  3. Mini Pro + DHT12 + NRF24L01+ SMD
12 Posts 3 Posters 3.7k Views 3 Watching
  • michlb1982M
    michlb1982M
    michlb1982
    wrote on last edited by michlb1982
    Hi
    I ordered the new DHT12 and the NRF24L01+ SMD and tried to build an Humidity sensor but it istn't working..
    i'm not a programmer so i don't no where the problem is...
    i testet the DHT12 with this code and it works...
    //Test library for DHT12 sensors.
    //Write by Bobadas.
    #include <DHT12.h>
    #include <Wire.h>     //The DHT12 uses I2C comunication.
    DHT12 dht12;          //Preset scale CELSIUS and ID 0x5c.
    For configuration library:
    DHT12 dht12("Scale temperature","ID device for I2C");
    On "Scale temperature" you can select the preset scale:
    CELSIUS, FAHRENHEIT or KELVIN.
    And on "ID device", you can put ID sensor, on DHT12
    normally is 0x5c.
    Examples:
      DHT12 dht12;
    The preset scale is CELSIUS and ID is 0x5c.
      DHT12 dht12(KELVIN);
    the preset scale is KELVIN and ID is 0x5c.
      DHT12 dht12(FAHRENHEIT,0x53);
    The preset scale is FAHRENHEIT and ID is 0x53.
      Wire.begin();
      Serial.begin(9600);
      Serial.println("Prueba de libreria DHT12:");
      Serial.print("Temperatura: ");
      Serial.print(dht12.readTemperature());
    //Read temperature with preset scale.
      Serial.print("*C  Humedad: ");
      Serial.print(dht12.readHumidity());
    //Read humidity.
      Serial.println("%RH");
      Serial.print(dht12.readTemperature(FAHRENHEIT));
    //Read temperature as forced fahrenheit.
      Serial.println("*F");
      Serial.print(dht12.readTemperature(KELVIN));
    //Read termperature as forced kelvin.
      Serial.println("*K");
      delay(5000);
    if it delivers the values 0.01, 0.02 or 0.03, you are
    giving us the error that has had in reading:
    0.01: DHT12 is not connected or the ID does not exist.
    0.02: There have been a problem with communication.
    0.03: Checksum error (bad connections, check the wires).
    and i wired the nrf like in the tutorial but i think there is something wrong... i used this for the wireing
    and i used the 3,3V regulator..
    then i changed the code like this:
     * Version 1.0: Michael Berger
     * Version 1.1 - 2017-03-31: Converted to MySensors v2.0 and added various improvements - Torben Woltjen (mozzbozz)
     * sensor using a DHT12
    // Enable debug prints
    #include <DHT12.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      Wire.begin();
      Serial.begin(9600);
    //  dht12.readSensor(true);
      float temperature = dht12.readTemperature();
      Serial.print("Temp: ");
      if (isnan(temperature)) {
        lastTemp = temperature;
    //    if (!metric) {
    //      temperature = dht12.toFahrenheit(temperature);
        // Reset no updates counter
        nNoUpdatesTemp = 0;
    //    temperature += SENSOR_TEMP_OFFSET;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      float humidity = dht12.readHumidity();
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    now i get these lines in the serial monitor:
    222794 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    224802 !TSM:FPAR:NO REPLY
    224804 TSM:FPAR
    226404 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    228412 !TSM:FPAR:NO REPLY
    228414 TSM:FPAR
    230013 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    232022 !TSM:FPAR:NO REPLY
    232024 TSM:FPAR
    233623 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    can anybody tell me where the problem is.????
    thanks a lot!
    ps i use a RPi-Gateway with about 15 older Arduino Nano with DHT11 sensors..... they are working fine but too big...
    • michlb1982M michlb1982
      Hi
      //Write by Bobadas.
      #include <DHT12.h>
      normally is 0x5c.
      Examples:
        DHT12 dht12;
        Wire.begin();
        Serial.begin(9600);
      //Read humidity.
        delay(5000);
      #include <DHT12.h>
      float lastTemp;
      float lastHum;
      bool metric = true;
        Wire.begin();
        Serial.begin(9600);
      //    if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      224804 TSM:FPAR
      228414 TSM:FPAR
      232024 TSM:FPAR
      thanks a lot!
      @michlb1982 looks like the node is able to receive ack from the gw on the messages sent by the node (indicated by st=OK), but the reply message from the gateway is not received.
      Could you share the gateway log?
      Does the gw run the same version of MySensors as the node?
