  3. Pressure Sensor - minimum detectable pressure change
3 Posts 2 Posters 1.6k Views 3 Watching
  • jimbolayaJ
    jimbolayaJ
    jimbolaya
    I'm working on a sensor to give me the pressure drop across my furnace filter. From what I'm reading I can expect filter inlet and outlet pressures of around 1 inch of water or 2.5 hPa. The sensor spec sheet lists accuracies of around +- 1 hPa. I'm concerned the error may be more than the pressures changes I'm trying to measure. Anyone have any experience with this sensor? Any thoughts? Thx!
    Jim
    • F
      F
      flopp
      wrote on last edited by flopp
      Are we talking about BMP280?
      Specs for BMP280
      • jimbolayaJ
        jimbolayaJ
        jimbolaya
        Oops. My bad. I thought I listed the sensor. I was looking at the BMP180 on the atmospheric pressure sensor build page. It looks like the BMP280 also has a +- 1 hPa absolute accuracy. Maybe I could take advantage of the better relative accuracy and sample pressure when the furnace is both running and not. The not running pressure would give me a good baseline.
        Jim
