  3. DHT 22 & Arduino Nano & Raspberry Pi Domoticz
5 Posts 3 Posters 4.7k Views 3 Watching
  • M Offline
    M Offline
    maciej
    wrote on last edited by maciej
    At first, i would like to say Hi to all of you.
    I have some problem with connecting nodes to my domoticz running in raspberry pi.
    Short description:
    Domoticz on raspberry pi is connected to USB gateway (Arduino nano & nrf24l01 module)
    I use a sketch from mysensors.org examples GatewaySerial
    Sketch:
    * The ArduinoGateway prints data received from sensors on the serial link.
    * The gateway accepts input on seral which will be sent out on radio network.
    * The GW code is designed for Arduino Nano 328p / 16MHz
    * Wire connections (OPTIONAL):
    * - Inclusion button should be connected between digital pin 3 and GND
    * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    I've connected gate to my raspberry and it's work fine ( logs shows that it is connected - and I can see gateway in Hardware in domoticz)
    Nodes - Arduino nano & DHT 22 & nrf24l01 module
    I used sketch from this example: https://www.mysensors.org/build/humidity
    Sketch
     * Version 1.0: Henrik EKblad
    // Enable debug prints
    //#define MY_RS485
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    After connecting everything I can't see any nodes. If I use a simple sketch for DHT sensor in Arduino everything works just fine. For example:
    #include "DHT.h"
    DHT dht;
      Serial.begin(9600);
      Serial.println();
      Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)");
      dht.setup(4); // data pin 2
      Serial.print(dht.getStatusString());
      Serial.print("\t");
      Serial.print(humidity, 1);
      Serial.print("\t\t");
      Serial.print(temperature, 1);
      Serial.println(dht.toFahrenheit(temperature), 1);
    In serial monitor I get:
    Status	Humidity (%)	Temperature (C)	(F)
    OK	46.1		25.2		77.4
    OK	46.0		25.1		77.2
    OK	46.0		25.1		77.2
    OK	46.0		25.1		77.2
    OK	46.0		25.1		77.2
    OK	46.1		25.2		77.4
    OK	46.1		25.1		77.2
    But if I include in even the sample sketch MySensors.h library this what I get from serial monitor:
    ⸮	⸮⸮⸮⸮pnh{⸮⸮⸮
    8⸮;⸮ى8C;⸮⸮z⸮s⸮⸮⸮⸮⸮⸮⸮⸮h⸮⸮z⸮y⸮⸮⸮⸮⸮
    The same situation in sketch: https://www.mysensors.org/build/humidity
    When I remove from this sketch MySensors.h library
    //#include <MySensors.h>
    and related to it lines sketch works also fine:
    T: 25.20
    H: 46.00
    T: 25.10
    H: 45.90
    H: 45.80
    T: 25.10
    T: 25.20
    H: 45.90
    T: 25.10
    H: 45.80
    T: 25.20
    H: 45.90
    Can anyone can halep mi with this problem?
    Regards. Maciej
    • M maciej
      Short description:
      Sketch:
      * LEDs (OPTIONAL):
      Sketch
      //#define MY_RS485
      #include <DHT.h>
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      #include "DHT.h"
      DHT dht;
        Serial.begin(9600);
        Serial.println();
        Serial.print("\t");
      OK	46.1		25.2		77.4
      OK	46.0		25.1		77.2
      OK	46.0		25.1		77.2
      OK	46.0		25.1		77.2
      OK	46.0		25.1		77.2
      OK	46.1		25.2		77.4
      OK	46.1		25.1		77.2
      ⸮	⸮⸮⸮⸮pnh{⸮⸮⸮
      T: 25.20
      H: 46.00
      T: 25.10
      H: 45.90
      H: 45.80
      T: 25.10
      T: 25.20
      H: 45.90
      T: 25.10
      H: 45.80
      T: 25.20
      H: 45.90
      Regards. Maciej
      Welcome to the MySensors community @maciej !
      MySensors uses 115200bps by default. See if changing the serial monitor to that speed helps.
      Alternatively you can use
      #define MY_BAUD_RATE 9600
      before including MySensors.h to instruct MySensors to use 9600bps.
      • M Offline
        M Offline
        maciej
        Thank you @MFALKVIDD for your answer. At this moment I don't have access to Arduino but I'll look into it later this weekend.
        Once again thank you for your answer.
        Regards, Maciej.
        • M Offline
          M Offline
          maciej
          Ok, I've checked the serial monitor speed and now I see whats going on.
          That's what I get from serial monitor:
          3 TSM:INIT
          4 TSF:WUR:MS=0
          11 !TSM:INIT:TSP FAIL
          12 TSM:FAIL:CNT=1
          14 TSM:FAIL:PDT
          10016 TSM:FAIL:RE-INIT
          10018 TSM:INIT
          10024 !TSM:INIT:TSP FAIL
          10028 TSM:FAIL:CNT=2
          10029 TSM:FAIL:PDT
          Any idea?
          Y 1 Reply Last reply
          • M maciej
            3 TSM:INIT
            4 TSF:WUR:MS=0
            12 TSM:FAIL:CNT=1
            14 TSM:FAIL:PDT
            10018 TSM:INIT
            10029 TSM:FAIL:PDT
            Any idea?
            Y Offline
            Y Offline
            @maciej initialization of the radio failed. Quadruple check your wiring, assure the radio is powered from a stable 3v3 supply. If all looks fine test with another module.
