  3. RFM69 BinarySwitchSleepSensor not working.
3 Posts 2 Posters 1.2k Views 1 Watching
  • YeitsoY
    YeitsoY
    Yeitso
    Im runnig a BinarySwitchSleepSensor.ino file with some edits to make it work with a RFM69 but alas im not getting what i want
    Here is the code im using (on a Uno with the level adjuster to get 3.3V)
     * Interrupt driven binary switch example with dual interrupts
     * Author: Patrick 'Anticimex' Fallberg
     * Connect one button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
     * one in similar fashion on digital I/O pin 2.
     * This example is designed to fit Arduino Nano/Pro Mini
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define RF69_IRQ_PIN 4
    #define MY_RFM69_FREQUENCY   RF69_868MHZ
    #define SKETCH_NAME "Wall switch"
    #define SKETCH_MAJOR_VER "0"
    #define SKETCH_MINOR_VER "1"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
    #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
    #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
    MyMessage msg(PRIMARY_CHILD_ID, V_LIGHT);
    MyMessage msg2(SECONDARY_CHILD_ID, V_LIGHT);
      // Setup the buttons
      pinMode(PRIMARY_BUTTON_PIN, INPUT);
      pinMode(SECONDARY_BUTTON_PIN, INPUT);
      // Activate internal pull-ups
      digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
      digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
    void presentation() {
      sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
      // Register binary input sensor to sensor_node (they will be created as child devices)
      present(PRIMARY_CHILD_ID, S_LIGHT);
      present(SECONDARY_CHILD_ID, S_LIGHT);
      uint8_t value;
      uint8_t value2;
      static uint8_t sentValue=2;
      static uint8_t sentValue2=2;
      sleep(5);
      Serial.println("Im Awake!");
      value = digitalRead(PRIMARY_BUTTON_PIN);
      if (value != sentValue) {
         // Value has changed from last transmission, send the updated value
         Serial.println(value);
         send(msg.set(value==HIGH ? 1 : 0));
         sentValue = value;
      value2 = digitalRead(SECONDARY_BUTTON_PIN);
      if (value2 != sentValue2) {
         Serial.println(value2);
         send(msg2.set(value2==HIGH ? 1 : 0));
         sentValue2 = value2;
      // Sleep until something happens with the sensor
      Serial.println("Going to sleep until buttons are pressed");
      sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
    When i run this i get this from the Serial monitor, this is including me pressing the buttons connected to pin 2 -> GND and 3 -> GND.
    ti�G�Starting sensor (RRNNA-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    Anyone got an idea on how to fix this?
    • scalzS
      scalzS
      Hello.
      For the moment you have no communication.
      In your define you set RF69_IRQ = D4, but you can't. you need to use D2 or D3, native INT0/1 of Arduino which are compatible with Mysensors.
      So, interruption is not fired and then you cannot get any ACK etc..no parent node etc..
      So comment the line for D2 default, or use D3, should fix your problem i hope.
      • YeitsoY
        YeitsoY
        Yeitso
        wrote on last edited by Yeitso
        aah. Then I will have to run it from a 3.3V pro micro :) need 3 interupt pins for this sketch :)
        Thank you for the answer!
