  3. Combining code together. Nightmare bug
2 Posts 1 Posters 878 Views 1 Watching
    moskovskiy82
    wrote on last edited by moskovskiy82
    Built a node which would combine together a DHT22 + MQ2 + RGB LED Strip on mosfets + IR Aircond control.
    Problem i am facing
    SENSORS+ IR Aircond code works Github HVAC and Sensor
    Comiled sketch size 16468 bytes
    SENSORS+RGB code works Github RGB and Sensor
    Comiled sketch size 18910 bytes
    By working i mean i ran them for half an hour (this was to rule out my main problem of the board - power supply as it's a 7805 converter which is quite hot) and during these time i was sending commands (strip lit up or send aircond temp + fan speed e.t.c). DHT and MQ2 values were reported as they should - every 60 seconds.
    But when i combine all the code together. Everything works - but only humidity is being reported for sensors every 60 seconds (no temperature from DHT22 or air quality from MQ2 are being reported). I have tried changing the code, different variation and all i could see that these values report "nan". Have already broke my head on this - so desperately need a helping hand.
    This is the code combined. What can it be? Just a tiny extra load on the chip and more power drawn which sets 7805 mad? Or some incompatability in the code? Memory problems?
    Sketch uses 18744 bytes (61%) of program storage space. Maximum is 30720 bytes.
    Global variables use 1391 bytes (67%) of dynamic memory, leaving 657 bytes for local variables. Maximum is 2048 bytes.
    Any push in the direction of fixing it up is much appreciated
    #define SN "Bedroom"
    #define SV "2.1"
    #define MODE_AUTO   1
    #define MODE_HEAT   2
    #define MODE_COOL   3
    #define MODE_DRY    4
    #define MODE_FAN    5
    #define MODE_MAINT  6
    #define FAN_AUTO    0
    #define FAN_1       1
    #define FAN_2       2
    #define FAN_3       3
    #define FAN_4       4
    #define FAN_5       5
    #define VDIR_AUTO   0
    #define VDIR_MANUAL 0
    #define VDIR_SWING  1
    #define VDIR_UP     2
    #define VDIR_MUP    3
    #define VDIR_MIDDLE 4
    #define VDIR_MDOWN  5
    #define VDIR_DOWN   6
    #define HDIR_AUTO   0
    #define HDIR_MANUAL 0
    #define HDIR_SWING  1
    #define HDIR_MIDDLE 2
    #define HDIR_LEFT   3
    #define HDIR_MLEFT  4
    #define HDIR_MRIGHT 5
    #define HDIR_RIGHT  6
    #define MY_NODE_ID 31
    //Disable blinking
    #define MY_DEFAULT_ERR_LED A10
    #define MY_DEFAULT_TX_LED A10
    #define MY_DEFAULT_RX_LED A10
    #define MY_RF24_CE_PIN 8
    #include <DHT.h>
    #include <math.h>
    #include <Wire.h>
    #include <FujitsuHeatpumpIR.h>
    //Define connections
    #define CHILD_ID_HVAC 0
    #define CHILD_ID_LIGHT 1
    #define CHILD_ID_HUM 2
    #define CHILD_ID_TEMP 3
    #define CHILD_ID_MQ 4
    #define DHT_PIN 7
    const int MQ_Pin = A3;
    DHT dht;
    //MQ+DHT
    long MQ_Millis = 0;
    long MQ_interval = 60000;
    long DHT_Millis = 0;
    long DHT_interval = 60000;
    MyMessage msgMQ(CHILD_ID_MQ, V_LEVEL);
    //HVAC
    //Some global variables to hold the states
    int POWER_STATE;
    int TEMP_STATE;
    int FAN_STATE;
    int MODE_STATE;
    int VDIR_STATE;
    int HDIR_STATE;
    String HA_MODE_STATE = "Off";
    String HA_FAN_STATE = "Min";
    IRSenderPWM irSender(3);       // IR led on Arduino digital pin 3, using Arduino PWM
    HeatpumpIR *heatpumpIR = new FujitsuHeatpumpIR();
    MyMessage msgHVACSetPointC(CHILD_ID_HVAC, V_HVAC_SETPOINT_COOL);
    MyMessage msgHVACSpeed(CHILD_ID_HVAC, V_HVAC_SPEED);
