  3. Prevent Relay from triggering on power loss or broker reboot
22 Posts 8 Posters 10.3k Views 8 Watching
  • D Offline
    djzang
    I'm wondering if its not your code that is bringing the PIN high momentarily during boot up but the device or boot loader itself. Try flashing it with blank code and power cycle it and see if it triggers the relay still. If it does then you may need to put a pullup resistor on the pin to prevent it from happening.
    • rhuehnR rhuehn
      Hey guys! Thanks so very much for all the great comments. I haven't replied in a few days as I wanted to go back to the drawing board..... I didn't like that sketch, the sleep functions, etc etc.... It didn't also make sense clearly based on everyone's feedback ( Sorry I am just getting started with IDE... ) So, based on that, I've come up with the following, and if you could comment, modify where I messed up, it would be greatly appreciated. This sketch seems to work, and keep state on power LOSS. There's a relay for the garage door ( trigger, PIN 4 ), a reed switch to detect if the door is open or closed ( PIN 2 ), a DHT for Temp / Humidity ( PIN 7 ), and a PIR ( PIN 3 ) for motion activated events. Below is the sketch, and would really appreciate any great feedback.
      Thanks again!
      #define MY_REPEATER_FEATURE
      #define MY_NODE_ID 50
      #include <Bounce2.h>
      #include <DHT.h>
      #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      #define TOGGLE_INTERVAL 350
      #define CHILD_ID_SW 2
      #define BUTTON_PIN  2  // Arduino Digital I/O pin for button/reed switch
      float lastTemp;
      float lastHum;
      uint8_t nNoUpdatesTemp;
      uint8_t nNoUpdatesHum;
      bool metric = true;
      #define CHILD_ID_HUM 10
      #define CHILD_ID_TEMP 11
      #define HUMIDITY_SENSOR_DIGITAL_PIN 7
      #define SENSOR_TEMP_OFFSET -1
      #define CHILD_ID_PIR 3
      #define PIR_PIN 3
      byte StatePIR=0;
      byte oldStatePIR=0;
      Bounce debouncer = Bounce();
      int oldValue=-1;
      MyMessage msgSw(CHILD_ID_SW,V_TRIPPED);
      MyMessage msgHum(CHILD_ID_HUM, V_HUM); // 1
      MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); // 0
      MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
      DHT dht;
      void before()
              pinMode(pin, OUTPUT);
        dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN); // set data pin of DHT sensor
        pinMode(PIR_PIN, INPUT_PULLUP);
        // Setup the button
        pinMode(BUTTON_PIN,INPUT);
        // Activate internal pull-up
        debouncer.attach(BUTTON_PIN);
        debouncer.interval(5);
          sendSketchInfo("Garage Multi Sensor", "1.0");
              present(sensor, S_BINARY);
              present(CHILD_ID_SW, S_DOOR);
              present(CHILD_ID_HUM, S_HUM);
              present(CHILD_ID_PIR, S_MOTION);
              metric = getConfig().isMetric;
      StatePIR=digitalRead(PIR_PIN);
        if (StatePIR != oldStatePIR) {
          oldStatePIR=StatePIR;
          send(msgPir.set(StatePIR ? "ON" : "OFF"));
        dht.readSensor(true);
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          // Reset no updates counter
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          Serial.print("T: ");
          Serial.println(temperature);
        } else {
          nNoUpdatesTemp++;
        if (isnan(humidity)) {
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
        } else {
          nNoUpdatesHum++;
        debouncer.update();
        // Get the update value
        int value = debouncer.read();
        if (value != oldValue) {
           // Send in the new value
           send(msgSw.set(value==HIGH ? 1 : 0));
           oldValue = value;
          if (message.type==V_STATUS) {
              // Change relay state
              //Keep the relay on for the amount of time defined by TOGGLE_INTERVAL
              delay( TOGGLE_INTERVAL );
              digitalWrite( RELAY_1, RELAY_OFF );
              // Store state in eeprom
              // Write some debug info
              Serial.print(message.sensor);
      B Offline
      B Offline
      Ben Andrewes
      @rhuehn I know this is an old post but I had a similar issue which I solved by inserting a line in my sketch to pull the pin high before setting it as output
        digitalWrite(RELAY_1_PIN , HIGH);  //stops relays cycling state during boot
        digitalWrite(RELAY_2_PIN , HIGH);  //stops relays cycling state during boot
        pinMode(RELAY_1_PIN , OUTPUT);
        pinMode(RELAY_2_PIN , OUTPUT);
