  3. Sensebender Micro + rfm69w consumption?
14 Posts 3 Posters 3.9k Views 2 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    @tbowmo I know you were running sensebender micro on rfm69 adapter. What was your sleep consumption please? I am getting around 90 µA and I think it should be lower.
    May be others did some tests?
    • alexsh1A
      alexsh1A
      alexsh1
      Not sure what happened but I sorted it out.
      Sleep mode - > 24µA, peak TX -> 24mA averaging around 12-15mA
      I think this is fine.
      • tbowmoT
        tbowmoT
        tbowmo
        @alexsh1
        I'm still using nrf24 radios in my setup.. Only used rfm69 for testing the Sensebender Gateway.. And never got around to check on power consumption while sleeping.
        • scalzS
          scalzS
          RFM69 in sleep mode needs 0.1uA. I have checked sleep mode a while ago, and was approx getting that. Tested with an uCurrent device.
          perhaps your measurement tool, or something consuming power on your node.
          alexsh1A 1 Reply Last reply
          • scalzS scalz
            alexsh1A
            alexsh1A
            alexsh1
            @scalz ok, but what about sensebender micro AND rfm69w?
            I'm using a true RMS meter. It's not Fluke, but I do not think it can be 10 times wrong
            • alexsh1A
              alexsh1A
              alexsh1
              Moteinos arr drawing around 19 uA in a sleep mode (mainly overheads due to onboard VR)
              So I'm not too far from that
              • scalzS
                scalzS
                wrote on last edited by scalz
                sensebender micro is using ultra low power flash and atsha. both <1uA in deepest sleep mode. 328p is approx 0.1-0.2uA. Radio is 0.1uA.
                I'm talking about the deepest sleep mode without bod, and no wdt of course. with wdt it adds something like 5uA if i remember.
                already checked those values on my side.
                moteinos should be the same as sensebender except that there is a ldo (approx 1uA min), i don't remember the flash ic though (could draw some uA depending on the ref).
                that's a simple calc without sensors, you can have others leakage depending on the application.
                • scalzS scalz
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @scalz interesting info - thanks. I think by default I have optiboot on the sensebender micro, but not sure if BOD is on.
                  scalzS 1 Reply Last reply
                  • alexsh1A alexsh1
                    scalzS
                    scalzS
                    @alexsh1 i meant no bod during sleep mode is the lowest drain. But when wake up, it's better to have bod enabled (always better to have bod on for reliability, but it uses some power in sleep mode).
                    I guess you already know this. No idea why you're getting higher drain. we don't know much about your hw setup, or perhaps the burden voltage of your measurement tool..
                    • scalzS scalz
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @scalz I have a standard sensebender micro with default sketch (modifying node_id and rfm69w as well as singing). rfm69w is on the adapter @tbowmo developed (rfm69w to nrf24l01+ socket). Nothing extraordinary.
                      Not sure what sensebender micro default BODs are - I'll try to disable them today. From my experience, this is the only way to run on batteries long term.
                      • scalzS
                        scalzS
                        @alexsh1
                        weird.. what you could do for testing, is check power consumption by using sketch J from Gammon.
                        And add lowpowerlab lib to put the radio and flash in sleep mode too.
                        You should get approx 1uA drain or less
                        Below the sketch J from Gammon, you can remove the led management..
                        #include <avr/sleep.h>
                        const byte LED = 9;
                        void wake ()
                          // cancel sleep as a precaution
                          sleep_disable();
                          // precautionary while we do other stuff
                          detachInterrupt (0);
                        }  // end of wake
                        void setup ()
                          digitalWrite (2, HIGH);  // enable pull-up
                          }  // end of setup
                        void loop ()
                          pinMode (LED, OUTPUT);
                          digitalWrite (LED, HIGH);
                          delay (50);
                          digitalWrite (LED, LOW);
                          delay (50);
                          pinMode (LED, INPUT);
                          // disable ADC
                          ADCSRA = 0;
                          set_sleep_mode (SLEEP_MODE_PWR_DOWN);
                          sleep_enable();
                          // Do not interrupt before we go to sleep, or the
                          // ISR will detach interrupts and we won't wake.
