  3. Vera
  4. The problem of reconnection of the gateway to the controller VeraEdge after Reload Engine
1 Posts 1 Posters 1.2k Views 1 Watching
  • R Offline
    R Offline
    Romasu
    Hi!
    I use VeraEdge controller together with an Ethernet gateway WL5100 (ip:192.168.1.8:5003).
    Library version 2.1 from Github.
    My VeraEdge periodically loses connection with the gateway. (Messages from nodes cease to come to VeraEdge, from sensors to the gateway packets arrive).
    When I do a restart of the engine (Engine Reload) to VeraEdge gateway is not automatically reconnected. MySensor Plugin it gives an error communication.
    If, at the time of restarting the engine I do a reset on the gateway, the connection is fine.
    I want to do on VeraEdge scene which will overload the controller 1 once a day. How do I make an automatic reconnection of the gateway to VeraEdge after Reload Engine?
    VeraEdge firmware: 1.7.3014
    Log VeraEdge after Reload Engine (the gateway does not reset):
    50	12/27/17 22:39:39.597	luup_log:251: Arduino plugin: loading library L_Arduino ... <0x77745520>
    50	12/27/17 22:39:39.621	luup_log:251: Arduino plugin: library L_Arduino loaded <0x77745520>
    50	12/27/17 22:39:39.622	luup_log:251: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.5, 251 <0x77745520>
    50	12/27/17 22:39:39.622	luup_log:251: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, -, 251 <0x77745520>
    06	12/27/17 22:39:39.623	Device_Variable::m_szValue_set device: 251 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: GWAddress was: 192.168.1.8:5003 now: - #hooks: 0 upnp: 0 skip: 0 v:0x115c528/NONE duplicate:0 <0x77745520>
    50	12/27/17 22:39:39.623	luup_log:251: Arduino: Using network connection: IP address is 192.168.1.8:5003 <0x77745520>
    Log VeraEdge after the gateway reset:
    50	12/27/17 22:40:09.065	luup_log:251: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, 192.168.1.8:5003, 251 <0x77745520>
    06	12/27/17 22:40:09.066	Device_Variable::m_szValue_set device: 251 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: GWAddress was: - now: 192.168.1.8:5003 #hooks: 0 upnp: 0 skip: 0 v:0x115c528/NONE duplicate:0 <0x77745520>
    50	12/27/17 22:40:09.068	luup_log:251: Arduino: Sending: 0;0;3;0;2;Get Version <0x77745520>
    01	12/27/17 22:40:10.774	LuaInterface::CallFunction_Startup device 251 function startup took 31 seconds <0x77745520>
    03	12/27/17 22:40:10.774	JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 1 <0x77745520>
    03	12/27/17 22:40:10.775	JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 0 <0x77745520>
    50	12/27/17 22:40:10.802	luup_log:251: Arduino: Log: Gateway startup complete. <0x75d45520>
    50	12/27/17 22:40:10.803	luup_log:251: Arduino: Presentation: 0;255;0;0;18;2.1.1 <0x75d45520>
    50	12/27/17 22:40:10.804	luup_log:251: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,ArduinoLibVersion, 2.1.1, 251 <0x75d45520>
    Log gateway :
    0;255;3;0;9;TSM:READY:NWD REQ
    0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=2,c=1,t=4,pt=7,l=5,sg=0:750.9
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:1.92
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:76.6
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=0,pt=1,l=1,sg=0:91
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:1.94
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:76.3
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=0,pt=1,l=1,sg=0:96
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=4,c=1,t=39,pt=7,l=5,sg=0:0.75
    ->>>>> RESET <<<<<-
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP->: 192.168.1.8
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
    0;255;3;0;9;Eth:
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:1.96
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:75.9
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=0,pt=1,l=1,sg=0:94
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=4,c=1,t=39,pt=7,l=5,sg=0:0.00
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=2,c=1,t=4,pt=7,l=5,sg=0:751.0
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:2.00
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:76.9
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=0,pt=1,l=1,sg=0:92
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:1.78
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=0,c=1,t=0,pt=7,l=5,sg=0:1.75
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=1,pt=7,l=5,sg=0:75.5```
