  3. relay not changing state when compiling two working sketchs
3 Posts 2 Posters 1.1k Views 3 Watching
  • T Offline
    T Offline
    Ticupolu
    Hi all! i'm having problems with compiling two of my working sketches i am fairly new to this so it might be stupid mistake. Here is the thing one of my sketch is for 4x relay whith 4x button and the other is for dht22 and dallas temp sensor...this for a chicken coop im working on. The problem is that once compiled the relay doesn't change state when switching on and off in openhab2. I spent 2 days trying to figure out what is wrong...here is the code hope somebody can help me with that thanks!! in advance :chicken:
    // MySensor Debug
    // Enables repeater functionality (relays messages from other nodes)
    //#define MY_REPEATER_FEATURE
    #define MY_NODE_ID 50
    #define MY_RF24_CE_PIN 40
    #define MY_RF24_CS_PIN 53
    #define MY_RF24_MOSI_PIN 51
    #define MY_RF24_MISO_PIN 50
    #define MY_RF24_SCK_PIN 52
    // Comment line below if you don't want to use the temperature sensor
    #define USE_TEMP_SENSOR
    #include <Bounce2.h>
    #include <DHT.h>
    #include <OneWire.h>
    #define RELAY_PIN    22  // Arduino Digital I/O pin number for relay
    #define RELAY_PIN_2  23
    #define RELAY_PIN_3  24
    #define RELAY_PIN_4  25
    #define BUTTON_PIN   9  // Arduino Digital I/O pin number for button
    #define BUTTON_PIN_2 10
    #define BUTTON_PIN_3 11
    #define BUTTON_PIN_4 12
    #define CHILD_ID 11 // Id of the sensor child for 1st relay
    #define CHILD_ID_2 12 // Id of the sensor child for 2nd relay
    #define CHILD_ID_3 13
    #define CHILD_ID_4 14
    #define CHILD_ID_HUM1 6
    #define CHILD_ID_TEMP1 7
    #define MAX_ATTACHED_DS18B20 1
    // Relay status
    #define RELAY_ON 1
    #define RELAY_OFF 0
    // Source of state change (used when printing debug information)
    #define CHANGE_STATE_SOURCE_RADIO 0
    #define CHANGE_STATE_SOURCE_SWITCH 1
    #define DHT1_DATA_PIN 2
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 10000;
    static const uint8_t FORCE_UPDATE_N_READS = 100000;
    float lastTemp1;
    float lastHum1;
    uint8_t nNoUpdatesTemp1;
    uint8_t nNoUpdatesHum1;
    bool metric = true;
    int numSensors=0;
    bool receivedConfig = false;
    Bounce debouncer = Bounce();
    int oldValue;
    bool state;
    Bounce debouncer2 = Bounce();
    int oldValue2;
    bool state2;
    Bounce debouncer3 = Bounce();
    int oldValue3;
    bool state3;
    Bounce debouncer4 = Bounce();
    int oldValue4;
    bool state4;
    MyMessage msg(CHILD_ID, V_LIGHT);
    MyMessage msg2(CHILD_ID_2, V_LIGHT);
    MyMessage msg3(CHILD_ID_3, V_LIGHT);
    MyMessage msg4(CHILD_ID_4, V_LIGHT);
    MyMessage msgDallas(0,V_TEMP);
    MyMessage msgHum1(CHILD_ID_HUM1, V_HUM);
    MyMessage msgTemp1(CHILD_ID_TEMP1, V_TEMP);
    DHT dht;
    void before()
      sensors.begin();
    void presentation() {
      sendSketchInfo("Double Relay & Button", "0.2");
      present(CHILD_ID, S_LIGHT);
      present(CHILD_ID_2, S_LIGHT);
      present(CHILD_ID_3, S_LIGHT);
      present(CHILD_ID_4, S_LIGHT);
      sendSketchInfo("DHTandDallas", "1.1");
      present(CHILD_ID_HUM1, S_HUM);
      present(CHILD_ID_TEMP1, S_TEMP);
    //numSensors = 1;
         present(i, S_TEMP);
      // Setup the button
      pinMode(BUTTON_PIN, INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN, HIGH);
      // Setup the button
      pinMode(BUTTON_PIN_2, INPUT);
      digitalWrite(BUTTON_PIN_2, HIGH);
       // Setup the button
      pinMode(BUTTON_PIN_3, INPUT);
      digitalWrite(BUTTON_PIN_3, HIGH);
       // Setup the button
      pinMode(BUTTON_PIN_4, INPUT);
      digitalWrite(BUTTON_PIN_4, HIGH);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      debouncer2.attach(BUTTON_PIN_2);
      debouncer2.interval(5);
      debouncer3.attach(BUTTON_PIN_3);
      debouncer3.interval(5);
      debouncer4.attach(BUTTON_PIN_4);
      debouncer4.interval(5);
      // Set the initial values of oldValue/oldValue2 variables from status of physical switches
      //  if this is not done the loop() will detect status change and switch the relays on or off
      debouncer.update();
      debouncer2.update();
      debouncer3.update();
      debouncer4.update();
      oldValue = debouncer.read();
      oldValue2 = debouncer2.read();
      oldValue3 = debouncer3.read();
      oldValue4 = debouncer4.read();
      setRelayState(RELAY_PIN, RELAY_OFF);
      pinMode(RELAY_PIN, OUTPUT);
      digitalWrite(RELAY_PIN_2, RELAY_OFF);
      pinMode(RELAY_PIN_2, OUTPUT);
       digitalWrite(RELAY_PIN_3, RELAY_OFF);
      pinMode(RELAY_PIN_3, OUTPUT);
       digitalWrite(RELAY_PIN_4, RELAY_OFF);
      pinMode(RELAY_PIN_4, OUTPUT);
      state = loadState(CHILD_ID);
      setRelayState(RELAY_PIN, state);
     state2 = loadState(CHILD_ID_2);
      setRelayState(RELAY_PIN_2, state2);
