  3. Vera
  4. UI7
UI7
27 Posts 13 Posters 17.0k Views 4 Watching
  • D Dany
    @olaeke Yes, I can ping the gateway. This board works fine as MQTT gateway with the openhab.
    But the library version is 1.4, not 1.4.1. How can I download the libraries 1.4.1?
    O
    O
    olaeke
    @Dany You will get 1.41 on the download link http://www.mysensors.org/download/. I have no problem access my Gateway with Ethernet, I'm using W5100 module and the lib from the download link.
    • P
      P
      pstoian
      Hi, I am getting the same error as @Dany .... I am using an W5100 / Ethernet gateway. I downloaded the latest library but still the library is not listed into the device.
      Also I can ping successfully the gateway. Any advice is much appreciated. Thank you.
      upload-53c4a6f9-fdbb-4ecc-b1b0-26441ab092de
      upload-c0ca7cc5-0084-47f7-ae87-f68abc24b253
      upload-caf03c43-f936-4745-95e6-6c755e9a6659
      • mjunqueiraM
        mjunqueiraM
        mjunqueira
        I managed to use Serial Gateway in my Ver Edge´s UI7 pulling a support ticket in the link http://getvera.com/support/. They asked me to enable the remote support to access my controller and than they updated my open WRT firmware to the latest one and now i can use the Serial Ports normally.
          mikemayers
          wrote on last edited by mikemayers
          #24
          @mjunqueira
          good to know you got Serial to worked.
          • BulldogLowellB
            BulldogLowellB
            BulldogLowell
            Anyone else getting this persistent error using UI7 and ethernet gateway?
            trying to upgrade....
            It works (messages go both ways) but this error won't go away...
            • korttomaK
              korttomaK
              korttoma
              #26
              Jim I read this from the Vera forum maybe it is only for z-wave devices or maybe might help for you also:
              If you have a device that functions fine, and yet reports "Can't detect device", the following may work for you;
              1) Change the variable CommFailure from "-1" to "0" (click outside the box to save)
              2) Clear the variable LastCommFailure (going from memory here; it is right next to the CommFailure) field (click outside the box)
              3) Go to the device settings, and change the "Automatically configure" to "no"
              Once the "error" has cleared, step 3 (I think) keeps it cleared.
              I don't have any personal experience since I'm not ready to move from UI5 just yet..
              • Tomas
              • korttomaK korttoma
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @korttoma
                Hey Tomas, thanks!
                That seems to have worked.
                I'll update if there is a problem.
                Other than this issue, I think UI7 is OK for me (testing in one location only :) )
