  3. Relay connection to NodeMCU V3
6 Posts 2 Posters 2.2k Views 2 Watching
  • gbuicoG Offline
    gbuicoG Offline
    gbuico
    Good afternoon everyone. I'm here to get suggestions from those of you who are more experienced than me in electronics.
    The problem is simple. I have an ESP8266 (NodeMCU V3 Lolin) and I'd like it to drive a 5Vdc relay.
    Searching in internet I can find many samples like this... BUT.... some of them are connecting the positive wire of the relay to Vcc (3,3V), some others to VU (5V) and all say it's perfectly working.
    If I find two solution to the same problem I get worried :)
    Specifically, should I connect Vcc, I'm not sure that the relay would switch in a secure way.
    At the same, if I connect it to VU, I'm asking myself if this would not create a problem since the pin triggering the relay is coming from a GPIO pin and should be 3.3V
    Please forgive me if this is a stupid question but I have to experience in this area.
    Thanks in advance
    Giacomo
      If you get the opto isolated relay boards, you can power the trough a separate 5v vcc pin ,but I was able to use them on raspberry pi at 3.3v
      • gbuicoG Offline
        gbuicoG Offline
        gbuico
        @gohan , if I understand well, in a relay like the one of the attached picture, you removed the jumper, connected +5V to JD and GND, In1, In2, 3,3V on the other connector?
        If this is true I'll be happy because this is how I'd have done.... but I couldn't find anybody confirming it...
          I don't see the picture, but keep in mind that to toggle a relay you need to put the pin to Low
          • gbuicoG Offline
            gbuicoG Offline
            gbuico
            Sorry... my fault.
            Yes, the need to pull the pin low is the only sure info I found around.. :(
              As you said before, you should be good to go
              12.2k
