  3. multiple door sensors, one arduino
multiple doordoor sensors
4 Posts 4 Posters 4.7k Views 3 Watching
  • O
    O
    Opus40
    Hello every one
    I would like to first thank every one for their help. I have got a lot of sensors up and running and its all working well.
    What I am trying to do is have 3 door sensors running from the one arduino as they will all be in the same room, the garage. I realise that this is probably some thing but how would I go about changing the code to make this happen?
    I appreciate any help.
    thanks
    • E
      E
      ericvdb
      Look at the http://www.mysensors.org/build/temp code. It handles multiple temp sensors but you will get the point.
      • O Opus40
        Hello every one
        thanks
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        wrote on last edited by BulldogLowell
        @Opus40
        you can try like this:
        #include <Bounce2.h>
        #define NUMBER_OF_SWITCHES 3
        Bounce debouncer[NUMBER_OF_SWITCHES];
        int oldValue[NUMBER_OF_SWITCHES];
        byte switchPin[NUMBER_OF_SWITCHES] = {4,5,6}; //<<<<<<<<<<< set your switch pins here
        MyMessage msg(0,V_TRIPPED);
          gw.begin();
          for (int i = 0; i < NUMBER_OF_SWITCHES; i++)
            pinMode(switchPin[i],INPUT_PULLUP);
            debouncer[i] = Bounce();
            debouncer[i].attach(switchPin[i]);
            debouncer[i].interval(5);
            gw.present(i, S_DOOR);
            delay(250);
            debouncer[i].update();
            int value = debouncer[i].read();
            if (value != oldValue[i])
              gw.send(msg.setSensor(i).set(value == HIGH? true : false), false);
            oldValue[i] = value;
        not tested, but compiles....
        • E
          E
          emurr
          The sketch is working!
