  3. ESP8266 offline loop
4 Posts 1 Posters 2.4k Views 3 Watching
  • B
    B
    blacksheepinc
    Dear all,
    I would like to make my ESP gateway to be able to do something even though if it is offline/trying to connect to wifi or MQTT.
    I've made a test, I restart my router but the ESP gives an error and restart itself.
    Here is the log: (the repetative 6,3,1 is the WiFi.status() printed)
    Ȥl⸮⸮⸮H⸮⸮⸮D:h⸮?⸮⸮0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGE--,VER=2.1.1
    sta config unchangedscandone
    f 0, scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 2
    cnt
    connected with Xiaomi, channel 1
    ip:192.168.1.202,mask:255.255.255.0,gw:192.168.1.1
    wifi evt: 0
    wifi evt: 3
    .WIFI connected - IP: 192.168.1.202
    0;255;3;0;9;MCO:BGN:STP
    Booting
    OTA server at: esp8266-30dde1.local:8266
    Ready
    0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
    :ref 1
    :wr
    :sent 22
    :rn 4
    :ww
    :c0 1, 4
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: mygateway-out/1/255/0/0/17
    :wr
    :sent 35
    :ww
    0;255;3;0;9;Sending message on topic: mygateway-out/1/255/3/0/11
    :wr
    :sent 54
    :ww
    0;255;3;0;9;Sending message on topic: mygateway-out/1/255/3/0/12
    :wr
    :sent 33
    :ww
    0;255;3;0;9;Sending message on topic: mygateway-out/1/0/0/0/3
    :wr
    :sent 27
    :ww
    0;255;3;0;9;Sending message on topic: mygateway-out/1/1/0/0/3
    :wr
    :sent 27
    :ww
    :wr
    :sent 29
    :rn 5
    :ww
    Request old state
    0;255;3;0;9;Sending message on topic: mygateway-out/1/0/2/0/2
    :wr
    :sent 27
    :ww
    :c0 1, 5
    :rn 27
    :c0 1, 27
    0;255;3;0;9;Message arrived on topic: mygateway-in/1/0/1/0/2
    -----------START SEND TO HARDWARE-------------------------
    relay no.:0, relay pin no.:5, new relay state:0
    -----------END SEND TO HARDWARE-------------------------
    Incoming change for sensor:0, New status: 0
    0;255;3;0;9;Sending message on topic: mygateway-out/1/1/2/0/2
    :wr
    :sent 27
    :ww
    :rn 27
    :c0 1, 27
    0;255;3;0;9;Message arrived on topic: mygateway-in/1/1/1/0/2
    relay no.:1, relay pin no.:0, new relay state:0
    Incoming change for sensor:1, New status: 0
    3 -- this the WiFi.status() printed to serial approx every sec
    pm open,type:2 0
    ////// SOMEWHERE HERE I REBOOTED MY ROUTER SWITCHING OFF IT'S WIFI
    bcn_timout,ap_probe_send_start // GIVES THIS ERROR FIRST
    ap_probe_send over, rest wifi status to disassoc
    state: 5 -> 0 (1)
    rm 0
    pm close 7
    f r0, wifi evt: 1
    STA disconnect: 200
    :ur 1
    :close
    :del
    :ur 1
    Panic C:\Users\M⸮rk\Documents\Arduino\libraries\MySensors/core/MyMainESP8266.cpp:140 loop_task // then it resets itself
    ctx: sys
    sp: 3ffffdd0 end: 3fffffb0 offset: 01b0
    >>>stack>>>  ///Sometimes this stack is much longer
    3fffff80:  4021f672 3fffdab0 00000000 3ffeefd0
    3fffff90:  00000000 3fffdad0 3ffeefbc 402023e0
    3fffffa0:  40000f49 40000f49 3fffdab0 40000f49
    <<<stack<<<
    ⸮⸮⸮⸮L⸮⸮DH⸮0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGE--,VER=2.1.1
    f 0, scandone
    no Xiaomi found, reconnect after 1s
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f -180, .6
    .6
    .6
    .6
    scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f r0, .6
    .6
    .6
    .6
    .scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f 0, 1
    .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f -180, .1
    .1
    .1
    .1
    .scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f r0, 1
    .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f 0, .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    .reconnect
    f -180, 1
    .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f r0, .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    .reconnect
    f 0, 1
    .1
    .1
    .1
    .scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f -180, .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f r0, .1
    .1
    .1
    .1
    .scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f 0, .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f -180, .1
    .1
    .1
    .1
    .scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f r0, 1
    .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f 0, .1
    .1
    .1
    .1
    .scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f -180, 1
    .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f r0, .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    .reconnect
    f 0, 1
    .1
    .1
    .1
    .1
    scandone
    wifi evt: 1
    STA disconnect: 201
    reconnect
    f -180, .1
    .1
    .1
    .1
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 1
    cnt
    chg_B1:-140
    .6
    wifi evt: 0
    wifi evt: 3
    Booting
    Ready
    chg_B1:-100
    chg_B1:-60
    :err -8
    Request old state
    :ref 1
    :wr
    :sent 22
    :rn 4
    :ww
    :c0 1, 4
    :wr
    :sent 35
    :ww
    :wr
    :sent 54
    :ww
    :wr
    :sent 33
    :ww
    :wr
    :sent 27
    :ww
    :wr
    :sent 27
    :ww
    :wr
    :sent 29
    :rn 5
    :ww
    :wr
    :sent 27
    :ww
    :c0 1, 5
    :rn 27
    :c0 1, 27
    pm open,type:2 0
    What should I do to be able to still run the loop while it is trying to reconnect?
    Thank you!
