  3. Wall touch sensor
Wall touch sensor
5 Posts 4 Posters 2.2k Views 4 Watching
  • Y Offline
    Y Offline
    Yago Casasnovas
    Hi everyone. I am building a new house and I want to do some home automation. I already have knowledge in Arduino and its sensors/actuators.
    My idea is to have all lights controlled by arduino and relay sets, either from an app/web via Raspberry or directly by wall switches. First I though of using wall push-buttons that would be connected direclty to arduino (5V). Then I thought it would be fancier to have touch sensors instead. For arduino there are already like this one: http://img.dxcdn.com/productimages/sku_230867_1.jpg
    So I am looking for something that does the same but that I can put in the wall. All I have found out there are touch sensors working at 220V and with wireless connection like this one:
    https://www.alibaba.com/product-detail/BroadLink-TC1-UK-standard-1-gang_60557743703.html?spm=a2700.7724857.main07.21.2bd13975bmHL1h&s=p
    I do not want that, instead a wall touch sensor that can be wired directly to arduino (5V).
    Any comment? Help?
    Thanks.
    Boots33B 1 Reply Last reply
    • Y Yago Casasnovas
      Any comment? Help?
      Thanks.
      Boots33B Offline
      Boots33B Offline
      Boots33
      @Yago-Casasnovas If you do a search for touch switch you may find a few ideas. This one might be of use.
      • Y Offline
        Y Offline
        Yago Casasnovas
        Hey thanks for replying @Boots33.
        So as I understand there is no off the shelf solution and I'd have to do some hacking. Is it not strange that nobody is manufacturing something similar?
        Is it so weird to wire the sensors directly to Arduino through the walls? Maybe there would be some interference issues wiring in the same tube, 220V power wires and 5V signal wires?
        Thanks.
        R 1 Reply Last reply
        • Y Yago Casasnovas
          Thanks.
          R Offline
          R Offline
          rvendrame
          @Yago-Casasnovas , the one mentioned by Boots runs a coincell. There is no wire to connect it, just glue anywhere and it will send commands to your controller. The standard one uses 433Mhz (like a garage door remote control), while the hacked version from Nca78 transforms it in 'mySensors enabled'.
          It doesn't control any light though, like the one you found from Broadlink. If you want a module to replace the original switch, wired to the lamp, search for 'Livolo' in the forum and you will find some hacks too.
          ESP8266 GW + mySensors 2.3.2
          Alexa / Google Home
          • ? Offline
            ? Offline
            A Former User
            Check this link out. Be sure to watch his you tube video too.
            https://tech.scargill.net/cheap-as-chips-touch-switch/
