  3. Question about powering the nrf24l01+ with atmega328ppu ?
5 Posts 2 Posters 1.7k Views 3 Watching
  • L
    L
    linkos
    Hi, i'm new to mysensors and i'm trying to build a classic temp/humidity node with an atmega328p (with arduinolilypad 8mhz bootloader) + dht22 + nrf24l01. I want to run the whole module on a cr2032 battery.
    My node is actually running really great, but I have a question about the right way to power the nrf24l01.
    Actually my nrf24l01 module is directly connected to the battery + and gnd, is it the right way to do ? I presume that the nrf does not enter sleep mode when i put my atmega in sleep mode if it's allways connect to + and GND ?
    I'm sorry if my english is not very good it's not my primary language.
    F 1 Reply Last reply
    • L linkos
      F
      F
      flopp
      @linkos
      You have connected it correct. MySensors code will put the nRF to sleep.
      • L
        L
        linkos
        ok thanks for your answer, so it will be in sleep mode even if it's directly powered via the battery ?
        i'm sorry but I've another question ^^ how can I measure the total amperage of my module ? i've try with my multimeter (on mA caliber or uA caliber) in serie but it show me 0 uA :(
        I want to try with a shunt resistor but I don"t know how to calculate the good value of the resistor (my module is 3v powered with cr2032)
        sorry for that newbies questions ^^
        • L linkos
          F
          F
          flopp
          @linkos said in Question about powering the nrf24l01+ with atmega328ppu ?:
          Yes it will go to sleep.
          if you connect it in serie then it should show you mA. Try to measure a not battery powered arduino and see if you can measure the mA
          • L
            L
            linkos
            thanks for your answer ;)
            it's a good news because i've allready made the pcb for the module ^^
