  3. Two Wire Temperature Sensor Convert from older gateway NEED HELP
3 Posts 2 Posters 1.4k Views 1 Watching
  • N
    N
    Newzwaver
    Hi Everyone,
    I am using this old sketch for a two wire temp probe and upgraded to the 2.1.1 gateway and can't figure out what to change to get it to work. Do anyone know of a basic guide? I can't find one.
    #define THERMISTORPIN A0
    #define THERMISTORNOMINAL 10000
    #define TEMPERATURENOMINAL 25
    #define NUMSAMPLES 5
    #define BCOEFFICIENT 3950
    #define SERIESRESISTOR 10000
    const unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
    MyMessage msg(0,V_TEMP);
    int samples[NUMSAMPLES];
    void setup(void) {
    pinMode(THERMISTORPIN, INPUT);
    analogReference(EXTERNAL);
    gw.begin();
    gw.sendSketchInfo("Temperature Sensor", "1.1");
    gw.present(0, S_TEMP);
    void loop(void) {
    gw.process();
    float average;
    // take N samples in a row, with a slight delay
    for (uint8_t i=0; i< NUMSAMPLES; i++) {
    samples[i] = analogRead(THERMISTORPIN);
    delay(10);
    // average all the samples out
    average = 0;
    average += samples[i];
    average /= NUMSAMPLES;
    Serial.print("Average analog reading ");
    Serial.println(average);
    // convert the value to resistance
    average = 1023 / average - 1;
    average = SERIESRESISTOR / average;
    Serial.print("Thermistor resistance ");
    float temperature;
    temperature = average / THERMISTORNOMINAL; // (R/Ro)
    temperature = log(temperature); // ln(R/Ro)
    temperature /= BCOEFFICIENT; // 1/B * ln(R/Ro)
    temperature += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
    temperature = 1.0 / temperature; // Invert
    temperature -= 258.95; // convert to C
    Serial.print("Temperature ");
    Serial.print(temperature);
    Serial.println(" *C");
    gw.send(msg.setSensor(0).set(temperature,1));
    // delay(1000);
    gw.sleep(SLEEP_TIME);
    • scalzS
      scalzS
      wrote on last edited by scalz
      you need to convert your node to MySensors 2.x api. you can see how it looks in MySensors examples and there are also some guidelines here: https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
      • N
        N
        Newzwaver
        Hi
        Thank you for the prompt reply, I will have a look.
