  3. How can I include MyMessage object in my own class?
5 Posts 3 Posters 2.2k Views 3 Watching
  • G
    G
    gryzli133
    Dear all, I have been trying to change my Arduino Mega project controlling 16 relays for Light on/off. The board is working standalone as gateway for Domoticz. The reason is, I want to have bullet proof Smart Home with only one point of failture - in this case arduino Mega. Untill now I was separately creating every button/relay, so a lot of code. I though it would be nice, to create a class switch, and then create a array of 16 objects of class switch. This will make the code looking much better. The problem is, I need to create object MyMessage in my own class switch, how can I do it? The code is compiling until I declare MyMessage msg(child_id, V_LIGHT) inside the class switch. I will leave code for single switch and my code trying convert it to class object.
    Original working code:
    //#define MY_RADIO_NRF24
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // #define MY_WITH_LEDS_BLINKING_INVERSE
    // Enable inclusion mode
    #include <Bounce2.h>
    #define MY_REPEATER_FEATURE
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define BUTTON_PIN A1
    void before() {
        pinMode(pin, OUTPUT);
    Bounce debouncer = Bounce();
      delay(10000);
       // Setup the button.
      pinMode(BUTTON_PIN, INPUT_PULLUP);
      // After setting up the button, setup debouncer.
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      //presentation();
        present(sensor, S_LIGHT);
    MyMessage msg(1, V_LIGHT);
      if (debouncer.update()) {
        // Get the update value.
        int value = debouncer.read();
        // Send in the new value.
        if(value == LOW){
             saveState(1, !loadState(1));
             digitalWrite(RELAY_1, loadState(1)?RELAY_ON:RELAY_OFF);
             send(msg.set(loadState(1)));
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    Here the new object oriented version:
    class Switch
      public:
      uint8_t child_id;
      int buttonPin;
      int relayPin;
      bool relayON;
      bool relayOFF;
      Switch(int childId, int button, int relay, int debaunce, bool invertedRelay)
        child_id = childId;
        buttonPin = button;
        relayPin = relay;
        relayON = !invertedRelay;
        relayOFF = invertedRelay;
        pinMode(buttonPin, INPUT_PULLUP);
        debouncer.attach(buttonPin);
        debouncer.interval(debaunce);
        pinMode(relayPin, OUTPUT);
        digitalWrite(relayPin, loadState(child_id)?relayON:relayOFF);
      MyMessage msg(child_id, V_LIGHT);
      void Update()
          if(value == LOW)
             saveState(child_id, !loadState(child_id));
             send(msg.set(loadState(child_id)));
      void Present()
        present(child_id, S_LIGHT);
      void Update(const MyMessage &message)
        if (message.type==V_LIGHT && message.sensor==child_id)
           digitalWrite(relayPin, message.getBool()?relayON:relayOFF);
      delay(10000);
    PS: if you move the line with: MyMessage msg(child_id, V_LIGHT); at the before class declaration and change the child_id to f.e. 1, everything is compiling....
    • G
      G
      gryzli133
      nobody can help? ;-(
      • P
        P
        pjr
        wrote on last edited by pjr
        @gryzli133 said in How can I include MyMessage object in my own class?:
        IMO you are trying to initialize MyMessage object before your class has any value for child_id. Can be resolved using object reference.
        https://www.embedded.com/electronics-blogs/programming-pointers/4024641/An-Introduction-to-References
        So you wont initialize msg variable until when constructing instance of your class..
        Declare MyMessage &msg; in your class
        and set value for it in your class constructor: msg = MyMessage(child_id, V_LIGHT);
        ps. I'm natively writing C# and C++ isnt my strongest language so this might not be right ;)
        edit: did read bit more.. you need to init msg before entering inside constructor logic:
        class Switch
        public:
          Switch(........ int &child_id ......... ) : msg(child_id, V_LIGHT) {
          MyMessage &msg;
        I hope this works :)
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          @pjr version is almost correct, it would be correct without references, so skip '&' symbol and it should work
          • G
            G
            gryzli133
            You are great guys! It compile already, later I will also check the functionality ;-)
