  3. [Solved] Undefined reference to own class used in Arduino sketch .cpp
2 Posts 1 Posters 5.0k Views 1 Watching
  • DerTommD
    DerTommD
    DerTomm
    wrote on last edited by DerTomm
    I just ran into a problem which occures as soon as I include another own class besides MySensors. Here is my code:
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Set blinking period
    #define MY_WITH_LEDS_BLINKING_INVERSE
    // Enable inclusion mode
    #include "Applications/LedHandler.h"
    MyMessage msgNodeTemperature(0, V_TEMP);
    LedHandler* ledHandler;
    unsigned long lastSentTimestamp = 0L;
      ledHandler = new LedHandler();
    void presentation() {
      sendSketchInfo("Demo", "1.0");
      present(0, S_TEMP);  // Board ambient temperature
      if (millis() - lastSentTimestamp > 10000) {
        long int rand = random(0, 30);
        send(msgNodeTemperature.set(rand, 1));
        lastSentTimestamp = millis();
    The problem starts when I create a new object of LedHandler and assign it to the pointer in the setup() method. Then I get the following linker error:
    Compiling .pioenvs\nanoatmega328\src\OpenhabDemo.o
    Linking .pioenvs\nanoatmega328\firmware.elf
    .pioenvs\nanoatmega328\src\OpenhabDemo.o: In function `setup':
    C:\Users\Thomas\.platformio\lib\MySensors_ID548/drivers/ATSHA204/sha256.cpp:70: undefined reference to `LedHandler::LedHandler()'
    collect2.exe: error: ld returned 1 exit status
    *** [.pioenvs\nanoatmega328\firmware.elf] Error 1
     [ERROR] Took 2.97 seconds
    Obviously there is a dependency problem. Can you help me how to get rid of it?
    I use PlatformIO for compilation. OpenhabDemo.cpp is my main Arduino sketch file.
    Here is the header and the class file of the dependend LedHandler:
    #ifndef SRC_APPLICATIONS_LEDHANDLER_H_
    #define SRC_APPLICATIONS_LEDHANDLER_H_
    #include "Actor.h"
    #include "ApplicationHelper.h"
    class LedHandler: public Actor {
    public:
      LedHandler();
      virtual ~LedHandler();
      uint8_t getApplicationPort() const {
        return ApplicationHelper::LED_HANDLER;
      void executeFunction(char* payload);
      void addLed(uint8_t ledPin);
      bool setLedEnabled(uint8_t ledId, bool enabled);
    private:
      uint8_t* managedLeds;
      uint8_t ledCounter;
    #endif /* SRC_APPLICATIONS_LEDHANDLER_H_ */
    LedHandler::LedHandler() {
      ledCounter = 0;
      managedLeds = 0;
    LedHandler::~LedHandler() {
      if (managedLeds != 0) {
        delete managedLeds;
    void LedHandler::executeFunction(char* payload) {
     <deleted>
    void LedHandler::addLed(uint8_t ledPin) {
       <deleted>
    bool LedHandler::setLedEnabled(uint8_t ledId, bool enabled) {
      <deleted>
    • DerTommD
      DerTommD
      DerTomm
      Finally I found a solution for the described situation.
      PlatformIO did not compile all dependend files in a library due to a wrong folder layout. After correcting this it works now.
      For people experiencing the same issue I recommend visiting the connected PlatformIO community thread: https://community.platformio.org/t/pio-does-not-compile-all-included-library-classes-which-leads-to-linker-errors/1034
