  3. Payload always 0 when using Arduino Pro Mini
8 Posts 3 Posters 2.1k Views 3 Watching
  • A Offline
    A Offline
    adamp237
    I've been using MySensors with HomeAssistant fairly successfully, testing on my Arduino Uno (Genuine).
    Everything works fine with the UNO, so I purchased some no so genuine Arduino Nanos and Pro Mini (5v and 3.3v version). With all of these boards I've had an issue of never being able to receive any usable data from the sensors.
    I will explain with my most current example which I have poured hours into with no luck:
    I have set up my UNO with the temperature sketch which works a treat using the waterproof DS18B20. I copied the exact same sketch with the exact same connections to an Arduino Pro Mini 3.3v and it seems to work through MQTT but I'm always receiving no actual data. Where it should show "13.2" for example, it shows "".
    I changed to the Arduino Pro Mini 5v with a 3.3v regulator and it does the exact same thing.
    When I warm the sensor up with my hand it shoots off lots of messages as if the code has recognised the change in temp but all of those messages have "".
    This happened on a previous project when I tried a Nano. Everything seems to work, but no data!
    I've tried different radios etc but it doesn't seem to make a difference.
    I will admit I don't really understand it all, I'm more of a copy paste type guy but all of my debugging has got me nowhere. I am guessing there's nothing wrong with the code, I'm not changing it at all, I'm just changing the board in the Arduino software.
    Using: Arduino 1.6.12 on Windows, powering by USB (FTD1232 for Pro Minis). I've tried different power supplies also.
    Serial output:
    3 MCO:BGN:BFR
    63 TSM:INIT
    64 TSF:WUR:MS=0
    71 TSM:INIT:TSP OK
    73 TSM:FPAR
    75 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    712 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    717 TSF:MSG:FPAR OK,ID=0,D=1
    2082 TSM:FPAR:OK
    2083 TSM:ID
    2084 TSM:ID:REQ
    2087 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4096 TSM:ID
    4097 TSM:ID:REQ
    4099 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    6107 TSM:ID
    6108 TSM:ID:REQ
    6110 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    8118 TSM:ID
    8119 TSM:ID:REQ
    8121 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    10129 !TSM:ID:FAIL
    10130 TSM:FAIL:CNT=1
    10132 TSM:FAIL:PDT
    20135 TSM:FAIL:RE-INIT
    20137 TSM:INIT
    20145 TSM:INIT:TSP OK
    20147 TSM:FPAR
    20149 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20369 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    20374 TSF:MSG:FPAR OK,ID=0,D=1
    22157 TSM:FPAR:OK
    22158 TSM:ID
    22160 TSM:ID:REQ
    22162 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    24170 TSM:ID
    24171 TSM:ID:REQ
    24174 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    26181 TSM:ID
    26182 TSM:ID:REQ
    26185 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    28192 TSM:ID
    28193 TSM:ID:REQ
    28196 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    30204 !TSM:ID:FAIL
    30205 TSM:FAIL:CNT=2
    30208 TSM:FAIL:PDT
    40211 TSM:FAIL:RE-INIT
    40213 TSM:INIT
    40220 TSM:INIT:TSP OK
    40222 TSM:FPAR
    40224 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    41061 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    41066 TSF:MSG:FPAR OK,ID=0,D=1
    42232 TSM:FPAR:OK
    42233 TSM:ID
    42235 TSM:ID:REQ
    42237 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    44246 TSM:ID
    44247 TSM:ID:REQ
    44250 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    46257 TSM:ID
    46258 TSM:ID:REQ
    46261 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    48268 TSM:ID
    48269 TSM:ID:REQ
    48272 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    50279 !TSM:ID:FAIL
    50280 TSM:FAIL:CNT=3
    50282 TSM:FAIL:PDT
    60285 TSM:FAIL:RE-INIT
    60288 TSM:INIT
    60295 TSM:INIT:TSP OK
    60297 TSM:FPAR
    60299 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    60737 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    60742 TSF:MSG:FPAR OK,ID=0,D=1
    62307 TSM:FPAR:OK
    62308 TSM:ID
    62310 TSM:ID:REQ
    62312 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    64320 TSM:ID
    64321 TSM:ID:REQ
    64324 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    66331 TSM:ID
    66332 TSM:ID:REQ
    66335 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    68342 TSM:ID
    68343 TSM:ID:REQ
    68346 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    70354 !TSM:ID:FAIL
    70355 TSM:FAIL:CNT=4
    70358 TSM:FAIL:PDT
    Arduino sketch:
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    #define MY_MQTT_USER "pi"
    #define MY_MQTT_PASSWORD "masked"
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 141
    #define MY_PORT 1883
    #include <OneWire.h>
    unsigned long SLEEP_TIME = 300; // Sleep time between reads (in milliseconds)
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
    void presentation() {
      sendSketchInfo("Temperature Sensor", "1.1");
         present(i, S_TEMP);
    Serial.println("Start");
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          Serial.println(temperature);
          send(msg.setSensor(i).set(temperature,1));
      sleep(SLEEP_TIME);
    • K Offline
      K Offline
      korttoma
      Please try your debug log in the Log Parser
      The issue is quite clear.
      • Tomas
      • A Offline
        A Offline
        adamp237
        I did try this. It is sending 4 messages before failing. I'm not really sure what this means though?
        • K Offline
          K Offline
          korttoma
          The Node is requesting and ID and your controller is not sending one. Does the controller support node ID generation?
          Another reason could be that your GW/controller never receives the request for ID. Can you get a log from your GW or controller?
          • Tomas
          • A Offline
            A Offline
            adamp237
            You're onto something I reckon, but I'm still not sure what! This might make more sense to you:
            So my MQTT shows this:
            Client mosqsub/2384-raspberryp received PUBLISH (d0, q0, r0, m0, 'mysensors-out/0/255/0/0/18', ... (5 bytes))
            2.1.1
            Client mosqsub/2384-raspberryp received PUBLISH (d0, q0, r0, m0, 'mysensors-out/255/255/3/0/3', ... (0 bytes))
            My Sensors did this:
            pi@raspberrypi:~/MySensors $ sudo ./bin/mysgw -d
            mysgw: Starting gateway...
            mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:INIT:TSP OK
            mysgw: TSM:INIT:GW MODE
            mysgw: MCO:REG:NOT NEEDED
            mysgw: MCO:BGN:STP
            mysgw: MCO:BGN:INIT OK,TSP=1
            mysgw: Attempting MQTT connection...
            mysgw: connected to 127.0.0.1
            mysgw: MQTT connected
            mysgw: Sending message on topic: mysensors-out/0/255/0/0/18
            mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
            mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
            mysgw: send: Broken pipe
            mysgw: TSF:MSG:READ,7-7-7,s=7,c=7,t=7,pt=0,l=0,sg=1:
            mysgw: !TSF:MSG:LEN,7!=32
            mysgw: !TSF:MSG:LEN,0!=32
            Then the Arduino Serial shows a fail to connect and nothing happens:
            3 MCO:BGN:BFR
            5 TSM:INIT
            6 TSF:WUR:MS=0
            13 TSM:INIT:TSP OK
            15 TSM:FPAR
            17 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2024 !TSM:FPAR:NO REPLY
            2026 TSM:FPAR
            2028 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            4036 !TSM:FPAR:NO REPLY
            4038 TSM:FPAR
            4040 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            6048 !TSM:FPAR:NO REPLY
            6050 TSM:FPAR
            6052 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            8061 !TSM:FPAR:FAIL
            8062 TSM:FAIL:CNT=1
            8065 TSM:FAIL:PDT
            18068 TSM:FAIL:RE-INIT
            18070 TSM:INIT
            18077 TSM:INIT:TSP OK
            18079 TSM:FPAR
            18081 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            20089 !TSM:FPAR:NO REPLY
            20091 TSM:FPAR
            20093 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            22102 !TSM:FPAR:NO REPLY
            22104 TSM:FPAR
            22106 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            24114 !TSM:FPAR:NO REPLY
            24116 TSM:FPAR
            24118 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            26126 !TSM:FPAR:FAIL
            26127 TSM:FAIL:CNT=2
            26129 TSM:FAIL:PDT
            36132 TSM:FAIL:RE-INIT
            36134 TSM:INIT
            36142 TSM:INIT:TSP OK
            36144 TSM:FPAR
            36146 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            38154 !TSM:FPAR:NO REPLY
            38156 TSM:FPAR
            38158 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            40166 !TSM:FPAR:NO REPLY
            40168 TSM:FPAR
            40170 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            42178 !TSM:FPAR:NO REPLY
            42180 TSM:FPAR
            42182 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            44190 !TSM:FPAR:FAIL
            44191 TSM:FAIL:CNT=3
            44193 TSM:FAIL:PDT
            54196 TSM:FAIL:RE-INIT
            54198 TSM:INIT
            54205 TSM:INIT:TSP OK
            54207 TSM:FPAR
            54209 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            56217 !TSM:FPAR:NO REPLY
            56219 TSM:FPAR
            56221 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            58229 !TSM:FPAR:NO REPLY
            58231 TSM:FPAR
            58233 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            60242 !TSM:FPAR:NO REPLY
            60244 TSM:FPAR
            60247 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            62255 !TSM:FPAR:FAIL
            62256 TSM:FAIL:CNT=4
            62258 TSM:FAIL:PDT
            72261 TSM:FAIL:RE-INIT
            72263 TSM:INIT
            72270 TSM:INIT:TSP OK
            72272 TSM:FPAR
            72274 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            72290 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            72295 TSF:MSG:FPAR OK,ID=0,D=1
            74283 TSM:FPAR:OK
            74284 TSM:ID
            74285 TSM:ID:REQ
            74288 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            76296 TSM:ID
            76297 TSM:ID:REQ
            76300 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            78307 TSM:ID
            78308 TSM:ID:REQ
            78311 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            80318 TSM:ID
            80319 TSM:ID:REQ
            80322 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            82329 !TSM:ID:FAIL
            82330 TSM:FAIL:CNT=5
            82332 TSM:FAIL:PDT
            92335 TSM:FAIL:RE-INIT
            92337 TSM:INIT
            92344 TSM:INIT:TSP OK
            92346 TSM:FPAR
            92348 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            92983 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            92988 TSF:MSG:FPAR OK,ID=0,D=1
            94356 TSM:FPAR:OK
            94357 TSM:ID
            94359 TSM:ID:REQ
            94361 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            96369 TSM:ID
            96370 TSM:ID:REQ
            96373 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            98380 TSM:ID
            98381 TSM:ID:REQ
            98384 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            100392 TSM:ID
            100393 TSM:ID:REQ
            100397 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            102404 !TSM:ID:FAIL
            102405 TSM:FAIL:CNT=6
            102408 TSM:FAIL:PDT
            112410 TSM:FAIL:RE-INIT
            112412 TSM:INIT
            112419 TSM:INIT:TSP OK
            112421 TSM:FPAR
            112424 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            112640 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            112645 TSF:MSG:FPAR OK,ID=0,D=1
            114432 TSM:FPAR:OK
            114433 TSM:ID
            114435 TSM:ID:REQ
            114438 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            116445 TSM:ID
            116446 TSM:ID:REQ
            116449 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            118456 TSM:ID
            118457 TSM:ID:REQ
            118460 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            120467 TSM:ID
            120468 TSM:ID:REQ
            120471 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            122478 !TSM:ID:FAIL
            122479 TSM:FAIL:CNT=7
            122482 TSM:FAIL:PDT
            182484 TSM:FAIL:RE-INIT
            182487 TSM:INIT
            182494 TSM:INIT:TSP OK
            182496 TSM:FPAR
            182499 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            184506 !TSM:FPAR:NO REPLY
            184508 TSM:FPAR
            184511 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            186518 !TSM:FPAR:NO REPLY
            186520 TSM:FPAR
            186523 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            188530 !TSM:FPAR:NO REPLY
            188532 TSM:FPAR
            188535 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            190542 !TSM:FPAR:FAIL
            190544 TSM:FAIL:CNT=7
            190546 TSM:FAIL:PDT
            250549 TSM:FAIL:RE-INIT
            250551 TSM:INIT
            250558 TSM:INIT:TSP OK
            250560 TSM:FPAR
            250563 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            252570 !TSM:FPAR:NO REPLY
            252572 TSM:FPAR
            252575 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            254582 !TSM:FPAR:NO REPLY
            254584 TSM:FPAR
            254587 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            256595 !TSM:FPAR:NO REPLY
            256598 TSM:FPAR
            256601 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            258608 !TSM:FPAR:FAIL
            258610 TSM:FAIL:CNT=7
            258612 TSM:FAIL:PDT
            318615 TSM:FAIL:RE-INIT
            318617 TSM:INIT
            318624 TSM:INIT:TSP OK
            318626 TSM:FPAR
            318629 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            320637 !TSM:FPAR:NO REPLY
            320640 TSM:FPAR
            320643 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            322650 !TSM:FPAR:NO REPLY
            322652 TSM:FPAR
            322655 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            324662 !TSM:FPAR:NO REPLY
            324664 TSM:FPAR
            324667 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            326674 !TSM:FPAR:FAIL
            326676 TSM:FAIL:CNT=7
            326678 TSM:FAIL:PDT
            Unless you can work out anything specific, I'll try reinstalling MySensors on my Pi. The initial installation did not go smoothly. I just figured that if it was working fine with the Uno, it was working fine full stop.
