  3. fail converting 1.5 sketch to 2.0
2 Posts 2 Posters 1.5k Views 2 Watching
  • carlekiC
    carlekiC
    carleki
    Hi guys !
    I'm trying to convert a temperature sketch with CR2032 battery monitoring, and the OneWire without resistor lib (to avoid the 4.7k resistor attached to the Dallas)
    But, it seems I have not well followed the instructions to convert a sketch from 1.5.4 to 2.0, because it won't compile !
    Here is the original sketch (1.5) :
    // avec mesure de la batterie avec Vcc.h
    // ok avec pile CR2032 et docATmega328 8Mhz MYSBootloader et efuse 0x07
    // pour DS18B20 SANS resistance
    // nécessite la lib OneWire : OneWireNoResistor-master.zip
    // boards.txt :
    //proMYSBL.name=docATmega328 8Mhz MYSBootloader
    //proMYSBL.upload.tool=avrdude
    //proMYSBL.upload.protocol=arduino
    //proMYSBL.upload.maximum_size=30720
    //proMYSBL.upload.maximum_data_size=2048
    //proMYSBL.upload.speed=115200
    //proMYSBL.bootloader.tool=avrdude
    //proMYSBL.bootloader.low_fuses=0xE2
    //proMYSBL.bootloader.high_fuses=0xDA
    //proMYSBL.bootloader.extended_fuses=0x07
    //proMYSBL.bootloader.unlock_bits=0x3F
    //proMYSBL.bootloader.lock_bits=0x0F
    //proMYSBL.bootloader.file=MySBootloader/MYSBootloader.hex
    //proMYSBL.build.mcu=atmega328p
    //proMYSBL.build.f_cpu=8000000L
    //proMYSBL.build.board=AVR_UNO
    //proMYSBL.build.core=arduino:arduino
    //proMYSBL.build.variant=arduino:standard
    #include <OneWire.h>
    #include <Vcc.h>
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    #define ONE_WIRE_GND 5
    #define ONE_WIRE_VCC 3
    #define ID_BatPcnt 1
    #define ID_Bat 2
    // 60000 = 1 minute
    // 12000 = 2 minutes
    // 300000 = 5 minutes
    // 600000 = 10 minutes
    #define SLEEP_TIME 300000  // Sleep time between reads (in milliseconds)
    const float VccMin   = 2.3;             // Vcc mini attendu, en Volts.
    const float VccMax   = 3;           // Vcc Maximum attendu, en Volts (2 piles AA neuves)
    const float VccCorrection = 2.52/2.6; // calibration : Vcc mesuré au multimètre / Vcc mesuré par l'Arduino par vcc.Read_Volts() dans sketch 1/2
    Vcc vcc(VccCorrection);
    OneWire oneWire(ONE_WIRE_BUS);
    MyMessage msgBAT_PCNT(ID_BatPcnt,V_VAR1); // on utilise le type V_VAR1 pour le % de charge des piles
    MyMessage msgBAT(ID_Bat,V_VAR2);          // on utilise le type V_VAR2 pour la tension des piles
    uint8_t numSensors = 0;
    boolean metric = true;
    MyMessage msg(0, V_TEMP);
    int oldvalue = 0;
    int node_id = 30; // on donne un ID au node
      // Startup OneWire
    #ifdef ONE_WIRE_VCC
      pinMode(ONE_WIRE_VCC, OUTPUT);
      digitalWrite(ONE_WIRE_VCC, HIGH);
    #ifdef ONE_WIRE_GND
      pinMode(ONE_WIRE_GND, OUTPUT);
      digitalWrite(ONE_WIRE_GND, LOW);
      analogReference(INTERNAL);
      pinMode(BATT_IN_PIN, INPUT);
      pinMode(BATT_VCC_PIN, OUTPUT);
      digitalWrite(BATT_VCC_PIN, LOW);
      sensors.begin();
     // gw.begin();
      gw.begin(NULL, node_id, true);
      gw.sendSketchInfo("Temperature Sensor", "1.0");
      sensors.setWaitForConversion(false);//saves a few mAs per read :-) to debug
      gw.present(ID_BatPcnt, S_CUSTOM);  // type S_CUSTOM pour le capteur "% de charge"
      gw.present(ID_Bat, S_CUSTOM);      // type S_CUSTOM pour le capteur "tension"
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
        gw.present(i, S_TEMP);
      //gw.process();
    // mesure de Vcc
          float v = vcc.Read_Volts();
          // calcul du % de charge batterie
          float p = 100 * ((v - VccMin) / (VccMax - VccMin));
          // On envoie les données des capteurs et de l'état de la batterie au Gateway
          //gw.sendBatteryLevel(p);  // Inutile...
          gw.send(msgBAT_PCNT.set(p, 1)); // 1 décimale
          gw.send(msgBAT.set(v, 3));      // 2 décimales
      gw.sleep(750);//wait for conversion in sleep mode
        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
        gw.send(msg.setSensor(i).set(temperature, 1));
          lastTemperature[i] = temperature;
        //if (lastTemperature[i] != temperature && temperature != -127.00) {
      gw.sleep(SLEEP_TIME);//wake on interrupt or after sleep-time
    Here is my "converted" sketch :
    // boards.txt :
    #include <Vcc.h>
    #define ID_Bat 2
    #define MY_NODE_ID 123
    // 60000 = 1 minute
    //MySensor gw;
    int oldvalue = 0;
    void before()
      sensors.begin();
      // Startup OneWire
    #ifdef ONE_WIRE_VCC
    #ifdef ONE_WIRE_GND
     // gw.begin();
      //gw.begin(NULL, node_id, true);
      sendSketchInfo("TS sR batt", "2.0");
        present(i, S_TEMP);
      //gw.process();
    // mesure de Vcc
    And the error given by the Arduino IDE :
    In file included from /home/carmelo/Arduino/tmp/tmp_tempbattv2/tmp_tempbattv2.ino:28:0:
    /home/carmelo/Arduino/libraries/MySensors/MySensors.h:332:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    exit status 1
    Erreur de compilation pour la carte Arduino Pro or Pro Mini
    • DIYProjectsD
      DIYProjectsD
      DIYProjects
      wrote on last edited by DIYProjects
      Hi Carmelo42. Here your sketch modified. You need to define all MySensors parameters before to include the library. I add 2 variables (BATT_IN_PIN, BATT_VCC_PIN). You need to set Pins. I think, it'll run now. I don't check if the measure of the temperature is correct.
      // boards.txt :
      #include <Vcc.h>
      #define ID_Bat 2
      #define BATT_IN_PIN 1
      #define BATT_VCC_PIN 2
      // 60000 = 1 minute
      //MySensor gw;
      int oldvalue = 0;
      void before()
        sensors.begin();
        // Startup OneWire
      #ifdef ONE_WIRE_VCC
      #ifdef ONE_WIRE_GND
       // gw.begin();
          present(i, S_TEMP);
        //gw.process();
      // mesure de Vcc
          float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
      If you need more info : http://www.diyprojects.io/mysensors-v2-discover-news-migrate-old-sketchs/ (or http://www.projetsdiy.fr/mysensors-version2-decouverte-nouveautes-convertir-sketch/ in french)
