  3. OpenHAB
  4. OpenHAB 2.5 MySensors Serial Gateway - How to install
23 Posts 10 Posters 17.7k Views 11 Watching
  • I iamtheghost
    @flipflap3 said in OpenHAB 2.4 MySensors Serial Gateway - How to install:
    sudo apt-get install oracle-java8-installer
    This package has been removed and can't be installed as instructed in the tutorial. As of April, I believe it was removed from that repo.
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Package oracle-java8-installer is not available, but is referred to by another package.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    E: Package 'oracle-java8-installer' has no installation candidate
    Unsure of how to proceed.
    TRS-80T
    TRS-80T
    TRS-80
    wrote on last edited by TRS-80
    #21
    @iamtheghost,
    I realize it's been few months, but I will post this anyway. As I also recently went through the same ordeal.
    Thanks to OP for posting an easy to follow guide.
    I found the official install instructions at OpenHAB quite good: https://www.openhab.org/docs/installation/linux.html
    ...with one exception. Currently, it seems there is some bug going on with their build system or something. I actually had lodged an issue of my own (and even had submitted a PR to correct the documentation) before someone replied, pointing me to the root issue. So for the time being, instead of using https://dl.bintray.com/openhab/apt-repo2 location, you should use https://openhab.jfrog.io/openhab/openhab-linuxpkg repository location.
    Further, if you care about issues such as software freedom (which I do a great deal) you might want to consider installing Azul/Zulu Java 8 (make sure it's 8!) which I have done, instead of Oracle Java. Azul's (also excellent) instructions can be found linked from the OpenHAB Linux install instructions. And that would also solve your missing repo problem, obviously.
    A 1 Reply Last reply
    • TRS-80T TRS-80
      @iamtheghost,
      A
      A
      alphaHotel
      wrote on last edited by alphaHotel
      #22
      @trs-80 said in OpenHAB 2.4 MySensors Serial Gateway - How to install:
      I ran into the same thing. Specifically, to get around this, the second instruction under the OpenHAB portion of the original post can be substituted with this:
      echo 'deb https://openhab.jfrog.io/openhab/openhab-linuxpkg stable main' | sudo tee /etc/apt/sources.list.d/openhab2.list
      EDIT: I've just noticed that they've updated the Package Repository Installation instructions to add the command above.
      If using Zulu Java, beware that the repos are not being maintained and are behind (see reference for manual instructions).
      I used OpenJDK 8 for java with sudo apt install openjdk-8-jdk-headless.
      I'm using an Ethernet gateway (on a separate Raspberry Pi) though which is a twist on all of this.
      --Allen
      • F
        F
        FlipFlap3
        Updated to OpenHAB 2.5 with step-by-step instructions
        switched to Zulu Java
