  3. Automated Raised Garden
1 Posts 1 Posters 1.1k Views 2 Watching
  • T
    thumper
    wrote on last edited by thumper
    This is my first MySensors project so figured I would post it in the forum and get some feedback and perhaps some optimization on my code.
    *** Disclaimer ***
    I am new to coding and new to MySensors.
    When I came across MySensors I decided I would build a monitor for a raised garden bed that I wanted. It would be able to monitor various variables and act upon the certain variables of the garden bed. I run Vera as my home automation controller and figured I could use the PLEG addon to control other sensors. Additionally, I wanted to store the variables of the garden bed and allow them to be exported for analysis.
    Some of the things I wanted to monitor:
    • Soil Moisture and Temperature
    • Water Flow
    • Amount of Light
    • Environmental Humidity and Temperature
    Some of the things I wanted to control:
    • Water Valve
    • That's it for now I guess... maybe something more later on??
    So far I have gotten everything working with the exception of the soil temperature as I have not added those sensors yet.
    My other problem is I am unable to get a reading for the flow rate sensor, I get a variable of zero (0) and nothing more even when water is flowing past the sensor. Below is the code I used I am running a Arduino Mega as I have a few laying around from other projects.
    // Lets get that radio working with the Mega
    #define MY_RF24_CE_PIN 49
    #define MY_RF24_CS_PIN 53
    #define MY_REPEATER_FEATURE
    // Pull in those external libraries
    #include <DHT.h>
    // Pin Numbers that the sensors are on and Define some items.
    #define DIGITAL_INPUT_SENSOR 2 // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    // #define Relay uses Digital I/O pins 4-7
    #define DHT1_DATA_PIN 8 // Temperature and Humidity sensor.
    #define DHT2_DATA_PIN 9 // Temperature and Humidity sensor.
    int mositure_sensor_pin1 = A0;
    int mositure_sensor_pin2 = A1;
    // Relay Information
    #define NUMBER_OF_RELAYS 4 // Total number of attached relays
    #define SENSOR_TEMP_OFFSET 0
    // child ID for the sensors
    #define CHILD_ID_HUM1 5 // ID of the DHT humidity sensor child
    // #define CHILD_ID_RELAY 1 // ID of the relay (It is expressed in another area of the code)
    #define CHILD_ID_TEMP1 6 // ID of the DHT temperature sensor child
    #define CHILD_ID_HUM2 7 // ID of the DHT humidity sensor child
    #define CHILD_ID_TEMP2 8 // ID of the DHT temperature sensor child
    #define CHILD_ID_SOIL1 9 // ID of the first soil monitor
    #define CHILD_ID_SOIL2 10 // ID of the second soil monitor
    #define CHILD_ID_FLOW 11 // ID of the water flow sensor
    float lastTemp1;
    float lastHum1;
    float lastTemp2;
    float lastHum2;
    uint8_t nNoUpdatesTemp1;
    uint8_t nNoUpdatesHum1;
    uint8_t nNoUpdatesTemp2;
    uint8_t nNoUpdatesHum2;
    bool metric = true;
    // Water flow sensor information
    //#define PULSE_FACTOR 12500                    // Nummber of blinks per m3 of your meter (One rotation/liter)
    #define PULSE_FACTOR 288000
    #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
    #define MAX_FLOW 25                             // Max flow (l/min) value to report. This filetrs outliers.
    #define INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
    unsigned long SEND_FREQUENCY = 10000;           // Minimum time between send (in miliseconds). We don't want to spam the gateway.