        I think the node ID is missing
        • michlb1982M
          michlb1982M
          michlb1982
          good morning
          here the config of my rpi-gateway with direct connected nrf24L01+.
          define SerialGate MYSENSORS /dev/ttyUSB020@115200
          attr SerialGate autocreate 1
          attr SerialGate first-sensorid 1
          attr SerialGate last-sensorid 255
          attr SerialGate requestAck 1
          attr SerialGate room 00_Sensornet
          attr SerialGate stateFormat connection```
          DEF /dev/ttyUSB020@115200
          DeviceName /dev/ttyUSB020@115200
          FD 4
          NAME SerialGate
          NOTIFYDEV global
          NR 63
          NTFY_ORDER 50-SerialGate
          PARTIAL
          STATE connected
          TYPE MYSENSORS
          ack 1
          inclusion-mode 1
          outstandingAck 0
          version 2.1.0-beta ```
          libraryversion on sensor 2.1.1
          version of Gateway 2.1.0-beta
          how can i update the gateway version?
          is it nessasary to update the old sensores too?
          greetings
          ps the log:
          2017.04.16 08:41:24 1: Including ./log/fhem.save
          2017.04.16 08:41:24 3: Opening SerialGate device /dev/ttyUSB020
          2017.04.16 08:41:24 3: Setting SerialGate serial parameters to 115200,8,N,1
          2017.04.16 08:41:24 3: SerialGate device opened
          2017.04.16 08:44:47 5: MYSENSORS/RAW: /70;0;1;0;0;18.0
          2017.04.16 08:44:47 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '18.0'
          2017.04.16 08:44:47 5: MYSENSORS/RAW: /70;0;1;0;1;38.0
          2017.04.16 08:44:47 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '38.0'
          2017.04.16 08:44:58 5: MYSENSORS/RAW: /170;0;1;0;0;20.0
          2017.04.16 08:44:58 5: MYSENSORS Read: Rx: fr=170 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '20.0'
          2017.04.16 08:45:28 5: MYSENSORS/RAW: /170;0;1;0;1;36.0
          160;0;1;0;0;24.0
          160;0;1;0;1;35.0
          190;0;1;0;0;25.0
          190;0;1;0;1;39.0
          70;0;1;0;0;18.0
          70;0;1;0;1;38.0
          130;0;1;0;0;21.0
          130;0;1;0;1;36.0
          120;0;1;0;0;23.0
          120;0;1;0;1;35.0
          2017.04.16 08:45:28 5: MYSENSORS Read: Rx: fr=170 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '36.0'
          2017.04.16 08:45:28 5: MYSENSORS Read: Rx: fr=160 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '24.0'
          2017.04.16 08:45:28 5: MYSENSORS Read: Rx: fr=160 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '35.0'
          2017.04.16 08:45:28 5: MYSENSORS Read: Rx: fr=190 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '25.0'
          2017.04.16 08:45:28 5: MYSENSORS Read: Rx: fr=190 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '39.0'
          2017.04.16 08:45:28 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '18.0'
          2017.04.16 08:45:29 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '38.0'
          2017.04.16 08:45:29 5: MYSENSORS Read: Rx: fr=130 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '21.0'
          2017.04.16 08:45:29 5: MYSENSORS Read: Rx: fr=130 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '36.0'
          2017.04.16 08:45:29 5: MYSENSORS Read: Rx: fr=120 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '23.0'
          2017.04.16 08:45:29 5: MYSENSORS Read: Rx: fr=120 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '35.0'
          2017.04.16 08:46:01 5: MYSENSORS/RAW: /70;0;1;0;0;18.0
          2017.04.16 08:46:01 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '18.0'
          2017.04.16 08:46:02 5: MYSENSORS/RAW: /70;0;1;0;1;38.0
          2017.04.16 08:46:02 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '38.0'
          2017.04.16 08:46:06 5: MYSENSORS/RAW: /170;0;1;0;0;20.0
          2017.04.16 08:46:06 5: MYSENSORS Read: Rx: fr=170 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '20.0'
          2017.04.16 08:46:07 5: MYSENSORS/RAW: /170;0;1;0;1;36.0
          2017.04.16 08:46:07 5: MYSENSORS Read: Rx: fr=170 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '36.0'
          2017.04.16 08:46:14 5: MYSENSORS/RAW: /160;0;1;0;0;24.0
          2017.04.16 08:46:14 5: MYSENSORS Read: Rx: fr=160 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '24.0'
          2017.04.16 08:46:15 5: MYSENSORS/RAW: /160;0;1;0;1;35.0
