  3. [Solved] W5100 Ethernet Gateway with NRF24 stable MySensors 2.1.0 problem
5 Posts 2 Posters 3.9k Views 2 Watching
  • macieiksM
    macieiksM
    macieiks
    wrote on last edited by tekka
    Hi Guys,
    Today I decided to upgrade my MySenors Arduino UNO with W5100 shield + NRF PA version on it to the newer stable version 2.1.0. Unfortunately I am having problem with establishing connection to Domoticz stable release 3.5877.
    I have run it for quite long time using MySensors beta 2.0.0 (I did it around half year ago) and beta's Domoticz without any issues.
    Problem now is updated ethernet gateway keeps all the time reseting and cannot be seen properly in Domoticz hardware page. When I am checking debug logs I do not see anything suspicious:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.0.5
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;Eth: connect
    IP: 192.168.0.5
    IP: 192.168.0.5
    IP: 192.168.0.5
    IP: 192.168.0.5
    IP: 192.168.0.5
    IP: 192.168.0.5
    IP: 192.168.0.5
    IP: 192.168.0.5
    IP: 192.168.0.5
    IP: 192.168.0.5
    Logs from Domoticz:
    2017-01-05 21:01:18.665 Domoticz V3.5877 (c)2012-2016 GizMoCuz
    2017-01-05 21:01:18.666 Build Hash: 15b013c, Date: 2016-11-10 16:44:33
    2017-01-05 21:01:18.666 System: Raspberry Pi
    2017-01-05 21:01:18.667 Startup Path: /home/pi/domoticz/
    2017-01-05 21:01:18.744 WebServer(HTTP) started on address: :: with port XXXX (hide)
    2017-01-05 21:01:18.754 WebServer(SSL) started on address: :: with port XXXX (hide)
    2017-01-05 21:01:18.757 Proxymanager started.
    2017-01-05 21:01:18.760 TCPServer: shared server started...
    2017-01-05 21:01:18.761 RxQueue: queue worker started...
    2017-01-05 21:01:20.140 Incoming connection from: 192.168.0.1
    2017-01-05 21:01:20.763 EventSystem: reset all events...
    2017-01-05 21:01:20.764 EventSystem: reset all device statuses...
    2017-01-05 21:01:20.765 EventSystem: Started
    2017-01-05 21:01:21.762 MySensors: trying to connect to: 192.168.0.5:5005
    2017-01-05 21:01:22.763 MySensors: connected to: 192.168.0.5:5005
    2017-01-05 21:01:31.765 MySensors: Connection reset!
    2017-01-05 21:01:31.765 TCP: Reconnecting in 30 seconds...
    2017-01-05 21:02:01.769 TCP: Reconnecting...
    2017-01-05 21:02:02.769 MySensors: connected to: 192.168.0.5:5005
    2017-01-05 21:02:11.771 MySensors: Connection reset!
    2017-01-05 21:02:11.771 TCP: Reconnecting in 30 seconds...
    2017-01-05 21:02:41.775 TCP: Reconnecting...
    2017-01-05 21:02:42.776 MySensors: connected to: 192.168.0.5:5005
    2017-01-05 21:02:51.777 MySensors: Connection reset!
    2017-01-05 21:02:51.777 TCP: Reconnecting in 30 seconds...
    2017-01-05 21:03:21.781 TCP: Reconnecting...
    2017-01-05 21:03:22.782 MySensors: connected to: 192.168.0.5:5005
    2017-01-05 21:03:31.783 MySensors: Connection reset!
    2017-01-05 21:03:31.784 TCP: Reconnecting in 30 seconds...
    2017-01-05 21:03:53.281 Incoming connection from: 139.162.34.160
    2017-01-05 21:04:01.788 TCP: Reconnecting...
    2017-01-05 21:04:02.789 MySensors: connected to: 192.168.0.5:5005
    2017-01-05 21:04:11.790 MySensors: Connection reset!
    2017-01-05 21:04:11.790 TCP: Reconnecting in 30 seconds...
    2017-01-05 21:04:41.795 TCP: Reconnecting...
    2017-01-05 21:04:42.796 MySensors: connected to: 192.168.0.5:5005
    2017-01-05 21:04:51.797 MySensors: Connection reset!
    2017-01-05 21:04:51.797 TCP: Reconnecting in 30 seconds...
    2017-01-05 21:05:21.801 TCP: Reconnecting...
    2017-01-05 21:05:22.802 MySensors: connected to: 192.168.0.5:5005
    2017-01-05 21:05:31.803 MySensors: Connection reset!
    2017-01-05 21:05:31.804 TCP: Reconnecting in 30 seconds...
    2017-01-05 21:06:01.808 TCP: Reconnecting...
    2017-01-05 21:06:02.808 MySensors: connected to: 192.168.0.5:5005
    2017-01-05 21:06:11.810 MySensors: Connection reset!
    2017-01-05 21:06:11.810 TCP: Reconnecting in 30 seconds...
    2017-01-05 21:06:41.814 TCP: Reconnecting...
    2017-01-05 21:06:41.815 MySensors: connected to: 192.168.0.5:5005
    2017-01-05 21:06:51.816 MySensors: Connection reset!
    2017-01-05 21:06:51.817 TCP: Reconnecting in 30 seconds...
    2017-01-05 21:07:21.820 TCP: Reconnecting...
    2017-01-05 21:07:22.821 MySensors: connected to: 192.168.0.5:5005
    2017-01-05 21:07:31.823 MySensors: Connection reset!
    2017-01-05 21:07:31.823 TCP: Reconnecting in 30 seconds...
    As you can see it keeps all the time reseting. When I see output in Domoticz "MySensors: Connection reset!" I can see Arduino Uno is being reseted at this time (from Serial Monitor output)
    I really tried to install beta 2.2.0 and also 2.0.0 from mysensors page on both stable and beta domoticz and still it is getting same error. Did anyone face any issue like this before?
    To add, W5100 is normally pingable from Raspberry:
    pi@raspberrypi ~/domoticz $ ping 192.168.0.5
    PING 192.168.0.5 (192.168.0.5) 56(84) bytes of data.
    64 bytes from 192.168.0.5: icmp_seq=1 ttl=128 time=0.351 ms
    64 bytes from 192.168.0.5: icmp_seq=2 ttl=128 time=0.236 ms
    64 bytes from 192.168.0.5: icmp_seq=3 ttl=128 time=0.274 ms
    ^C
    --- 192.168.0.5 ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 1998ms
    rtt min/avg/max/mdev = 0.236/0.287/0.351/0.047 ms
    Code for W5100 is default (just IP and port changed):
     * Version 1.0 - Henrik EKblad
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
     * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192, 168, 0, 5   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5005
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    Thank you in advance for help :)
    RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
    RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
    RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
    T 1 Reply Last reply
    • macieiksM macieiks
      Hi Guys,
      IP: 192.168.0.5
      IP: 192.168.0.5
      IP: 192.168.0.5
      IP: 192.168.0.5
      IP: 192.168.0.5
      IP: 192.168.0.5
      IP: 192.168.0.5
      IP: 192.168.0.5
      IP: 192.168.0.5
      IP: 192.168.0.5
      IP: 192.168.0.5
      Logs from Domoticz:
      ^C
       * LED purposes:
      #define MY_SOFTSPI
      // Enable to UDP
      tboha
      @macieiks I got an identical Error last week after upgrading to Arduino 1.8.0. Solution is:
      https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/4
      simple: If you are running AVR board defs > 1.6.11, downgrade to 1.6.11 and the issue should be solved. (from @tekka).
      If someone is interested: same Error for ENC28J60 Ethernet module, resolved with downgrading board definitions to 1.6.11.
      macieiksM 1 Reply Last reply
      • T tboha
        macieiksM
        macieiksM
        macieiks
        wrote on last edited by macieiks
        @tboha
        Hi, thank you for the update
        EDIT::
        Yes, I downgraded AVR boards to lower version and its working. Thanks ! you saved me tons of hours :D
          @tboha
          EDIT::
          tboha
          @macieiks
          for the sake of completeness - you do not have to downgrade your complete Arduino IDE, just "tweak" boards definitions. Board versions are not necessarily numbered according to Arduino version.
          Sorry - I couldn´t get Enlish version at speed.
          I probably reads "Tools"->"Board"->"Boardmanager"
          I got 1.6.11 installed- so it is not available in drop down list.
          Choose your desired version, hit "Install", wait a fairly long time and you are done.
          • T tboha
            @macieiks
            macieiksM
            macieiksM
            macieiks
            @tboha
            Yes I got it, Thank you very much for help! :)