    MyMessage msgHVACFlowState(CHILD_ID_HVAC, V_HVAC_FLOW_STATE);
    bool initialValueSent = false;
    //RGB VARS AND PINS
    #define REDPIN 6
    #define GREENPIN 5
    #define BLUEPIN 9
    MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT);
    MyMessage rgbMsg(CHILD_ID_LIGHT, V_RGB);
    MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
    //Global variables
    byte red = 255;
    byte green = 255;
    byte blue = 255;
    byte r0 = 255;
    byte g0 = 255;
    byte b0 = 255;
    char rgbstring[] = "ffffff";
    int on_off_status = 0;
    int dimmerlevel = 100;
    int fadespeed = 0;
    void before()
      dht.setup(DHT_PIN);
      loadState(CHILD_ID_HVAC);
    Serial.begin(115200);
    pinMode(REDPIN, OUTPUT);
    pinMode(GREENPIN, OUTPUT);
    pinMode(BLUEPIN, OUTPUT);
      sendSketchInfo(SN, SV);
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_MQ, S_AIR_QUALITY);
      present(CHILD_ID_LIGHT, S_RGB_LIGHT);
      present(CHILD_ID_HVAC, S_HVAC, "");
    unsigned long DHT_Current_Millis = millis();
    if((unsigned long)(DHT_Current_Millis - DHT_Millis) >= DHT_interval)
        DHT_Millis = DHT_Current_Millis;
        if (isnan(temperature))
          {Serial.println("Failed reading temperature from DHT");}
        if (isnan(humidity))
          {Serial.println("Failed reading humidity from DHT");}
        else
          Serial.print("T: ");
          Serial.println(temperature);
          Serial.print("H: ");
          Serial.println(humidity);
    unsigned long MQ_Current_Millis = millis();
    if((unsigned long)(MQ_Current_Millis - MQ_Millis) >= MQ_interval)
        MQ_Millis = MQ_Current_Millis;
        float mq_reading = analogRead(MQ_Pin);
        if (isnan(mq_reading))
          { Serial.println("Failed mq_reading"); }
        else
        send(msgMQ.set(mq_reading, 1));
        Serial.print("MQ: ");
        Serial.println(mq_reading);
      if (!initialValueSent)
        Serial.println("Sending initial values");
        POWER_STATE = 0;
        MODE_STATE = MODE_AUTO;
        FAN_STATE = 1;
        TEMP_STATE = 24;
        sendHeatpumpCommand();
        sendNewStateToGateway();
        request(CHILD_ID_HVAC, V_HVAC_SETPOINT_COOL);
        wait(3000, C_SET, V_HVAC_SETPOINT_COOL);
        request(CHILD_ID_HVAC, V_HVAC_SPEED);
        wait(3000, C_SET, V_HVAC_SPEED);
        request(CHILD_ID_HVAC, V_HVAC_FLOW_STATE);
        wait(3000, C_SET, V_HVAC_FLOW_STATE);
        //initialValueSent = true;
      static bool first_message_sent = false;
      if ( first_message_sent == false )
        Serial.println( "Sending initial state..." );
        set_hw_status();
        send_status();
        first_message_sent = true;
      if (message.isAck()) {
         //return;
      Serial.print("Incoming message for: ");
      Serial.print(message.sensor);
      int val; //RGB VAR
      String recvData = message.data;
      recvData.trim();
      Serial.println(recvData);
      switch (message.type)
        case V_HVAC_SPEED:
         Serial.println("V_HVAC_SPEED");
         if(recvData.equalsIgnoreCase("auto"))
    	 FAN_STATE = 0;
    	 HA_FAN_STATE = "Auto";
          else if(recvData.equalsIgnoreCase("min"))
             FAN_STATE = 1;
          else if(recvData.equalsIgnoreCase("normal"))
             FAN_STATE = 2;
             HA_FAN_STATE = "Normal";
          else if(recvData.equalsIgnoreCase("max"))
             FAN_STATE = 3;
             HA_FAN_STATE = "Max";
        break;
        case V_HVAC_SETPOINT_COOL:
          Serial.println("V_HVAC_SETPOINT_COOL");
          TEMP_STATE = message.getFloat();
          Serial.println(TEMP_STATE);