          2017.04.16 08:46:15 5: MYSENSORS Read: Rx: fr=160 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '35.0'
          2017.04.16 08:46:22 5: MYSENSORS/RAW: /190;0;1;0;0;25.0
          2017.04.16 08:46:22 5: MYSENSORS Read: Rx: fr=190 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '25.0'
          2017.04.16 08:46:22 5: MYSENSORS/RAW: /190;0;1;0;1;39.0
          2017.04.16 08:46:22 5: MYSENSORS Read: Rx: fr=190 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '39.0'
          2017.04.16 08:46:31 5: MYSENSORS/RAW: /120;0;1;0;0;23.0
          2017.04.16 08:46:31 5: MYSENSORS Read: Rx: fr=120 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '23.0'
          2017.04.16 08:46:31 5: MYSENSORS/RAW: /120;0;1;0;1;35.0
          2017.04.16 08:46:31 5: MYSENSORS Read: Rx: fr=120 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '35.0'
          2017.04.16 08:46:33 5: MYSENSORS/RAW: /130;0;1;0;0;21.0
          2017.04.16 08:46:33 5: MYSENSORS Read: Rx: fr=130 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '21.0'
          2017.04.16 08:46:34 5: MYSENSORS/RAW: /130;0;1;0;1;36.0
          2017.04.16 08:46:34 5: MYSENSORS Read: Rx: fr=130 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '36.0'
          2017.04.16 08:46:39 5: MYSENSORS/RAW: /70;0;1;0;0;18.0
          2017.04.16 08:46:39 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '18.0'
          2017.04.16 08:46:39 5: MYSENSORS/RAW: /70;0;1;0;1;38.0
          2017.04.16 08:46:39 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '38.0'
          2017.04.16 08:47:14 5: MYSENSORS/RAW: /170;0;1;0;0;20.0
          2017.04.16 08:47:14 5: MYSENSORS Read: Rx: fr=170 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '20.0'
          2017.04.16 08:47:15 5: MYSENSORS/RAW: /170;0;1;0;1;36.0
          2017.04.16 08:47:15 5: MYSENSORS Read: Rx: fr=170 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '36.0'
          2017.04.16 08:47:16 5: MYSENSORS/RAW: /70;0;1;0;0;18.0
          2017.04.16 08:47:16 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '18.0'
          2017.04.16 08:47:16 5: MYSENSORS/RAW: /70;0;1;0;1;38.0
          2017.04.16 08:47:16 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '38.0'
          2017.04.16 08:47:22 5: MYSENSORS/RAW: /160;0;1;0;0;24.0
          2017.04.16 08:47:22 5: MYSENSORS Read: Rx: fr=160 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '24.0'
          2017.04.16 08:47:22 5: MYSENSORS/RAW: /160;0;1;0;1;35.0
          2017.04.16 08:47:22 5: MYSENSORS Read: Rx: fr=160 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '35.0'
          2017.04.16 08:47:27 5: MYSENSORS/RAW: /190;0;1;0;0;25.0
          2017.04.16 08:47:27 5: MYSENSORS Read: Rx: fr=190 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '25.0'
          2017.04.16 08:47:27 5: MYSENSORS/RAW: /190;0;1;0;1;39.0
          2017.04.16 08:47:27 5: MYSENSORS Read: Rx: fr=190 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '39.0'
          2017.04.16 08:47:35 5: MYSENSORS/RAW: /120;0;1;0;0;23.0
          2017.04.16 08:47:35 5: MYSENSORS Read: Rx: fr=120 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '23.0'
          2017.04.16 08:47:35 5: MYSENSORS/RAW: /120;0;1;0;1;35.0
          2017.04.16 08:47:35 5: MYSENSORS Read: Rx: fr=120 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '35.0'
          2017.04.16 08:47:42 5: MYSENSORS/RAW: /130;0;1;0;0;21.0
          2017.04.16 08:47:42 5: MYSENSORS Read: Rx: fr=130 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '21.0'
          2017.04.16 08:47:42 5: MYSENSORS/RAW: /130;0;1;0;1;36.0
          2017.04.16 08:47:42 5: MYSENSORS Read: Rx: fr=130 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '36.0'
          2017.04.16 08:47:53 5: MYSENSORS/RAW: /70;0;1;0;0;18.0
          2017.04.16 08:47:53 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '18.0'
          2017.04.16 08:47:54 5: MYSENSORS/RAW: /70;0;1;0;1;38.0
          2017.04.16 08:47:54 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '38.0'
          2017.04.16 08:48:23 5: MYSENSORS/RAW: /170;0;1;0;0;20.0
          2017.04.16 08:48:23 5: MYSENSORS Read: Rx: fr=170 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '20.0'
          2017.04.16 08:48:23 5: MYSENSORS/RAW: /170;0;1;0;1;36.0
          2017.04.16 08:48:23 5: MYSENSORS Read: Rx: fr=170 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '36.0'
