  3. NRF24L01 does not work on scene controller
2 Posts 1 Posters 984 Views 1 Watching
  • J
    J
    Jean Pierre Rojas Vanegas
    Hello!
    I'm new on Mysensors forum. I have and Arduino Mega 2560 and NRF24L01 radio conecter on pins 14 for SCK, 15 for MOSI, 16 for MISO, 17 for CE and 18 for CS. I Have a LIL9481 display configured in the sketchs as CTE32HR on pins 38, 39, 40, 41. The problem is when I boot the program it just does not show anything on the display. I attach the sketck I have so far. Please check it and tell me what can be wrong and how to get the "SceneController" to be displayed. I apologize if the topic is not in the right place, please put it where it should go. Thanks in advance.
    Sketch code:
     * Version 1.0 - Henrik Ekblad
     * http://www.mysensors.org/build/scene_controller
     * Touch Display Scene Controller build using a touch enabled tft display
     * attached to a ATMega 2560. This example fetches time from controller and sends
     * in scene commands to the controller.
     * Short press sends V_SCENE_ON and long press (>0.5sec) sends V_SCENE_OFF.
     * Henrik Ekblad <henrik.ekblad@mysensors.org>
     * This example uses:
     * UTFT library: http://www.henningkarlsen.com/electronics/library.php?id=51
     * Convert your own images here: http://www.henningkarlsen.com/electronics/t_imageconverter565.php
     * The 3v3 output on the ATMega2560 is especially bad. I had to use a step down
     * on the 5V output to get solid transmissions.
     * Connect radio
     * Radio               Arduino Pin
     * GND                 GND
     * 5V  -> Step down -> 3V3   (see buying guide for help finding step-down)
     * SCK                 14
     * MOSI                15
     * MISO                16
     * CE                  17
     * CSN                 18
    // Enable soft spi as radio has a hard time sharing spi
    #define MY_SOFTSPI
    #include <TimeLib.h>
    #include <stdarg.h>
    #include <UTFT.h>
    #include <UTouch.h>
    #include <UTFT_Buttons.h>
    #include <avr/pgmspace.h>
    #include "arial_bold.c"
    #include "ArialNumFontPlus.c"
    #include "logo.c"
    #define CHILD_ID 1
    int LONG_PRESS = 500; // Number of millisecons to trinnger scene off for button push
    int RESEND_DEBOUNCE = 2000; // Number of millisecons interval between sending of same
                                // scene number again.
                                // This is used to avoid unwanted re-trigger when using
                                // a sensetive touch diplay.
    // Add your buttons here. Max is 5 if you still want time at the top.
    char *buttons[] = {
        (char *)"Good Morning",
        (char *)"Clean Up!",
        (char *)"All Lights Off",
        (char *)"Music On/Off"
    const int buttonCount = sizeof(buttons)/sizeof(char *);
    const int padding = 10;
    const int topBarHeight = 60;
    MyMessage on(CHILD_ID, V_SCENE_ON);
    MyMessage off(CHILD_ID, V_SCENE_OFF);
    UTFT myGLCD(CTE32HR,38,39,40,41);
    UTouch  myTouch( 6, 5, 4, 3, 2);
    UTFT_Buttons  myButtons(&myGLCD, &myTouch);
    bool timeReceived = false;
    unsigned long lastTimeUpdate=0, lastRequest=0;
    char timeBuf[20];
      Serial.println("***setup****");
      myGLCD.InitLCD();
      myGLCD.clrScr();
      myGLCD.setFont((uint8_t*)ArialNumFontPlus);
      myGLCD.setColor(100, 255, 100);
      myGLCD.setBackColor(0, 0, 0);
      myGLCD.drawBitmap (0, 0, 60, 60, (unsigned int*)logo);
      myTouch.InitTouch();
      myTouch.setPrecision(PREC_MEDIUM);
      myButtons.setButtonColors(VGA_WHITE, VGA_GRAY, VGA_WHITE, VGA_RED, VGA_BLUE);
      myButtons.setTextFont((uint8_t*)arial_bold);
      int height = (myGLCD.getDisplayYSize()-topBarHeight-(padding*(buttonCount+2)))/buttonCount;
      // Add buttons
      for (int i=0; i<buttonCount;i++) {
        int y = topBarHeight + padding+(i*(height+padding));
        myButtons.addButton( padding, y, myGLCD.getDisplayXSize()-padding*2, height, buttons[i]);
      myButtons.drawButtons();
      // Request time from controller.
      requestTime();
      sendSketchInfo("Scene Ctrl", "1.0");
      present(CHILD_ID, S_SCENE_CONTROLLER);
    void presentation()  {
       Serial.println("***presentation****");
    int lastPressedButton = -1;
    unsigned long lastPressedButtonTime = 0;
      unsigned long now = millis();
       Serial.println("***loop****");
      if (myTouch.dataAvailable()) {
        int pressedButton = myButtons.checkButtons();
        if (pressedButton>=0) {
          bool longPress = millis()-now>(unsigned long)LONG_PRESS;
          if (pressedButton != lastPressedButton || now-lastPressedButtonTime > (unsigned long)RESEND_DEBOUNCE) {
            if (longPress) {
              send(off.set(pressedButton));
              Serial.print("Long pressed: ");
            } else {
              send(on.set(pressedButton));
              Serial.print("Pressed: ");
            Serial.println(pressedButton);
            lastPressedButton = pressedButton;
            lastPressedButtonTime=now;
      // If no time has been received yet, request it every 10 second from controller
      // When time has been received, request update every hour
      if ((!timeReceived && now-lastRequest > (unsigned long)10*1000)
        || (timeReceived && now-lastRequest > (unsigned long)60*1000*60)) {
        Serial.println("requesting time");
        requestTime();
        lastRequest = now;
      // Update time every second
      if (timeReceived && now-lastTimeUpdate > 1000) {
        printTime();
        lastTimeUpdate = now;
    // This is called when a new time value was received
    void receiveTime(unsigned long time) {
      Serial.println("***recive****");
      // Ok, set incoming time
      setTime(time);
      timeReceived = true;
    void printTime() {
      sprintf(timeBuf, "%02d:%02d:%02d", hour(), minute(), second());
      myGLCD.print(timeBuf, 60,7);
    J 1 Reply Last reply
    • J Jean Pierre Rojas Vanegas
      Hello!
      Sketch code:
       * Connect radio
       * Radio               Arduino Pin
       * GND                 GND
       * SCK                 14
       * MOSI                15
       * MISO                16
       * CE                  17
       * CSN                 18
      #define MY_SOFTSPI
      #include <stdarg.h>
      #include <UTFT.h>
      #include <UTouch.h>
      #include "logo.c"
      #define CHILD_ID 1
      char *buttons[] = {
      char timeBuf[20];
        myGLCD.InitLCD();
        myGLCD.clrScr();
        // Add buttons
        requestTime();
              if (longPress) {
              } else {
          requestTime();
          lastRequest = now;
          printTime();
        setTime(time);
      void printTime() {
      J
      J
      @Jean-Pierre-Rojas-Vanegas
      I already found a solition. By default, the MyConfig.h library sets CE, CS, to pins 9, 10, respectively. I simply have to manually set CE and CS on pins 17 and 18. When I connect the gateway, it assigns me an ID and shows me the image on the display.