        break;
        case V_HVAC_FLOW_STATE:
          Serial.println("V_HVAC_FLOW_STATE");
          if (recvData.equalsIgnoreCase("coolon"))
             POWER_STATE = 1;
             MODE_STATE = MODE_COOL;
             HA_MODE_STATE = "CoolOn";
          else if (recvData.equalsIgnoreCase("heaton"))
             POWER_STATE = 1;
             MODE_STATE = MODE_HEAT;
             HA_MODE_STATE = "HeatOn";
          else if (recvData.equalsIgnoreCase("autochangeover"))
             POWER_STATE = 1;
             HA_MODE_STATE = "AutoChangeOver";
          else if (recvData.equalsIgnoreCase("off"))
             POWER_STATE = 0;
        break;
      case V_RGB:
         Serial.println( "V_RGB command: " );
         Serial.println(message.data);
         long number = (long) strtol( message.data, NULL, 16);
         // Save old value
         strcpy(rgbstring, message.data);
         // Split it up into r, g, b values
         red = number >> 16;
         green = number >> 8 & 0xFF;
         blue = number & 0xFF;
         send_status();
         set_hw_status();
      break;
      case V_LIGHT:
         Serial.println( "V_LIGHT command: " );
         val = atoi(message.data);
         if (val == 0 or val == 1)
             on_off_status = val;
             send_status();
             set_hw_status();
      break;
      case V_DIMMER:
        Serial.print( "V_DIMMER command: " );
        if (val >= 0 and val <=100)
    	  dimmerlevel = val;
    	  send_status();
    	  set_hw_status();
      break;
      case V_VAR1:
        Serial.print( "V_VAR1 command: " );
        if (val >= 0 and val <= 2000)
    	  fadespeed = val;
      break;
    void sendNewStateToGateway() {
      send(msgHVACSetPointC.set(TEMP_STATE));
      wait(1000, C_SET, V_HVAC_SETPOINT_COOL);
      char fan_state[HA_FAN_STATE.length() + 1];
      HA_FAN_STATE.toCharArray(fan_state, HA_FAN_STATE.length() + 1);
      send(msgHVACSpeed.set(fan_state));
      wait(1000, C_SET, V_HVAC_SPEED);
      char mode_state[HA_MODE_STATE.length() + 1];
      HA_MODE_STATE.toCharArray(mode_state, HA_MODE_STATE.length() + 1);
      send(msgHVACFlowState.set(mode_state));
      wait(1000, C_SET, V_HVAC_FLOW_STATE);
    void sendHeatpumpCommand() {
      Serial.println("Power = " + (String)POWER_STATE);
      Serial.println("Mode = " + (String)MODE_STATE);
      Serial.println("Fan = " + (String)FAN_STATE);
      Serial.println("Temp = " + (String)TEMP_STATE);
      heatpumpIR->send(irSender, POWER_STATE, MODE_STATE, FAN_STATE, TEMP_STATE, VDIR_AUTO, HDIR_AUTO);
    void set_rgb(int r, int g, int b) {
      analogWrite(REDPIN, r);
      analogWrite(GREENPIN, g);
      analogWrite(BLUEPIN, b);
    void set_hw_status()
      int r = on_off_status * (int)(red * dimmerlevel/100.0);
      int g = on_off_status * (int)(green * dimmerlevel/100.0);
      int b = on_off_status * (int)(blue * dimmerlevel/100.0);
      if (fadespeed >0)
        float dr = (r - r0) / float(fadespeed);
        float db = (b - b0) / float(fadespeed);
        float dg = (g - g0) / float(fadespeed);
        for (int x = 0;  x < fadespeed; x++)
    		  set_rgb(r0 + dr*x, g0 + dg*x, b0 + db*x);
    		  delay(100);
      set_rgb(r, g, b);
      r0 = r;
      b0 = b;
      g0 = g;
    void send_status()
      send(rgbMsg.set(rgbstring));
      send(lightMsg.set(on_off_status));
      send(dimmerMsg.set(dimmerlevel));
      moskovskiy82
      Well guess it was a bug. Removed some of the include libs. Deleted serial output and ... it worked. Now one more thing to solve but i guess that's another story
