  3. Multiple motion/door sketch
2 Posts 2 Posters 1.7k Views 3 Watching
  • B
    B
    bluezr1
    wrote on last edited by bluezr1
    I like to use store bought PIR motion sensors and have them trigger a Pam-1 relay due to their quality and being much safer. I’ve been using heks Door, Window and Push-button sketch with S_MOTION/S_DOOR. This way I only have to short one of the pins to ground.
    Well today I took the multi button relay sketch and combined it with heks sketch allowing me to have multiple motions on one pro mini.
    Here’s the sketch with two motions
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #define MY_NODE_ID 12
    #include <Bounce2.h>
    #define SSR_A_ID 1   // Id of the sensor child
    #define SSR_B_ID 2   // Id of the sensor child
    const int buttonPinA = 2;
    const int buttonPinB = 3;
    int oldValueA = 0;
    int oldValueB = 0;
    bool stateA = false;
    bool stateB = false;
    Bounce debouncerA = Bounce();
    Bounce debouncerB = Bounce();
    MyMessage msgA(SSR_A_ID, V_TRIPPED);
    MyMessage msgB(SSR_B_ID, V_TRIPPED);
      // Setup the button
      pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
      pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
      // After setting up the buttons, setup debouncer
      debouncerA.attach(buttonPinA);
      debouncerA.interval(5);
      debouncerB.attach(buttonPinB);
      debouncerB.interval(5);
    void presentation() {
      present(SSR_A_ID, S_MOTION);
      present(SSR_B_ID, S_MOTION);
      debouncerA.update();
       // Get the update value
      int valueA = debouncerA.read();
      if (valueA != oldValueA) {
         // Send in the new value
         send(msgA.set(valueA==HIGH ? 0 : 1));
         oldValueA = valueA;
      debouncerB.update();
       int valueB = debouncerB.read();
      if (valueB != oldValueB) {
         send(msgB.set(valueB==HIGH ? 0 : 1));
         oldValueB = valueB;
    Here's one with three motions
    #define MY_NODE_ID 11
    #define SSR_C_ID 3   // Id of the sensor child
    const int buttonPinC = 4;
    int oldValueA = 0;
    int oldValueB = 0;
    int oldValueC = 0;
    bool stateC = false;
    Bounce debouncerC = Bounce();
    MyMessage msgC(SSR_C_ID, V_TRIPPED);
      // Setup the button
      pinMode(buttonPinC, INPUT_PULLUP); // Setup the button Activate internal pull-up
      debouncerC.attach(buttonPinC);
      debouncerC.interval(5);
      present(SSR_C_ID, S_MOTION);
         oldValueA = valueA;
         oldValueB = valueB;
      debouncerC.update();
       int valueC = debouncerC.read();
      if (valueC != oldValueC) {
         send(msgC.set(valueC==HIGH ? 0 : 1));
         oldValueC = valueC;
    rejoe2R 1 Reply Last reply
    • B bluezr1
      int oldValueA = 0;
      int oldValueB = 0;
        // Setup the button
           oldValueA = valueA;
           oldValueB = valueB;
      int oldValueA = 0;
      int oldValueB = 0;
      int oldValueC = 0;
        // Setup the button
           oldValueA = valueA;
           oldValueB = valueB;
           oldValueC = valueC;
      rejoe2R
      rejoe2R
      rejoe2
      @bluezr1 Good progress!
      In case you are interested in how to shorten this kind of code and be more flexible in assigning PINs, you may have a look at this post here: https://forum.mysensors.org/topic/4847/multi-button-relay-sketch/33# by @korttoma
      Just delete the relay part...
