  3. JULA motion LED hack
6 Posts 3 Posters 3.8k Views 3 Watching
  • EfflonE
    EfflonE
    Efflon
    wrote on last edited by Efflon
    I found a cheap (€5) battery powered motion sensor LED at jula.se that I couldn't resist to pry open.
    Looking at the PCB I found the standard BISS0001 used in most PIR motion sensors.
    I de-soldered LED resistor and the resistor connecting the IC with the transistor causing the LED to shine. The bottom orange cable is the sensor output going HIGH when motion is detected. In this sensor trigger time was set to 25s by a 10K resistor at R2, I have replaced it with a short=0 to only have part of a second output (look at the datasheet for more details). The photo resistor is also removed unless you only want night triggering. Pin 9 on the IC, blue circle, is used to enable/disable the sensor. I have left it untouched, for now.
    Since it's powered by 3xAAA=4,5V I take 3V from the top right VDC regulator (?).
    It all fits just fine in the box..ehh
    The example motion sketch have been used as base for my code. I have made some small changes. I disable motion detection for 30min after first trigger. I sleep for 6hours before reporting battery level. Interrupt is triggered by RISING.
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    // Enable debug prints
    #include <Vcc.h>
    const float VccMin        = 2.0*0.6;  // Minimum expected Vcc level, in Volts. Example for 2xAA Alkaline.
    const float VccMax        = 2.0*1.5;  // Maximum expected Vcc level, in Volts. Example for 2xAA Alkaline.
    const float VccCorrection = 1.0/1.0;  // Measured Vcc by multimeter divided by reported Vcc
    Vcc vcc(VccCorrection);
                            //  h      m      s       ms
    unsigned long SLEEP_TIME =  6UL * 60UL * 60UL * 1000UL; // Sleep time between reports (in milliseconds)
    unsigned long DISABLE_TIME =      30UL * 60UL * 1000UL; // Time until sensor is re-enabled after triggering (in milliseconds)
    #define MOTION_SENSOR_PIN 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define CHILD_ID 0   // Id of the sensor child
    // Initialize motion message
    int wakeup = 0;
      pinMode(MOTION_SENSOR_PIN, INPUT);      // sets the motion sensor digital pin as input
      sendSketchInfo("Motion Sensor", "1.0");
      present(CHILD_ID, S_MOTION, "Motion tripped", true);
      // Read digital motion value
      bool tripped = digitalRead(MOTION_SENSOR_PIN) == HIGH;
      if (tripped)
        send(msg.set(1));  // Send tripped value to gw
        send(msg.set(0));  // Send tripped value to gw
        // Ignore any motion for a set time
        sleep(DISABLE_TIME);
      // Send battery level when waking up from long sleep
      if (wakeup == -1)
        uint8_t batteryPcnt = static_cast<uint8_t>(0.5 + vcc.Read_Perc(VccMin, VccMax));
        // Send battery level, used as heartbeat of the sensor
      wakeup = sleep(digitalPinToInterrupt(MOTION_SENSOR_PIN), RISING, SLEEP_TIME);
    • pansenP
      pansenP
      pansen
      Soooo what does it do?
      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
      • EfflonE
        EfflonE
        Efflon
        Ehh, detect motion :smiley:
        • pansenP
          pansenP
          pansen
          Ohh haha ok now I get it.
          Nice!
          • engyE
            engyE
            engy
            Cool! What is the consumption of the node and how long batteries last?
            EfflonE 1 Reply Last reply
            • engyE engy
              EfflonE
              EfflonE
              Efflon
              @engy I never let the sensor stay for to long since it was so ugly and seemed to drain my batteries fast. What I eventually did was restore it to its original state with a light and light-sensor and powered with a usb charger. Now when motion is detected an event with the light intensity is sent to my HASS server, who then decides if the light should turn on or not....
