  3. Multiple DHT-22 sensor problem
6 Posts 3 Posters 3.5k Views 3 Watching
  • S
    Slimz
    Hi All,
    I'm building my first sensor project and now have hit a wall. My project is a multi temp and humidity sensor for egg incubators. I want to have 5 DHTs, 4 for incubators and 1 for room temp and humidity.
    I'm using an Arduino Nano for the sensors, Pi Ethernet gateway both using NRF24 radios. I have Home Assistant up and running as the controller.
    I started with the one DHT and have everything working, so the Arduino is fine, gateway is good, radios good and I can read them in HA. I then added two more DHTs, made my best guess at the code, this is my first attempt at EE, but it seemed to work! I watched HA for days checking the status of the three sensors, they were updating and reading fine. Although very inaccurate.
    Then I updated HA to the latest, a major update, and now I only can read 1 DHT at a time. I don't think it has anything to do with the HA update, but maybe I did something wrong in the sketch, so I'm basically starting over. I have now learned to save the sketches with better names - especially if they work. I just started to see if the SENSOR_TEMP_OFFSET was actually working for the three DHTs, that's going to be important. I think it first showed up as node 1, as in HA it was ****_1_0, *****_1_1, 1_2, and so on, each child was listed and was updating. Now it shows up as node 2, and in the debug it shows 2-2-000 etc.
    BTW, each DHT does work, I can comment out each data_ping, using the child nodes and they work. Just now it will only send the last pin.
    There might be something in the debug file that explains the problem, I do not know what all of it means. Maybe my sketch is totally wrong, but here is what I created-
    // Enable debug prints
    //#define MY_RS485
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET -5
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define DHT_DATA_PIN 4
    #define SENSOR_TEMP_OFFSET 10
    #define CHILD_ID_HUM 2
    #define CHILD_ID_TEMP 3
    #define DHT_DATA_PIN 5
    #define CHILD_ID_HUM 4
    #define CHILD_ID_TEMP 5
    static const uint64_t UPDATE_INTERVAL = 30000;
    static const uint8_t FORCE_UPDATE_N_READS = 2;
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("IncubatorTempnHum", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    Here is the debug - I did see each DHT and child show in the monitor, before it broke. thanks for any help!
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSF:SID:OK,ID=2
    14 TSM:FPAR
    51 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2058 !TSM:FPAR:NO REPLY
    2060 TSM:FPAR
    2096 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2370 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    2375 TSF:MSG:FPAR OK,ID=0,D=1
    4104 TSM:FPAR:OK
    4105 TSM:ID
    4106 TSM:ID:OK
    4108 TSM:UPL
    4111 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4117 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    4122 TSF:MSG:PONG RECV,HP=1
    4124 TSM:UPL:OK
    4126 TSM:READY:ID=2,PAR=0,DIS=1
    4130 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    4137 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4145 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    4154 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4202 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:I
    4209 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=17,sg=0,ft=0,st=OK:IncubatorTempnHum
    4218 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    4227 TSF:MSG:SEND,2-2-0-0,s=4,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4235 TSF:MSG:SEND,2-2-0-0,s=5,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    4240 MCO:REG:REQ
    4244 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4250 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4255 MCO:PIM:NODE REG=1
    4257 MCO:BGN:STP
    4263 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4269 MCO:SLP:TPD
    4271 MCO:SLP:WUP=-1
    4273 MCO:BGN:INIT OK,TSP=1
    4282 TSF:MSG:SEND,2-2-0-0,s=5,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:78.4
    T: 78.36
    4291 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:99.9
    H: 99.90
    4297 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4302 MCO:SLP:TPD
    4304 MCO:SLP:WUP=-1
    4312 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4317 MCO:SLP:TPD
    4318 MCO:SLP:WUP=-1
    4325 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4330 MCO:SLP:TPD
    4332 MCO:SLP:WUP=-1
    4341 TSF:MSG:SEND,2-2-0-0,s=5,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:78.4
    T: 78.36
    4349 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:99.9
    H: 99.90
    4357 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    4362 MCO:SLP:TPD
    S 1 Reply Last reply
    • S Slimz
      Hi All,
      //#define MY_RS485
      #include <DHT.h>
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      13 TSF:SID:OK,ID=2
      14 TSM:FPAR
      2060 TSM:FPAR
      4104 TSM:FPAR:OK
      4105 TSM:ID
      4106 TSM:ID:OK
      4108 TSM:UPL
      4124 TSM:UPL:OK
      4240 MCO:REG:REQ
      4257 MCO:BGN:STP
      4269 MCO:SLP:TPD
      4271 MCO:SLP:WUP=-1
      T: 78.36
      H: 99.90
      4302 MCO:SLP:TPD
      4304 MCO:SLP:WUP=-1
      4317 MCO:SLP:TPD
      4318 MCO:SLP:WUP=-1
      4330 MCO:SLP:TPD
      4332 MCO:SLP:WUP=-1
      T: 78.36
      H: 99.90
      4362 MCO:SLP:TPD
      Slimz
      Hi again,
      Well, I guess I found the solution, of course after my first post looking bad :-)
      I found another post by turborick which helped a lot. I do not know how the first sketch was working, but modified my sketch, defining each DHT and used the sensor offset that might be working. I'll have to do more tests. I left in all the sleep and other commands from the original, just added one for each DHT, again, it seems to work. But I'm crazy, who knows.