    double ppl = ((double)PULSE_FACTOR)/1000;       // Pulses per liter
    volatile double flow = 0;
    bool pcReceived = false;
    unsigned long newBlink = 0;
    double oldflow = 0;
    double volume;
    double oldvolume;
    unsigned long lastSend;
    unsigned long lastPulse;
    unsigned long currentTime;
    // End water flow information
    // Here we are setting up some water thresholds that we will
    // use later. Note that you will need to change these to match
    // your soil type and environment. It doesn't do much for me because I'm using domoticz
    int thresholdUp = 400;
    int thresholdDown = 075;
     // Message from the Sensors
    MyMessage msgHum1(CHILD_ID_HUM1, V_HUM);
    MyMessage msgTemp1(CHILD_ID_TEMP1, V_TEMP);
    MyMessage msgHum2(CHILD_ID_HUM2, V_HUM);
    MyMessage msgTemp2(CHILD_ID_TEMP2, V_TEMP);
    MyMessage msgSoil1(CHILD_ID_SOIL1, V_LEVEL);
    MyMessage msgSoil2(CHILD_ID_SOIL2, V_LEVEL);
    DHT dht1;
    DHT dht2;
    MyMessage flowMsg(CHILD_ID_FLOW, V_FLOW);
    MyMessage volumeMsg(CHILD_ID_FLOW, V_VOLUME);
    MyMessage pcMsg(CHILD_ID_FLOW, V_VAR1);
    void before()
            //  Start of the Relay before all other sections
            pinMode(pin, OUTPUT);
            // End of the Relay before all other sections
      // Start of the DHT setup
      dht1.setup(DHT1_DATA_PIN); // set data pin of DHT sensor
      if (UPDATE_INTERVAL <= dht1.getMinimumSamplingPeriod()) {
      sleep(dht1.getMinimumSamplingPeriod());
      // End of the DHT Setup
      dht2.setup(DHT2_DATA_PIN); // set data pin of DHT sensor
      if (UPDATE_INTERVAL <= dht2.getMinimumSamplingPeriod()) {
      sleep(dht2.getMinimumSamplingPeriod());
      // Begin Water Flow Setup
      //begin(incomingMessage, AUTO, true);
      //begin(incomingMessage, AUTO, false, AUTO, RF24_PA_LOW);
      //begin(incomingMessage, AUTO, false, AUTO);
      //  send(pcMsg.set(0));
      //  send(volumeMsg.set(0.000, 3));
      //Water meter setup
      //Serial.print("PPL:");
      //Serial.print(ppl);
      request(CHILD_ID_FLOW, V_VAR1);
      //pulseCount = oldPulseCount = 0;
      //Serial.print("Last pulse count from gw:");
      //Serial.println(pulseCount);
      attachInterrupt(INTERRUPT, onPulse, RISING);
      lastSend = millis();
      // End Water Flow Setup
        sendSketchInfo("Garden Controller", "1.0");
        // Relay Presentation/Register all sensors to Gateway
            present(sensor, S_BINARY);
        // DHT Presentation/Register all sensors to Gateway (they will be created as child devices)
        present(CHILD_ID_HUM1, S_HUM);
        present(CHILD_ID_TEMP1, S_TEMP);
        present(CHILD_ID_HUM2, S_HUM);
        present(CHILD_ID_TEMP2, S_TEMP);
       // Soil moisture sensor Presentation/Register this device as Moisture sensor
        present(CHILD_ID_SOIL1, S_MOISTURE);
        present(CHILD_ID_SOIL2, S_MOISTURE);
       // Register this device as Waterflow sensor
        present(CHILD_ID_FLOW, S_WATER);
      // Start the DHT Sensor loop
      dht1.readSensor(true);
      float temperature1 = dht1.getTemperature();
      if (isnan(temperature1)) {
        Serial.println("Failed to read the temperature from DHT");
      } else if (temperature1 != lastTemp1 || nNoUpdatesTemp1 == FORCE_UPDATE_N_READS) {
        lastTemp1 = temperature1;
        if (!metric) {
          temperature1 = dht1.toFahrenheit(temperature1);
        // Reset no updates counter
        nNoUpdatesTemp1 = 0;
        temperature1 += SENSOR_TEMP_OFFSET;
        send(msgTemp1.set(temperature1, 1));
        #ifdef MY_DEBUG
        Serial.print("Temperature: ");
        Serial.println(temperature1);
      } else {
        nNoUpdatesTemp1++;
      float humidity1 = dht1.getHumidity();
      if (isnan(humidity1)) {
        Serial.println("Failed to read the humidity from DHT");
      } else if (humidity1 != lastHum1 || nNoUpdatesHum1 == FORCE_UPDATE_N_READS) {
        lastHum1 = humidity1;
        nNoUpdatesHum1 = 0;
        send(msgHum1.set(humidity1, 1));
        #ifdef MY_DEBUG
        Serial.print("Humidity: ");
        Serial.println(humidity1);
      } else {
        nNoUpdatesHum1++;
     // End the DHT Sensor Loop