                          noInterrupts ();
                          // will be called when pin D2 goes low
                          attachInterrupt (0, wake, FALLING);
                          EIFR = bit (INTF0);  // clear flag for interrupt 0
                          // turn off brown-out enable in software
                          // BODS must be set to one and BODSE must be set to zero within four clock cycles
                          MCUCR = bit (BODS) | bit (BODSE);
                          // The BODS bit is automatically cleared after three clock cycles
                          MCUCR = bit (BODS);
                          // We are guaranteed that the sleep_cpu call will be done
                          // as the processor executes the next instruction after
                          // interrupts are turned on.
                          interrupts ();  // one cycle
                          sleep_cpu ();   // one cycle
                          } // end of loop
                        For reference : https://www.gammon.com.au/forum/?id=11497
                        • scalzS scalz
                          @alexsh1
                          const byte LED = 9;
                          void wake ()
                            sleep_disable();
                          }  // end of wake
                          void setup ()
                            }  // end of setup
                          void loop ()
                            delay (50);
                            delay (50);
                            // disable ADC
                            ADCSRA = 0;
                            sleep_enable();
                            noInterrupts ();
                            MCUCR = bit (BODS);
                            } // end of loop
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @scalz With this sketch, I am still getting 19 uA. Not sure, but something is not sleeping.
                          With other low power boards, I am getting 5-6uA.
                          EDIT: I have tried it with nrf24l01+ and still get 24uA
                          • alexsh1A alexsh1
                            alexsh1A
                            alexsh1A
                            alexsh1
                            This is my Sesnebender Micro sketch:
                             * Version 1.0 - Thomas Bowman Mørch
                             * Default sensor sketch for Sensebender Micro module
                             * Act as a temperature / humidity sensor by default.
                             * If A0 is held low while powering on, it will enter testmode, which verifies all on-board peripherals
                             * Battery voltage is as battery percentage (Internal message), and optionally as a sensor value (See defines below)
                             * Version 1.3 - Thomas Bowman Mørch
                             * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
                             * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
                             * Version 1.4 - Thomas Bowman Mørch
                             * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
                             * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
                             * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
                            #define MY_DISABLED_SERIAL
                            //#define MY_DEBUG
                            //#define MY_DEBUG_VERBOSE_SIGNING
                            // Define a static node address, remove if you want auto address assignment
                            #define MY_NODE_ID 5
                            //#define MY_RADIO_NRF24
                            #define MY_RADIO_RFM69
                            //#define MY_RF69_IRQ_PIN 2
                            //#define MY_RF69_IRQ_NUM 1
                            #define MY_SIGNING_ATSHA204
                            #define MY_SIGNING_ATSHA204_PIN 17
                            // Enable to support OTA for this node (needs DualOptiBoot boot-loader to fully work)
                            #define MY_OTA_FIRMWARE_FEATURE
                            #include <Wire.h>
                            #include <SI7021.h>
                            #ifndef MY_OTA_FIRMWARE_FEATURE
                            #include "drivers/SPIFlash/SPIFlash.cpp"
                            #include <EEPROM.h>
                            #include <sha204_lib_return_codes.h>
                            #include <sha204_library.h>
                            #include <RunningAverage.h>
                            #include <avr/power.h>
                            #define RELEASE "1.4"
                            #define AVERAGES 2
                            // Child sensor ID's
                            #define CHILD_ID_TEMP  1
                            #define CHILD_ID_HUM   2
                            // Uncomment the line below, to transmit battery voltage as a normal sensor value
                            #define BATT_SENSOR    3
                            // How many milli seconds between each measurement
                            #define MEASURE_INTERVAL 500000
                            // How many milli seconds should we wait for OTA?