      Here is a working sketch for my three DHTs, I'll update if the offsets work. The incubators have to be 99.5 exactly, each sensor needs to be accurate for the alarms. Also the humidity needs to be good or it's useless.
      Here is the working sketch:
      #include <DHT.h>
      #define CHILD_ID_HUM1 1
      #define CHILD_ID_TEMP1 2
      #define DHT1_DATA_PIN 3
      #define SENSOR_TEMP1_OFFSET -2.5
      #define CHILD_ID_HUM2 3
      #define CHILD_ID_TEMP2 4
      #define DHT2_DATA_PIN 4
      #define SENSOR_TEMP2_OFFSET -12.5
      #define CHILD_ID_HUM3 5
      #define CHILD_ID_TEMP3 6
      #define DHT3_DATA_PIN 5
      #define SENSOR_TEMP3_OFFSET 0
      DHT dht1;
      DHT dht2;
      DHT dht3;
      float lastTemp1;
      float lastHum1;
      float lastTemp2;
      float lastHum2;
      float lastTemp3;
      float lastHum3;
      uint8_t nNoUpdatesTemp1;
      uint8_t nNoUpdatesHum1;
      uint8_t nNoUpdatesTemp2;
      uint8_t nNoUpdatesHum2;
      uint8_t nNoUpdatesTemp3;
      uint8_t nNoUpdatesHum3;
      bool metric = true;
      MyMessage msgHum1(CHILD_ID_HUM1, V_HUM);
      MyMessage msgTemp1(CHILD_ID_TEMP1, V_TEMP);
      MyMessage msgHum2(CHILD_ID_HUM2, V_HUM);
      MyMessage msgTemp2(CHILD_ID_TEMP2, V_TEMP);
      MyMessage msgHum3(CHILD_ID_HUM3, V_HUM);
      MyMessage msgTemp3(CHILD_ID_TEMP3, V_TEMP);
        sendSketchInfo("IncubatorTempAndHum", "1.1");
        present(CHILD_ID_HUM1, S_HUM);
        present(CHILD_ID_TEMP1, S_TEMP);
        present(CHILD_ID_HUM2, S_HUM);
        present(CHILD_ID_TEMP2, S_TEMP);
        present(CHILD_ID_HUM3, S_HUM);
        present(CHILD_ID_TEMP3, S_TEMP);
        dht1.setup(DHT1_DATA_PIN);
        dht2.setup(DHT2_DATA_PIN);
        dht3.setup(DHT3_DATA_PIN);
        sleep(dht1.getMinimumSamplingPeriod());
        sleep(dht2.getMinimumSamplingPeriod());
        sleep(dht3.getMinimumSamplingPeriod());
        dht1.readSensor(true);
        dht2.readSensor(true);
        dht3.readSensor(true);
        float temperature1 = dht1.getTemperature();
        if (isnan(temperature1)) {
          Serial.println("Failed reading temperature from DHT1!");
        } else if (temperature1 != lastTemp1 || nNoUpdatesTemp1 == FORCE_UPDATE_N_READS) {
          lastTemp1 = temperature1;
          if (!metric) {
            temperature1 = dht1.toFahrenheit(temperature1);
          nNoUpdatesTemp1 = 0;
          temperature1 += SENSOR_TEMP1_OFFSET;
          send(msgTemp1.set(temperature1, 1));
          #ifdef MY_DEBUG
          Serial.println(temperature1);
        } else {
          nNoUpdatesTemp1++;
        float humidity1 = dht1.getHumidity();
        if (isnan(humidity1)) {
          Serial.println("Failed reading humidity from DHT1");
        } else if (humidity1 != lastHum1 || nNoUpdatesHum1 == FORCE_UPDATE_N_READS) {
          lastHum1 = humidity1;
          nNoUpdatesHum1 = 0;
          send(msgHum1.set(humidity1, 1));
          #ifdef MY_DEBUG
          Serial.println(humidity1);
        } else {
          nNoUpdatesHum1++;
        float temperature2 = dht2.getTemperature();
        if (isnan(temperature2)) {
          Serial.println("Failed reading temperature from DHT2!");
        } else if (temperature2 != lastTemp2 || nNoUpdatesTemp2 == FORCE_UPDATE_N_READS) {
          lastTemp2 = temperature2;
          if (!metric) {
            temperature2 = dht2.toFahrenheit(temperature2);
          nNoUpdatesTemp2 = 0;
          temperature2 += SENSOR_TEMP2_OFFSET;
          send(msgTemp2.set(temperature2, 1));
          #ifdef MY_DEBUG
          Serial.println(temperature2);
        } else {
          nNoUpdatesTemp2++;
        float humidity2 = dht2.getHumidity();
        if (isnan(humidity2)) {
          Serial.println("Failed reading humidity from DHT2");
        } else if (humidity2 != lastHum2 || nNoUpdatesHum2 == FORCE_UPDATE_N_READS) {
          lastHum2 = humidity2;