    Mark
    B 2 Replies Last reply
    • B blacksheepinc
      Dear all,
      f 0, scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 2
      cnt
      wifi evt: 0
      wifi evt: 3
      Booting
      Ready
      :ref 1
      :wr
      :sent 22
      :rn 4
      :ww
      :c0 1, 4
      :wr
      :sent 35
      :ww
      :wr
      :sent 54
      :ww
      :wr
      :sent 33
      :ww
      :wr
      :sent 27
      :ww
      :wr
      :sent 27
      :ww
      :wr
      :sent 29
      :rn 5
      :ww
      Request old state
      :wr
      :sent 27
      :ww
      :c0 1, 5
      :rn 27
      :c0 1, 27
      :wr
      :sent 27
      :ww
      :rn 27
      :c0 1, 27
      pm open,type:2 0
      state: 5 -> 0 (1)
      rm 0
      pm close 7
      f r0, wifi evt: 1
      STA disconnect: 200
      :ur 1
      :close
      :del
      :ur 1
      ctx: sys
      <<<stack<<<
      f 0, scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f -180, .6
      .6
      .6
      .6
      scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f r0, .6
      .6
      .6
      .6
      .scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f 0, 1
      .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f -180, .1
      .1
      .1
      .1
      .scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f r0, 1
      .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f 0, .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      .reconnect
      f -180, 1
      .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f r0, .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      .reconnect
      f 0, 1
      .1
      .1
      .1
      .scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f -180, .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f r0, .1
      .1
      .1
      .1
      .scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f 0, .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f -180, .1
      .1
      .1
      .1
      .scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f r0, 1
      .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f 0, .1
      .1
      .1
      .1
      .scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f -180, 1
      .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f r0, .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      .reconnect
      f 0, 1
      .1
      .1
      .1
      .1
      scandone
      wifi evt: 1
      STA disconnect: 201
      reconnect
      f -180, .1
      .1
      .1
      .1
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 1
      cnt
      chg_B1:-140
      .6
      wifi evt: 0
      wifi evt: 3
      Booting
      Ready
      chg_B1:-100
      chg_B1:-60
      :err -8
      Request old state
      :ref 1
      :wr
      :sent 22
      :rn 4
      :ww
      :c0 1, 4
      :wr
      :sent 35
      :ww
      :wr
      :sent 54
      :ww
      :wr
      :sent 33
      :ww
      :wr
      :sent 27
      :ww
      :wr
      :sent 27
      :ww
      :wr
      :sent 29
      :rn 5
      :ww
      :wr
      :sent 27
      :ww
      :c0 1, 5
      :rn 27
      :c0 1, 27
      pm open,type:2 0
      Thank you!
      Mark
      B
      B
      blacksheepinc
      @blacksheepinc bump
      B 1 Reply Last reply
      • B blacksheepinc
        @blacksheepinc bump
        B
        B
        blacksheepinc
        @blacksheepinc anyone?
        • B blacksheepinc
          Dear all,
          f 0, scandone
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 2
          cnt
          wifi evt: 0
          wifi evt: 3
          Booting
          Ready
          :ref 1
          :wr
          :sent 22
          :rn 4
          :ww
          :c0 1, 4
          :wr
          :sent 35
          :ww
          :wr
          :sent 54
          :ww
          :wr
          :sent 33
          :ww
          :wr
          :sent 27
          :ww
          :wr
          :sent 27
          :ww
          :wr
          :sent 29
          :rn 5
          :ww
          Request old state
          :wr
          :sent 27
          :ww
          :c0 1, 5
          :rn 27
          :c0 1, 27
          :wr
          :sent 27
          :ww
          :rn 27
          :c0 1, 27
          pm open,type:2 0
          state: 5 -> 0 (1)
          rm 0
          pm close 7
          f r0, wifi evt: 1
          STA disconnect: 200
          :ur 1
          :close
          :del
          :ur 1
          ctx: sys
          <<<stack<<<
          f 0, scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f -180, .6
          .6
          .6
          .6
          scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f r0, .6
          .6
          .6
          .6
          .scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f 0, 1
          .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f -180, .1
          .1
          .1
          .1
          .scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f r0, 1
          .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f 0, .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          .reconnect
          f -180, 1
          .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f r0, .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          .reconnect
          f 0, 1
          .1
          .1
          .1
          .scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f -180, .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f r0, .1
          .1
          .1
          .1
          .scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f 0, .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f -180, .1
          .1
          .1
          .1
          .scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f r0, 1
          .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f 0, .1
          .1
          .1
          .1
          .scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f -180, 1
          .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f r0, .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          .reconnect
          f 0, 1
          .1
          .1
          .1
          .1
          scandone
          wifi evt: 1
          STA disconnect: 201
          reconnect
          f -180, .1
          .1
          .1
          .1
          scandone
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 1
          cnt
          chg_B1:-140
          .6
          wifi evt: 0
          wifi evt: 3
          Booting
          Ready
          chg_B1:-100
          chg_B1:-60
          :err -8
          Request old state
          :ref 1
          :wr
          :sent 22
          :rn 4
          :ww
          :c0 1, 4
          :wr
          :sent 35
          :ww
          :wr
          :sent 54
          :ww
          :wr
          :sent 33
          :ww
          :wr
          :sent 27
          :ww
          :wr
          :sent 27
          :ww
          :wr
          :sent 29
          :rn 5
          :ww
          :wr
          :sent 27
          :ww
          :c0 1, 5
          :rn 27
          :c0 1, 27
          pm open,type:2 0
          Thank you!
          Mark
          B
          B
          blacksheepinc
          @blacksheepinc It is a watchdog reset, thats fix. But idk if it's software or hardware.
          The booting init (baud rate 115000) says it is hardware reset, but system_get_rst_info() says it is Software watchdog reset. Which is probably not true, because it resets it's GPIO states.
