  3. OpenHAB
  4. openHAB 2.2 binding
openHAB 2.2 binding
132 Posts 32 Posters 89.6k Views 34 Watching
  • T TimO
    Dear fellow openHAB2 binding users,
    it's time for a new release of the binding. The added functionality is low, but under the hood there were a few changes, so after the refactoring @andreacioni has done at the beginning of this year, I've done some refactoring too, with the objective to fullfil the regulations for an integration into the official openhab2-addons repository.
    I've tried to improve the readability of the configuration and of the code itself.
    This leads to an important point: The current release is not backwards compatible!!
    Whatever is configured (MySensors binding related) will not work anymore with the current release.
    But why?
    • nodeId & childId were Strings in the old bindings and now are Integer
    • skipStartupCheck was renamed to startupCheckEnabled
    If you've configured the things with the *.things file you just have to do two easy steps:
    1. Look for skipStartupCheck and switch it with startupCheckEnabled and reverse the logic (true to false and vice versa)
    2. Look for nodeId="123", childId="456" and remove the quotation marks ", so it will look like: nodeId=123, childId=456
    Copy the new jar file into the addons folder, start OpenHAB2 and you're good to go.
    If you've configured the things in PaperUI the easiest way is to delete all things and rediscover them. Of course in large installations this won't be much fun.
    I hope this won't happen again in further versions! :s
    Fixed in this release:
    • RGB & RGBW corrections
    • Removed bug that prevented autodiscovery of deleted things
    • mysensors.test fragment added / tests moved
    • Static code analysis
    • Move to 2.2.0 Snapshot
    The changes in functionality were small so there is no need to install the new version asap if you are able to forgo the above mentioned functionality.
    Downloads:
    OpenHAB MySensors Binding 2.2.0
    OpenHAB MySensors Binding 2.1.0 (old binding version, with old configuration if you still need it)
    G
    G
    Guillermo Schimmel
    @timo Hi! Do you plan to continue the development into openhab 2.4?
    T 1 Reply Last reply
    • G Guillermo Schimmel
      TimO
      @guillermo-schimmel Yes, the binding is (should) be compatible with OH 2.4 and I continue to hope for an integration in the main repository. ;-)
      I've recently cleaned up the history of my git repository and will look forward to an integration in OH 2.5.
      G 1 Reply Last reply
      • T TimO
        G
        G
        Guillermo Schimmel
        @timo Great news! I'm testing it today. Thanks
          G
          G
          Guillermo Schimmel
          @guillermo-schimmel Hi there, it's me again. Do you still need to remove the other standard mqtt binding for this to work?
          I'm getting HANDLER_INITIALIZING_ERROR.
          • F
            F
            freynder
            @timo said in openHAB 2.2 binding:
            Hi @TimO,
            What is preventing this? I'm willing to help if needed.
            • J
              J
              jimmy loyens
              wrote on last edited by jimmy loyens
              #126
              Hello, I just started to use the mysensors binding 2.2 (moving from serial gateway to ethernet gateway to accomadate MYSController) and I have some (maybe stupid) questions I cant find the answers to (I have been poking around the forum though).
              First off, I have a whole bunch of the same type nodes: child0=battery/child1=humidity/child2=temperature/child3=lightintensity/child4-9 are digital inputs for doors and windows. Are such nodes supported by the binding, and how to configure them? I can find temperature, humidity and lightlevel nodes in the list (paperUI) but how can i combine these?
              Second, can the nodes be automaticly discovered by the binding? In my case i have to add them all manually.
              Third, what are the var1-5 channels for? (is this the answer to my first question?)
              Fourth, what is the difference between the two variable1 channels? in the channel name one says "var1" the other one says "custom"?
              Fifth, is there a comprehencive tutorial out there on how to configure the nodes? (I have looked but cant seem to find one)
              Sixed, when i add any sensor manualy i get a status for it of "UNINITIALIZED - HANDLER_INITIALIZING_ERROR ". The node ID/child ID is online sending data though.
              am i using the latest stable version of the binding? I downloaded it a few weeks ago from eclipse market.
              Any help would be appreciated
              J G 2 Replies Last reply
              • J jimmy loyens
                J
                J
                jimmy loyens
                @jimmy-loyens Ok now i found "some" info on the configuration via things/items files here:https://github.com/tobof/openhab2-addons/wiki/Configuration.
                Is there anything more i should know about?
                I configured an ethernet gateway and1 node with a temp, humidity, lightlevel and battery child. The battery child is not even showing up in paperUI, the other 3 are showing up as a thing (and online, bridge allso) but in control tab of paperUI all channels are shown as NaN.
                • J jimmy loyens
                  G
                  G
                  Guillermo Schimmel
                  @jimmy-loyens said in openHAB 2.2 binding:
                  Yes they can. Use the openhab-mysensors-2.4.0-snapshot binding and they will appear.
                  Good question. I wonder that myself. When you know it please tell me.
                  No there isn't. I think it would be a great idea to write something.
                  I resolved a lot of those messages by restarting the complete OpenHAB. Not cool, but works.
                  Use this:
                  http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.4.0-SNAPSHOT.jar
                  J 1 Reply Last reply
                    Use this:
                    J
                    J
                    jimmy loyens
                    @guillermo-schimmel thanks for the very detailed anser 😀
                    • J jimmy loyens
                      J
                      J
                      jimmy loyens
                      #130
                      This post is deleted!
                      • J
                        J
                        jimmy loyens
                        • K
                          K
                          Klabbe
                          The 2.5-version of the binding does not work out of the box in OpenHAB 3 for me.
                          2020-12-22 22:53:34.555 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.mysensors-2.5.0-SNAPSHOT.jar
                          org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [272]
                          Unresolved requirement: Import-Package: org.eclipse.smarthome.config.core
                              at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
                              at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
                              at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
                              at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
                              at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.6.4]
                              at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
                              at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
                          I guess it might have something to do with this?
                          https://community.openhab.org/t/guide-binding-development-changes-for-openhab-3-from-2-5-x/104134
                          Namespace change of openHAB core classes
                          With the migration of Eclipse Smart Home to openHAB the namespace of all classes in openHAB core needed to be changed. This means all imports done by bindings that refer to org.eclipse.smarthome have been changed to org.openhab.core. With your binding code you can simply do a file level replace of this text string in the java source files to migrate the binding. On linux you can use the following commands in you src/main/java directory:
                          find . -name *.java -exec sed -i "s/org.eclipse.smarthome.core/org.openhab.core/g" {} ;
                          find . -name *.java -exec sed -i "s/org.eclipse.smarthome/org.openhab.core/g" {} ;
