  3. Timer Help
Timer Help
10 Posts 3 Posters 3.0k Views 3 Watching
  • Bruno CunhaB Offline
    Bruno Cunha
    Hi,´
    I have this timer, where when a button is pressed it activates a relay for some time, the duration is regulated by a potenciometer.
    int potPin = A1;
    const int buttonPin = A2;
    Serial.begin(9600);
    pinMode(ledPin, OUTPUT);
    pinMode(buttonPin, INPUT);
    int buttonState = digitalRead(buttonPin);
    int val = analogRead(potPin);
    long tempo = (val*19.550342131);
    Serial.print(tempo);
    Serial.print("tempo:");
    // read the value from the sensor
    if (buttonState==HIGH) {
    digitalWrite(ledPin, HIGH);
    delay(tempo);
    digitalWrite(ledPin, LOW);
    } else {}; // turn the ledPin off
    delay(500);
    Thats the code, my problem is that when i press de button, the arduino stops reading the code while it is counting, can anyone show me a way to keep running the code, but counting the time?
    Thank you
    • D Offline
      It would help if your code was indented and put in a code block. When posting, click the </> icon and paste your indented code, or paste it in and put a line before and one after your code that has 3 backticks ( ` ). That is how to signify a code block.
        Bruno Cunha
        int potPin = A1;
        Serial.begin(9600);
        delay(tempo);
        delay(500);
        Like this
        • D Offline
          Thank you.. Much easier to read.
          • D Offline
            What if you did something like this:
            int potPin = A1;
            int counter = 0;
              Serial.begin(9600);
              Serial.println("tempo:");
              //While the ledPin/relay is on, increment and check the counter
              if (digitalRead(ledPin) == HIGH) {
                counter ++;
                //Only reset if the counter is over tempo, otherwise continue with loop
                if (counter > tempo) {
                  //reset the counter
                  counter = 0;
              delay(500);
            Notice how the above code is double space indented. Having it in the code block does help readability, but indenting helps even more.
              Bruno Cunha
              Well that remains a problem, the relay keeps turning in and off even if i dont press the button...
              • D Offline
                Can we see how you have things hooked up? Show us your schematic.
                  Bruno Cunha
                  https://circuits.io/circuits/4669781-the-unnamed-circuit
                  Well is something like that
                  • T Offline
                    T Offline
                    Topdawg2881
                    The main problem is that you are delaying the tempo time. When you use "delay" everything stops for that amount of time. Try using millis. compare current millis to val and if it is greater than a set amount do something else.
                    Thomas
                    D 1 Reply Last reply
                    • T Topdawg2881
                      Thomas
                      @Topdawg2881 that's where I was going with my example. There is still the delay(500) that I left in from his code, but that's a short delay.