     dht2.readSensor(true);
     float temperature2 = dht2.getTemperature();
     if (isnan(temperature2)) {
     } else if (temperature2 != lastTemp2 || nNoUpdatesTemp2 == FORCE_UPDATE_N_READS) {
       lastTemp2 = temperature2;
       if (!metric) {
         temperature2 = dht2.toFahrenheit(temperature2);
       nNoUpdatesTemp2 = 0;
       temperature2 += SENSOR_TEMP_OFFSET;
       send(msgTemp2.set(temperature2, 2));
       #ifdef MY_DEBUG
       Serial.println(temperature2);
     } else {
       nNoUpdatesTemp2++;
     float humidity2 = dht2.getHumidity();
     if (isnan(humidity2)) {
     } else if (humidity2 != lastHum2 || nNoUpdatesHum2 == FORCE_UPDATE_N_READS) {
       lastHum2 = humidity2;
       nNoUpdatesHum2 = 0;
       send(msgHum2.set(humidity2, 2));
       #ifdef MY_DEBUG
       Serial.println(humidity2);
     } else {
       nNoUpdatesHum2++;
       // Start Water Flow Loop
       currentTime = millis();
       bool sendTime = currentTime - lastSend > SEND_FREQUENCY;
       if (pcReceived && (SLEEP_MODE || sendTime)) {
         // New flow value has been calculated
         if (!SLEEP_MODE && flow != oldflow) {
           // Check that we dont get unresonable large flow value.
           // could hapen when long wraps or false interrupt triggered
           if (flow<((unsigned long)MAX_FLOW)) {
             send(flowMsg.set(flow, 2));        // Send flow value to gw
           //Serial.print("l/min: ");
           //Serial.println(flow);
           oldflow = flow;
         // No Pulse count in 2min
         if(currentTime - lastPulse > 20000){
           flow = 0;
         // Pulse count has changed
         if (pulseCount != oldPulseCount) {
           send(pcMsg.set(pulseCount));                  // Send  volumevalue to gw VAR1
           double volume = ((double)pulseCount/((double)PULSE_FACTOR)*264.172);
           //double volume = ((double)pulseCount/((double)PULSE_FACTOR));
           oldPulseCount = pulseCount;
           Serial.print("Pulse count:");
           if (volume != oldvolume) {
             send(volumeMsg.set(volume, 3));               // Send volume value to gw
             //Serial.print("m3: ");
             //Serial.println(volume);
             oldvolume = volume;
         lastSend = currentTime;
       else if (sendTime) {
         // No count received. Try requesting it again
         lastSend=currentTime;
       // End Water Flow Lop
      sleep(UPDATE_INTERVAL);
      // Start Soil Mositure Loop
        int sensorValue1;
    sensorValue1 = analogRead(mositure_sensor_pin1);
        int sensorValue2;
    sensorValue2 = analogRead(mositure_sensor_pin2);
      //send back the values
        send(msgSoil1.set(sensorValue1));
        send(msgSoil2.set(sensorValue2));
      // End Soil mositure loop
        if (message.type==V_STATUS) {
            // Change relay state
            // Store state in eeprom
            // Write some debug info
            Serial.print(message.sensor);
     void onPulse()
       if (!SLEEP_MODE) {
         unsigned long interval = newBlink-lastBlink;
         lastPulse = millis();
         if (interval < 2080) {       // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)  WAS 2080
           return;
         flow = ((60000000.0 /interval) / ppl)*.264172;
         //flow = ((60000000.0 /interval) / ppl);
         // Serial.print("interval:");
         // Serial.println(interval);
         lastBlink = newBlink;
          // Serial.println(flow, 4);
       pulseCount++;
       if (message.type==V_VAR1) {
         pcReceived = true;
    I am not getting any flow rate data passed into my Vera Dashboard. I want to monitor the flow rate to make sure that the power actuated valve is closed when vera actually states that it is closed (I don't want to over water my plants causing them to stress and die).
    Any help with getting the flow rate to actually display in Vera would be helpful and much appreciated and any way to optimize the code to run quick and/or more efficient is gladly accepted.
    This is my first project and I honestly enjoyed building it. I know some of the components I used were overkill but I didn't care as it was a learning experience and I had fun.