          2017.04.16 08:48:29 5: MYSENSORS/RAW: /160;0;1;0;0;24.0
          2017.04.16 08:48:29 5: MYSENSORS Read: Rx: fr=160 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '24.0'
          2017.04.16 08:48:29 5: MYSENSORS/RAW: /160;0;1;0;1;35.0
          2017.04.16 08:48:29 5: MYSENSORS Read: Rx: fr=160 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '35.0'
          2017.04.16 08:48:31 5: MYSENSORS/RAW: /70;0;1;0;0;18.0
          2017.04.16 08:48:31 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '18.0'
          2017.04.16 08:48:31 5: MYSENSORS/RAW: /70;0;1;0;1;38.0
          2017.04.16 08:48:31 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '38.0'
          2017.04.16 08:48:32 5: MYSENSORS/RAW: /190;0;1;0;0;25.0
          2017.04.16 08:48:32 5: MYSENSORS Read: Rx: fr=190 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '25.0'
          2017.04.16 08:48:33 5: MYSENSORS/RAW: /190;0;1;0;1;39.0
          2017.04.16 08:48:33 5: MYSENSORS Read: Rx: fr=190 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '39.0'
          2017.04.16 08:48:39 5: MYSENSORS/RAW: /120;0;1;0;0;23.0
          2017.04.16 08:48:39 5: MYSENSORS Read: Rx: fr=120 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '23.0'
          2017.04.16 08:48:39 5: MYSENSORS/RAW: /120;0;1;0;1;35.0
          2017.04.16 08:48:39 5: MYSENSORS Read: Rx: fr=120 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '35.0'
          2017.04.16 08:48:50 5: MYSENSORS/RAW: /130;0;1;0;0;21.0
          2017.04.16 08:48:50 5: MYSENSORS Read: Rx: fr=130 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '21.0'
          2017.04.16 08:48:50 5: MYSENSORS/RAW: /130;0;1;0;1;36.0
          2017.04.16 08:48:50 5: MYSENSORS Read: Rx: fr=130 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '36.0'
          2017.04.16 08:49:08 5: MYSENSORS/RAW: /70;0;1;0;0;18.0
          2017.04.16 08:49:08 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '18.0'
          2017.04.16 08:49:09 5: MYSENSORS/RAW: /70;0;1;0;1;38.0
          2017.04.16 08:49:09 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '38.0'
          2017.04.16 08:49:31 5: MYSENSORS/RAW: /170;0;1;0;0;20.0
          2017.04.16 08:49:31 5: MYSENSORS Read: Rx: fr=170 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '20.0'
          2017.04.16 08:49:32 5: MYSENSORS/RAW: /170;0;1;0;1;36.0
          2017.04.16 08:49:32 5: MYSENSORS Read: Rx: fr=170 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '36.0'
          2017.04.16 08:49:36 5: MYSENSORS/RAW: /160;0;1;0;0;24.0
          2017.04.16 08:49:36 5: MYSENSORS Read: Rx: fr=160 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '24.0'
          2017.04.16 08:49:36 5: MYSENSORS/RAW: /160;0;1;0;1;35.0
          2017.04.16 08:49:36 5: MYSENSORS Read: Rx: fr=160 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '35.0'
          2017.04.16 08:49:37 5: MYSENSORS/RAW: /190;0;1;0;0;25.0
          2017.04.16 08:49:37 5: MYSENSORS Read: Rx: fr=190 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '25.0'
          2017.04.16 08:49:38 5: MYSENSORS/RAW: /190;0;1;0;1;39.0
          2017.04.16 08:49:38 5: MYSENSORS Read: Rx: fr=190 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '39.0'
          2017.04.16 08:49:43 5: MYSENSORS/RAW: /120;0;1;0;0;23.0
          2017.04.16 08:49:43 5: MYSENSORS Read: Rx: fr=120 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '23.0'
          2017.04.16 08:49:43 5: MYSENSORS/RAW: /120;0;1;0;1;35.0
          2017.04.16 08:49:43 5: MYSENSORS Read: Rx: fr=120 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '35.0'
          2017.04.16 08:49:45 5: MYSENSORS/RAW: /70;0;1;0;0;18.0
          2017.04.16 08:49:45 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '18.0'
          2017.04.16 08:49:46 5: MYSENSORS/RAW: /70;0;1;0;1;38.0
          2017.04.16 08:49:46 5: MYSENSORS Read: Rx: fr=070 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '38.0'
          2017.04.16 08:49:58 5: MYSENSORS/RAW: /130;0;1;0;0;21.0
          2017.04.16 08:49:58 5: MYSENSORS Read: Rx: fr=130 ci=000 c=001(C_SET         ) st=000(V_TEMP          ) ack=0 '21.0'
          2017.04.16 08:49:58 5: MYSENSORS/RAW: /130;0;1;0;1;36.0
          2017.04.16 08:49:58 5: MYSENSORS Read: Rx: fr=130 ci=000 c=001(C_SET         ) st=001(V_HUM           ) ack=0 '36.0'
            good morning
            FD 4
            NAME SerialGate
            NOTIFYDEV global
