  3. 💬 nRF52832 ESP-LINK Shield for ESP8266 Wemos D1 Mini
25 Posts 6 Posters 5.9k Views 4 Watching
  • Ikes 72000I Ikes 72000
    @NeverDie , thanks, but unfortunately this doesn't work.
    Sketch i upload to nrf:
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #include <nrf.h>
      Serial.begin(460800);
      Serial.println();
      Serial.println("Countdown 3...");
      Serial.flush();
      delay(100);
      Serial.println("Countdown 2...");
      Serial.flush();
      delay(100);
      Serial.println("Countdown 1...");
      Serial.flush();
      delay(100);
      Serial.println("Starting...");
      Serial.flush();
      delay(100);
    uint32_t loopCounter=0;
      Serial.println(loopCounter++);
      Serial.flush();
    Log:
    c:/users/ikes/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 4 bytes
    c:/users/ikes/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .heap by 4 bytes
    c:/users/ikes/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .stack_dummy by 4 bytes
    Le croquis utilise 22984 octets (4%) de l'espace de stockage de programmes. Le maximum est de 524288 octets.
    Target voltage: 3.73V
    Remote debugging using \\.\COM6
    Available Targets:
    No. Att Driver
     1      Nordic nRF52 M3/M4
     2      Nordic nRF52 Access Port
    Attaching to Remote target
    0x000009c4 in ?? ()
    Reading symbols from MyBoardNRF5.ino.elf...done.
    Loading section .text, size 0x59c8 lma 0x0
    Loading section .ARM.exidx, size 0x8 lma 0x59c8
    Loading section .data, size 0xbc lma 0x59d0
    Start address 0x1410, load size 23180
    Transfer rate: 39 KB/sec, 891 bytes/write.
    Temporary breakpoint 1 at 0x1370: file G:\Documents\Arduino\libraries\MySensors/hal/architecture/NRF5/MyMainNRF5.cpp, line 23.
    Starting program: C:\Users\Ikes\AppData\Local\Temp\arduino_build_693731\MyBoardNRF5.ino.elf
    Note: automatically using hardware breakpoints for read-only addresses.
    Temporary breakpoint 1, main ()
        at G:\Documents\Arduino\libraries\MySensors/hal/architecture/NRF5/MyMainNRF5.cpp:23
    23	{
    Program complete!
    Don't see anything in esp-link console.
    NeverDieN
    NeverDieN
    #21
    @Ikes-72000 Did you remember to set the baud rate on your ESP-LINK serial console to 460800 baud?
    Ikes 72000I 1 Reply Last reply
    • NeverDieN NeverDie
      Ikes 72000I
      Ikes 72000I
      Ikes 72000
      @NeverDie, yes, but same, nothing in the console.
      I will check my wiring.
      And what the signification of this in log ?
      23	{
      NeverDieN 1 Reply Last reply
        23	{
        NeverDieN
        NeverDieN
        @Ikes-72000 Maybe it's platform.io related? I don't recognize it.
        Good luck!
          Good luck!
          Ikes 72000I
          Ikes 72000I
          Ikes 72000
          @NeverDie, no, log is from arduino ide.
            NeverDieN
            NeverDieN
            @Ikes-72000 If it were me having these problems, I'd simplify the situation by demounting the nRF board fromt he D1 Mini, then I'd power it, hook it up to a console and see whether I'm getting the count that it should be outputting. At that point what you have is simply a breakout board for the nRF, and it doesn't get any simpler than that.
