Arduino Nano Gateway for Vera - PCB link
$14.65 is €10.92 and you can pay with PayPal. No custom charges because it is below €22.
Seems like (not sure!) panelization would be done tomorrow.
$14.95 is about €11, no shipping or custom costs, so also if you just need one board...
Got just an email saying:
Your Nano Gateway V2 copy boards are on the July 31st 2 layer prototype panel.
Once we fill up the panel with other orders it will be sent off to the fabricator. -
What's going on with these?
So I ordered a batch of these from OSHPark and they arrived a couple weeks ago. I've put one together but I'm running into a bit of a problem. Let me start by saying it's almost certainly me. I'm sure the boards and the design are fine. I'm pretty confident the Nano and the radio are fine too because they were working fine on a breadboard.
So when I plug everything together on the PCB the TX and RX and Power lights on the Nano are on solid and stay that way. The middle LED on the PCB gives a brief flash and that's it, nothing else is happening. If I take the Nano out from the board it seems to boot up normally.
So I've looked at my solder job and while not great I don't see any shorts, but I don't quite understand why the TX and RX lights stay solid when connected. If I connect the Nano to my laptop when plugged into the board it doesn't recognize a COM port.
Now I should admit that I did not put to capacitor for the radio onto the board, I just shorted the holes. I wanted to try it first without the cap. because I hadn't needed it on the breadboard. My brain tells me this shouldn't be causing a problem, but maybe it is?
Any suggestions that anyone would have for me to check would be awesome.
Thanks!
Ok so.... things not to do:
- Don't short the holes for the capacitor.
When I thought about this some more I realize it didn't make any sense to do that. I clipped the short and presto the Nano booted properly, no solid TX RX. So I cleaned the holes and put the capacitor in just for kicks and I think everything is working now.
A big thanks to Ross for putting the PCB together it's awesome!