            NR 63
            PARTIAL
            STATE connected
            TYPE MYSENSORS
            ack 1
            inclusion-mode 1
            outstandingAck 0
            greetings
            ps the log:
            160;0;1;0;0;24.0
            160;0;1;0;1;35.0
            190;0;1;0;0;25.0
            190;0;1;0;1;39.0
            70;0;1;0;0;18.0
            70;0;1;0;1;38.0
            130;0;1;0;0;21.0
            130;0;1;0;1;36.0
            120;0;1;0;0;23.0
            120;0;1;0;1;35.0
            Thanks @michlb1982
            Mixing different 2.x versions is ok, so there is no need to upgrade the gw. If you want to upgrade anyway, do the same thing you did when creating the gw, except use a newer version of MySensors.
            I am not sure if the fhem log of the gw shows all debug info from the gw. There are no mentions of the broadcast messages sent by the node. Could you post the debug log from the gateway itself?
            michlb1982M 1 Reply Last reply
              Thanks @michlb1982
              michlb1982M
              michlb1982M
              michlb1982
              @mfalkvidd sure i can, but how? is this you want to see an extra log direct from the gateway? where will i find this log?
              as i said i'm not an it technican just an hobbyist, a little DIY'er....
                @michlb1982 I don't know how to do that but I will try to find out.
                  Found it!
                  https://www.mysensors.org/build/raspberry#test
                  The first time you run the gateway, enable the debug messages to verify that it is working:
                  sudo ./bin/mysgw -d
                    Found it!
                    sudo ./bin/mysgw -d
                    michlb1982M
                    michlb1982M
                    michlb1982
                    @mfalkvidd Thanks for the link... got it..
                    here the output from the debug..
                    pi@SmartPi:~/MySensors $ sudo ./bin/mysgw -d
                    mysgw: Starting gateway...
                    mysgw: Protocol version - 2.1.0-beta
                    mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.1.0-beta
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: !TSM:INIT:TSP FAIL
                    mysgw: TSM:FAIL:CNT=1
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:FAIL:RE-INIT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=2
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=3
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=4
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=5
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=6
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:CNT=7
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:INIT:TSP OK
                    mysgw: TSM:INIT:GW MODE
                    mysgw: MCO:BGN:STP
                    mysgw: MCO:BGN:INIT OK,TSP=1
                    mysgw: TSF:MSG:READ,70-70-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                    mysgw: TSF:MSG:BC
                    mysgw: TSF:MSG:FPAR REQ,ID=70
                    mysgw: TSF:PNG:SEND,TO=0
                    mysgw: TSF:CKU:OK
                    mysgw: TSF:MSG:GWL OK
                    mysgw: Received SIGINT
                    My other sensors are working fine, just the new one isn't .
                      It looks like it can't initialize the radio.
                        michlb1982M
                        michlb1982M
                        michlb1982
                        @gohan thanks for the info.... you were right!
                        i soldered the smd radio like in the building instruktions descripted,and because of that, that there were no infos about the voltage of the smd radio i used the 3,3v regulator ... that was the mistake!!!
                        so i thaught, if it's not workimg, let's try tu use the 5v, worst case the radio will go to hell....
                        so... testet with 5v on themradio and ... heureka it works.... now i have the dht12 with nrf24 smd on a mini pro.... so the sensor is very small and easy coded....
                        i will make a build and wire diagramm and rewrite the code... who can i send it for publication on the mysensors site?
                          That's odd... Unless that smd version has different voltage requirements, the nrf24 should fry with 5v
