  3. about ACK ...
about ACK ...
2 Posts 1 Posters 1.5k Views 3 Watching
  • zzz-teoZ
    zzz-teoZ
    zzz-teo
    Hi, all
    I am trying to build a simple project of two nodes.One node with a push button(TOGGLE) and one switch, both with feedback LEDs.The other node with two relays and local control buttons.
    Its mandatory to have a reliable feedback to first node LEDs so, trying to figure out how ACK work in mysensors and how to resend the message if not ACK, I used
    this...
     //function to handle the ACK .
    #define ATTEMPTS 5
    void SendData(byte sensor, byte destination, bool value, bool ack) {
             msg.setSensor(sensor);
             msg.setDestination(destination);
      for(byte i=0; i<=ATTEMPTS; i++){
          if(send(msg.set((bool)value),ack)){
             Serial.println("ACK");
             break;
            }else{
            Serial.println("NACK");
    ... which works great but only until the message reaches the gateway, not the target node! although I can see the ACK back from the target node it remains unparsed!
    Can anyone give me an example of how to do it?
    • zzz-teoZ
      zzz-teoZ
      zzz-teo
      wrote on last edited by zzz-teo
      ... this approach seems that work !
      #define ACKDELAY 40 //seems 40 millis is a good value
      bool nodeACK = false;
            if(send(msg.set(value),ack)){
               Serial.println("Gateway ACK");
      //         wait(ACKDELAY);
               if(nodeACK == true){
               Serial.println("Node ACK");
               nodeACK = false;
               break;}else{
               Serial.println("Node NACK");
              }else{
              Serial.println("Gateway NACK");
              wait(ACKDELAY);
      ... in combination with this
      if (message.isAck()){
              nodeACK=true;
              digitalWrite(LED_PINS[message.sensor], message.getBool()? LED_ON:LED_OFF);
              Serial.println(F("ACK recieved LED Status Changed"));
      ... but probably is not the most elegand way!
      ... because if during the send/ack back message duty cycle, an ack from an other sensor received, a conflict may occure! i do not feel safe!
      (i also have a feeling that i did that post in the wrong topic! :confused: )