          nNoUpdatesHum2 = 0;
          send(msgHum2.set(humidity2, 1));
          #ifdef MY_DEBUG
          Serial.println(humidity2);
        } else {
          nNoUpdatesHum2++;
        float temperature3 = dht3.getTemperature();
        if (isnan(temperature3)) {
          Serial.println("Failed reading temperature from DHT3!");
        } else if (temperature3 != lastTemp3 || nNoUpdatesTemp3 == FORCE_UPDATE_N_READS) {
          lastTemp3 = temperature3;
          if (!metric) {
            temperature3 = dht3.toFahrenheit(temperature3);
          nNoUpdatesTemp3 = 0;
          temperature3 += SENSOR_TEMP3_OFFSET;
          send(msgTemp3.set(temperature3, 1));
          #ifdef MY_DEBUG
          Serial.println(temperature3);
        } else {
          nNoUpdatesTemp3++;
        float humidity3 = dht3.getHumidity();
        if (isnan(humidity3)) {
          Serial.println("Failed reading humidity from DHT3");
        } else if (humidity3 != lastHum3 || nNoUpdatesHum3 == FORCE_UPDATE_N_READS) {
          lastHum3 = humidity3;
          nNoUpdatesHum3 = 0;
          send(msgHum3.set(humidity3, 1));
          #ifdef MY_DEBUG
          Serial.println(humidity3);
        } else {
          nNoUpdatesHum3++;
      • E
        E
        exxamalte
        You have probably seen that the DHT-22 sensor promises an accuracy of +-0.5°C for temperature and +-2% for humidity. So, if are building almost a sort of life-support-system, you may want to think about redundancy, e.g. by joining 2-3 sensors per unit and taking their average value or calculating their relative deviation to avoid surprises and notify you about sensors going awry.
        • E
          E
          exxamalte
          This post is deleted!
          • E exxamalte
            Slimz
            @exxamalte Hi,
            That is a good idea, at least having two DHT-22s for each incubator. I've been thinking how to program the average for each, then present that number to the gateway. Could have alarms in case one goes down and stuff. Sounds like fun.
            Now that my code is working and I'm getting real numbers from the three DHTs, they are accurate. Only .1 - .2 difference between them. So I'm happy with that.
            Thanks!
            Bogus ExceptionB 1 Reply Last reply
            • S Slimz
              @exxamalte Hi,
              Thanks!
              Bogus ExceptionB
              Bogus ExceptionB
              Bogus Exception
              wrote on last edited by Bogus Exception
              @Slimz Speaking of reliability (life support), I was searching for similar posts to what I am experiencing (again) and came across this one.
              I don't see this in the DHT-11s I've tested (dozens), but this is frequent in the DHT-22s (no doubt just my luck)... they dies, and then rise from the dead... Check this out from last night:
              All yesterday, no output from the DHT-22. I tried different pins, and almost tried another library (using SimpleDHT now). I had a 10k resistor between pins 1&2 (Vcc & Data), all to no avail. Also, I couldn't remember if having Vcc on the data pin was normal or not-but it was there...
              I went to bed, a beaten man. Then, the Sensor Fairy (C)2017 came to visit at around 4:00am, and now I have 2 problems:
              1. Why it didn't work, and...
              2. Why it works now.
              Just sharing because this kind of behavior has been common with me and the DHT-22s, and in your situation may not be noticeable. Hopefully you have alerts for env values out of range. If it really matters, I use a trusty BME280.
              good luck!
              "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
              -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
              -ATTiny, ATMega, STM32
              -Geek Channel: https://www.youtube.com/TheSalesEngineer
