  3. 💬 Raspberry Pi gateway interface
domoticzraspberrygatewaynrf24l01+
6 Posts 6 Posters 2.0k Views 5 Watching
  • openhardware.ioO Offline
    openhardware.io
    https://www.openhardware.io/view/372/Raspberry-Pi-gateway-interface
    • hhaliboH Offline
      hhaliboH Offline
      hhalibo
      Awesome works! Really want to have one!THX!
      • pihomeP Offline
        pihomeP Offline
        pihome
        @GertSanders,
        sorry may be this is basic question, how this gateway is presented to raspberry pi? as a serial gateway?
        PiHome - Smart Heating Control
          It is up to you, as the RPI gw can be set either serial/ethernet/mqtt
          • pihomeP pihome
            @GertSanders,
            GertSandersG Offline
            GertSanders
            @pihome I have now used it first as a serial gateway. Now I'm using it as a ethernet gateway (since Raspberry gateway code is now included in MySensors build).
            • A Offline
              A Offline
              alphaHotel
              wrote on last edited by alphaHotel
              Hi @GertSanders,
              Do you happen to still have the Eagle project files from version 3 you created and shared on OSH Park? I'd like to add a set of pads for the mini smd version of the NRF24L01. If not, I'll just use the version 2 files from openhardware.io and try my best to recreate the changes you made between them.
              Kind regards,
              AH