            A 1 Reply Last reply
            • A adamp237
              2.1.1
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: MCO:BGN:STP
              3 MCO:BGN:BFR
              5 TSM:INIT
              6 TSF:WUR:MS=0
              13 TSM:INIT:TSP OK
              15 TSM:FPAR
              2026 TSM:FPAR
              4038 TSM:FPAR
              6050 TSM:FPAR
              8061 !TSM:FPAR:FAIL
              8062 TSM:FAIL:CNT=1
              8065 TSM:FAIL:PDT
              18070 TSM:INIT
              18079 TSM:FPAR
              20091 TSM:FPAR
              22104 TSM:FPAR
              24116 TSM:FPAR
              26129 TSM:FAIL:PDT
              36134 TSM:INIT
              36144 TSM:FPAR
              38156 TSM:FPAR
              40168 TSM:FPAR
              42180 TSM:FPAR
              44193 TSM:FAIL:PDT
              54198 TSM:INIT
              54207 TSM:FPAR
              56219 TSM:FPAR
              58231 TSM:FPAR
              60244 TSM:FPAR
              62258 TSM:FAIL:PDT
              72263 TSM:INIT
              72272 TSM:FPAR
              74283 TSM:FPAR:OK
              74284 TSM:ID
              74285 TSM:ID:REQ
              76296 TSM:ID
              76297 TSM:ID:REQ
              78307 TSM:ID
              78308 TSM:ID:REQ
              80318 TSM:ID
              80319 TSM:ID:REQ
              82329 !TSM:ID:FAIL
              82332 TSM:FAIL:PDT
              92337 TSM:INIT
              92346 TSM:FPAR
              94356 TSM:FPAR:OK
              94357 TSM:ID
              94359 TSM:ID:REQ
              96369 TSM:ID
              96370 TSM:ID:REQ
              98380 TSM:ID
              98381 TSM:ID:REQ
              100392 TSM:ID
              100393 TSM:ID:REQ
              102404 !TSM:ID:FAIL
              102408 TSM:FAIL:PDT
              112412 TSM:INIT
              112421 TSM:FPAR
              114432 TSM:FPAR:OK
              114433 TSM:ID
              114435 TSM:ID:REQ
              116445 TSM:ID
              116446 TSM:ID:REQ
              118456 TSM:ID
              118457 TSM:ID:REQ
              120467 TSM:ID
              120468 TSM:ID:REQ
              122478 !TSM:ID:FAIL
              122482 TSM:FAIL:PDT
              182487 TSM:INIT
              182496 TSM:FPAR
              184508 TSM:FPAR
              186520 TSM:FPAR
              188532 TSM:FPAR
              190546 TSM:FAIL:PDT
              250551 TSM:INIT
              250560 TSM:FPAR
              252572 TSM:FPAR
              254584 TSM:FPAR
              256598 TSM:FPAR
              258612 TSM:FAIL:PDT
              318617 TSM:INIT
              318626 TSM:FPAR
              320640 TSM:FPAR
              322652 TSM:FPAR
              324664 TSM:FPAR
              326678 TSM:FAIL:PDT
              A Offline
              A Offline
              adamp237
              Reinstalled. It all went smoothly. Still sending 0 bytes of data.
              J 1 Reply Last reply
              • A adamp237
                J Offline
                J Offline
                Jan Gatzke
                wrote on last edited by Jan Gatzke
                @adamp237
                It looks like the node does not get a node ID from the controller. If you do not have a controller which supports assigning node IDs automatically, you have to assign a static ID in the sketch.
                • A Offline
                  A Offline
                  adamp237
                  You are all actually amazing and I appreciate your time. Thanks.
