDLedState = 0;
              BLUELedState = 255;
        void modetwo()
            led->update();
              // Fade Up
              // Fade Down
              else
        void modethree()
          REDled.update();
            // Fade down
            // Fade up
            else
              direction = DIR_UP;
        rchampR
        rchampR
        rchamp
        @korttoma
        thsnk you for the input. how does the interface look in vera? I'm not too clear on using the V_var options. I do like doing this through a single sensor vs trying to use different.
        I think my biggest problem right now is understanding how to write the code to understand the differences of the messages coming in from vera/the myS gateway
        • korttomaK
          korttomaK
          korttoma
          I actually do not have anything in the interface for setting the mode. I just use a simple lua command:
          luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_1", value=1}, 24)
          • Tomas