                            #define OTA_WAIT_PERIOD 300
                            // FORCE_TRANSMIT_INTERVAL, this number of times of wakeup, the sensor is forced to report all values to the controller
                            #define FORCE_TRANSMIT_INTERVAL 6
                            // When MEASURE_INTERVAL is 60000 and FORCE_TRANSMIT_INTERVAL is 30, we force a transmission every 30 minutes.
                            // Between the forced transmissions a tranmission will only occur if the measured value differs from the previous measurement
                            // HUMI_TRANSMIT_THRESHOLD tells how much the humidity should have changed since last time it was transmitted. Likewise with
                            // TEMP_TRANSMIT_THRESHOLD for temperature threshold.
                            #define HUMI_TRANSMIT_THRESHOLD 0.5
                            #define TEMP_TRANSMIT_THRESHOLD 0.5
                            // Pin definitions
                            //#define TEST_PIN       A0
                            #define LED_PIN        A2
                            #define ATSHA204_PIN   17 // A3
                            const int sha204Pin = ATSHA204_PIN;
                            atsha204Class sha204(sha204Pin);
                            SI7021 humiditySensor;
                            SPIFlash flash(8, 0x1F65);
                            // Sensor messages
                            #ifdef BATT_SENSOR
                            MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
                            // Global settings
                            int measureCount = 0;
                            int sendBattery = 0;
                            boolean isMetric = true;
                            boolean highfreq = true;
                            boolean transmission_occured = false;
                            // Storage of old measurements
                            float lastTemperature = -100;
                            int lastHumidity = -100;
                            long lastBattery = -100;
                            RunningAverage raHum(AVERAGES);
                             * Setup code
                              pinMode(LED_PIN, OUTPUT);
                              digitalWrite(LED_PIN, LOW);
                              Serial.begin(115200);
                              Serial.print(F("Sensebender Micro FW "));
                              Serial.print(RELEASE);
                              Serial.flush();
                              // First check if we should boot into test mode
                              //pinMode(TEST_PIN,INPUT);
                              //digitalWrite(TEST_PIN, HIGH); // Enable pullup
                              //if (!digitalRead(TEST_PIN)) testMode();
                              // Make sure that ATSHA204 is not floating
                              pinMode(ATSHA204_PIN, INPUT);
                              digitalWrite(ATSHA204_PIN, HIGH);
                              //digitalWrite(TEST_PIN,LOW);
                              digitalWrite(LED_PIN, HIGH);
                              humiditySensor.begin();
                              delay (200);
                              Serial.flush();
                              Serial.println(F(" - Online!"));
                              isMetric = getControllerConfig().isMetric;
                              Serial.print(F("isMetric: ")); Serial.println(isMetric);
                              raHum.clear();
                              sendTempHumidityMeasurements(false);
                              sendBattLevel(false);
                            #ifdef MY_OTA_FIRMWARE_FEATURE
                              Serial.println("OTA FW update enabled");
                            void presentation()  {
                              sendSketchInfo("Sensebender Micro", RELEASE);
                              present(CHILD_ID_TEMP,S_TEMP);
                              present(CHILD_ID_HUM,S_HUM);
                            #ifdef BATT_SENSOR
                              present(BATT_SENSOR, S_POWER);
                             *  Main loop function
                              measureCount ++;
                              sendBattery ++;
                              bool forceTransmit = false;
                              if ((measureCount == 5) && highfreq)
                                clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
                                highfreq = false;
                              if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                                forceTransmit = true;
                                measureCount = 0;
                            /*  if (sendBattery > 60)
                                 sendBattLevel(forceTransmit); // Not needed to send battery info that often
                                 sendBattery = 0;
                              if (transmission_occured) {
                                  wait(OTA_WAIT_PERIOD);
                              sleep(MEASURE_INTERVAL);
                             * Sends temperature and humidity from Si7021 sensor
                             * Parameters
                             * - force : Forces transmission of a value (even if it's the same as previous measurement)
                            void sendTempHumidityMeasurements(bool force)
                              bool tx = force;
                              si7021_env data = humiditySensor.getHumidityAndTemperature();
                              raHum.addValue(data.humidityPercent);
                              float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
                              float diffHum = abs(lastHumidity - raHum.getAverage());
                              Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                              Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                              if (isnan(diffHum)) tx = true;