    state3 = loadState(CHILD_ID_3);
      setRelayState(RELAY_PIN_3, state3);
    state4 = loadState(CHILD_ID_4);
      setRelayState(RELAY_PIN_4, state4);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
         //Only send data if temperature has changed and no error
        //#if COMPARE_TEMP == 1
       // if (lastTemperature[i] != temperature && temperature != -127.00 && temperature != 85.00) {
       // #else
       // if (temperature != -127.00 && temperature != 85.00) {
        //#endif
          send(msgDallas.setSensor(i).set(temperature,1));
          Serial.print("Dallas");
          Serial.println(i);
          Serial.println(" :");
        Serial.println(temperature);
      sleep(UPDATE_INTERVAL);
      dht.setup(DHT1_DATA_PIN); // set data pin of DHT1 sensor
      dht.readSensor(true);
      float temperature1 = dht.getTemperature();
      if (isnan(temperature1)) {
      } else if (temperature1 != lastTemp1 || nNoUpdatesTemp1 == FORCE_UPDATE_N_READS) {
        lastTemp1 = temperature1;
        if (!metric) {
          temperature1 = dht.toFahrenheit(temperature1);
        // Reset no updates counter
        nNoUpdatesTemp1 = 0;
        temperature1 += SENSOR_TEMP_OFFSET;
        send(msgTemp1.set(temperature1, 1));
        //#ifdef MY_DEBUG
        //Serial.print("T1: ");
        //Serial.println(temperature1);
        //#endif
      } else {
        nNoUpdatesTemp1++;
      float humidity1 = dht.getHumidity();
      if (isnan(humidity1)) {
      } else if (humidity1 != lastHum1 || nNoUpdatesHum1 == FORCE_UPDATE_N_READS) {
        lastHum1 = humidity1;
        nNoUpdatesHum1 = 0;
        send(msgHum1.set(humidity1, 1));
        #ifdef MY_DEBUG
        Serial.print("H1: ");
        Serial.println(humidity1);
      } else {
        nNoUpdatesHum1++;
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      int value2 = debouncer2.read();
      int value3 = debouncer3.read();
      int value4 = debouncer4.read();
      if (value != oldValue) {
        send(msg.set(state ? false : true), true); // Send new state and request ack back
        // Write some debug info
        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID, value);
      oldValue = value;
      if (value2 != oldValue2) {
        send(msg2.set(state2 ? false : true), true); // Send new state and request ack back
        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_2, value2);
      oldValue2 = value2;
     if (value3 != oldValue3) {
        send(msg3.set(state3 ? false : true), true); // Send new state and request ack back
        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_3, value3);
      oldValue3 = value3;
      if (value4 != oldValue4) {
        send(msg4.set(state4 ? false : true), true); // Send new state and request ack back
        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_4, value4);
      oldValue4 = value4;
      if (message.isAck()) {
    #ifdef MY_DEBUG
        Serial.println(F("This is an ack from gateway"));
      else if (message.type == V_LIGHT && message.sensor == CHILD_ID) {
        // Change relay state
        state = message.getBool();
        // Store state in eeprom
        saveState(CHILD_ID, state);
        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID, state);
      else if (message.type == V_LIGHT && message.sensor == CHILD_ID_2) {
        state2 = message.getBool();
        saveState(CHILD_ID_2, state2);
        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_2, state2);
      else if (message.type == V_LIGHT && message.sensor == CHILD_ID_3) {
       state3 = message.getBool();
        saveState(CHILD_ID_3, state3);
        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_3, state3);
      else if (message.type == V_LIGHT && message.sensor == CHILD_ID_4) {
        state4 = message.getBool();
        saveState(CHILD_ID_4, state4);
        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_4, state4);
    // Set status of a relay pin
    void setRelayState(byte relayPin, bool value) {
      digitalWrite(relayPin, value ? RELAY_ON : RELAY_OFF);
    // Print debug info, centralized in one place to minimize memory usage and have only one #ifdef MY_DEBUG for all state change messages
    void printStateChangedDebug(int source, int sensorID, bool value) {
    #ifdef MY_DEBUG
      Serial.print(F("Sensor value changed, source="));
      Serial.print(source == CHANGE_STATE_SOURCE_RADIO ? F("Radio") : F("Physical switch"));
      Serial.print(F(", Sensor="));
      Serial.print(sensorID);
      Serial.print(F(", New status: "));
      Serial.println(value);
    • K Offline
      K Offline
      korttoma
      Try changin all your sleep() to wait(). Your node can not receive commans while sleeping.
      • Tomas
      • T Offline
        T Offline
        Ticupolu
        Thank you for quick response works perfect :thumbsup:
