  3. Beehive monitoring using Ceech board
7 Posts 2 Posters 2.5k Views 2 Watching
  • JodailleJ
    JodailleJ
    Jodaille
    wrote on last edited by Jodaille
    I am using Ceech board (LTC4079) with 6v pannel
    I have tried to adjust potentiometer but I am not sure to well understand the values :
    Vcc = 3.28V
    Charge current = 0.00mA
    Solar cell voltage = 5.56V
    Battery voltage = 4.03V
    CHRG = 542
    I read CHRG = 542 but Charge current = 0.00mA
    If I turn a bit the portentiometer I have :
    Vcc = 3.28V
    Charge current = 79.91mA
    Solar cell voltage = 4.95V
    Battery voltage = 4.07V
    CHRG = 0
    What I understand is that charge current come from solar cell and CHRG is amount send to battery, am I right ?
    Is it normal to nat have a positive value in both ?
    ps: for now with full wires (power and network) it looks like http://jodaille.org/snapshots/
    a daily timelapse and meteo/temperature sensors
    • C
      C
      ceech
      Charge current is the current that flows into the battery. And the CHRG signal indicates when charging occurs. CHRG is an active low signal. It means that charging works when this signal is 0 or close to zero.
      Here is an explanation on how the trimmer works:
      The viper is on the red line. Turn it counterclockwise till it reaches the 5V mark. This is a 5V setting. The other way around is for 18V solar panel setting.
      JodailleJ 1 Reply Last reply
      • C ceech
        JodailleJ
        JodailleJ
        Jodaille
        Hello Ceech,
        thank you for your answer,
        So I think I have turned the trimmer too much :-)
        Your board is very useful, it is very nice to be able to monitor level battery and so on !
        • JodailleJ
          JodailleJ
          Jodaille
          now it is charging \o/
          Vcc = 3.28V
          Charge current = 71.65mA
          Solar cell voltage = 4.71V
          Battery voltage = 3.97V
          CHRG = 0
          it was Battery voltage = 3.90V few minutes ago
          • JodailleJ
            JodailleJ
            Jodaille
            we have successfully transmitted data over 233 m (apiary to labo) with RFM69.
            • JodailleJ
              JodailleJ
              Jodaille
              Hello Ceech,
              your board is used with six ds18b20 sensors to monitor a hive:
              http://www.dheaf.plus.com/monitor/monitor_v2.htm
              • C
                C
                ceech
                Great work.