                              if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
                              if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
                              if (tx) {
                                measureCount = 0;
                                float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                                int humidity = data.humidityPercent;
                                Serial.print(F("T: "));Serial.println(temperature);
                                Serial.print(F("H: "));Serial.println(humidity);
                                send(msgTemp.set(temperature,1));
                                send(msgHum.set(humidity));
                                Serial.println(F("Sent to GW"));
                                lastTemperature = temperature;
                                lastHumidity = humidity;
                                transmission_occured = true;
                                if (sendBattery > 60) {
                                 sendBattLevel(true); // Not needed to send battery info that often
                                 sendBattery = 0;
                             * Sends battery information (battery percentage)
                             * Parameters
                            void sendBattLevel(bool force)
                              if (force) lastBattery = -1;
                              long vcc = readVcc();
                              if (vcc != lastBattery) {
                                lastBattery = vcc;
                            #ifdef BATT_SENSOR
                                float send_voltage = float(vcc)/1000.0f;
                                send(msgBatt.set(send_voltage,2));
                                // Calculate percentage
                                vcc = vcc - 1900; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
                                long percent = vcc / 13.0;
                                sendBatteryLevel(percent);
                             * Internal battery ADC measuring
                            long readVcc() {
                              #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
                                ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
                              #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
                                ADMUX = _BV(MUX5) | _BV(MUX0);
                              #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
                                ADcdMUX = _BV(MUX3) | _BV(MUX2);
                              #else
                              long result = (high<<8) | low;
                             * Verify all peripherals, and signal via the LED if any problems.
                            void testMode()
                              uint8_t rx_buffer[SHA204_RSP_SIZE_MAX];
                              uint8_t ret_code;
                              byte tests = 0;
                              digitalWrite(LED_PIN, HIGH); // Turn on LED.
                              Serial.println(F(" - TestMode"));
                              Serial.println(F("Testing peripherals!"));
                              Serial.flush();
                              Serial.print(F("-> SI7021 : "));
                              Serial.flush();
                              if (humiditySensor.begin())
                                Serial.println(F("ok!"));
                                tests ++;
                              else
                                Serial.println(F("failed!"));
                              Serial.flush();
                              Serial.print(F("-> Flash : "));
                              Serial.flush();
                              if (flash.initialize())
                                tests ++;
                              else
                              Serial.flush();
                              Serial.print(F("-> SHA204 : "));
                              ret_code = sha204.sha204c_wakeup(rx_buffer);
                              Serial.flush();
                              if (ret_code != SHA204_SUCCESS)
                                Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
                              Serial.flush();
                              if (ret_code == SHA204_SUCCESS)
                                ret_code = sha204.getSerialNumber(rx_buffer);
                                  Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
                                else
                                  Serial.print(F("Ok (serial : "));
                                  for (int i=0; i<9; i++)
                                    if (rx_buffer[i] < 0x10)
                                      Serial.print('0'); // Because Serial.print does not 0-pad HEX
                                    Serial.print(rx_buffer[i], HEX);
                                  Serial.println(")");
                                  tests ++;
                              Serial.flush();
                              Serial.println(F("Test finished"));
                              if (tests == 3)
                                Serial.println(F("Selftest ok!"));
                                while (1) // Blink OK pattern!
                                  delay(200);
                                  delay(200);
                              else
                                Serial.println(F("----> Selftest failed!"));
                                while (1) // Blink FAILED pattern! Rappidly blinking..
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              OK, I have just found out that others are reporting 27uA overheads so my 24uA is conservative. Another Sensebender +nrf24l01+ I have is about 24.5uA during sleeping
